JimK Posted April 22 Report Share Posted April 22 At this time of year many of us are cleaning up our RVs and getting ready for warm weather RV travel. I posted my recommendations on a different forum and thought it might be of interest here. Six or seven years ago, I did my Spring cleaning including washing and waxing the RV. I used a popular "premium flagship" wax and was disappointed with the results. Even after two full rubbed on coats the results were splotchy and uneven. I used lots of ammonia and wax stripper and recoated with Zep. I applied several very thin coats. Now all of these years later the finish still looks great with no flaking, no yellowing or deterioration of any kind. The black streak problem is gone. Streaks and dirt just rinse off even without using soap or a mop. Every year or so, typically in the Spring, I do a thorough washing and re-apply another thin coat of Zep. There is minimal work with no buffing or rubbing needed. I just wipe down the RV with a rag lightly dampened with Zep. If you decide to try Zep, proper surface prep is essential. As with any wax job, you first need to scrub off any dirty and oxidized areas and of course also remove those black streaks. There is one additional step. You need to go over the entire RV a couple of times with a mop and dilute ammonia or other wax stripper. You also need to plan on doing at least 3-4 thin coats of Zep with about an hour of dry time between each coat. Quote Link to comment Share on other sites More sharing options...
rpsinc Posted April 22 Report Share Posted April 22 I think you have found an alternative to a process I used some years back with a product called PoliGlo. They supply a mild acid based cleaner and the finish is applied just as you indicated. When I was using it, it reminded me of liquid Johnson Floor wax. I found it to work well and yes, several coats were required for best results. I did not discover how long it lasted as the results were so good on that trailer(2004 Alfa) that someone took note and bought it from me at a profit on my end. I have read about this product and have wondered about its durability. Thanks for answering that question esp now that I am in the process of doing some restoration to the exterior of my 2008 Teton. Quote Link to comment Share on other sites More sharing options...
Dutch_12078 Posted April 22 Report Share Posted April 22 1 hour ago, rpsinc said: I think you have found an alternative to a process I used some years back with a product called PoliGlo. They supply a mild acid based cleaner and the finish is applied just as you indicated. When I was using it, it reminded me of liquid Johnson Floor wax. I found it to work well and yes, several coats were required for best results. I did not discover how long it lasted as the results were so good on that trailer(2004 Alfa) that someone took note and bought it from me at a profit on my end. I have read about this product and have wondered about its durability. Thanks for answering that question esp now that I am in the process of doing some restoration to the exterior of my 2008 Teton. There's been some speculation over the years that PoliGlo was repackaged ZEP, although I've never seen anything to back that up. Lowes "Red Max" was indeed private labeled ZEP, and at some point it no longer made sense for Lowes to keep the Red Max brand, switching instead to the standard ZEP branded products. Quote Link to comment Share on other sites More sharing options...
Pappy Yokum Posted April 22 Report Share Posted April 22 (edited) FYI: "JimK" posted the (almost) identical info on RV.Net (Open Roads Forums) - as "JimK-NY". The thread title is "Zep Floor Wax Update", and found in the General RVing Issues forum. His thread has received additional replies & comments there - if anyone is interested...😉 . Edited April 22 by Pappy Yokum Condensed! Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted April 22 Report Share Posted April 22 (edited) There are numerous posts in past years on irv2.com complaining about poor results. This floor wax seems to lack any UV resistance from the posts I've read. Edited April 22 by Ray,IN Quote Link to comment Share on other sites More sharing options...
Pappy Yokum Posted April 22 Report Share Posted April 22 1 hour ago, Ray,IN said: There are numerous posts in past years on irv2.com complaining about poor results. This floor wax seems to lack any UV resistance from the posts I've read. Yep (that's "yep", not Zep, LOL!) - the positives should be weighed against the negatives - both old & new. Ya gotta decide what you are willing to believe - before your roll the dice....and put in whatever effort req'd for your wax (or Zep) job. About 100 posts (for a poll?) would be a good start !! Quote Link to comment Share on other sites More sharing options...
coyote Posted April 23 Report Share Posted April 23 I had very good results with Zep wax on a previous rig. I scrubbed the coach with Bar Keepers Friend to get all the years of built up chalking and black streaks then wiped it down with ammonia. It was easy to put on multiple light coats and it lasted well. Quote Link to comment Share on other sites More sharing options...
JimK Posted April 23 Author Report Share Posted April 23 14 hours ago, Ray,IN said: There are numerous posts in past years on irv2.com complaining about poor results. This floor wax seems to lack any UV resistance from the posts I've read. Anyone checking the forums will find some negative comments and also find that many of us have had great success: little or no maintenance, no flaking, no yellowing and durability lasting for years and years. I believe most of the different results are due to surface prep. It is essential to strip off old carnauba wax. A heavily wax RV will take several moppings with stripper or dilute ammonia. I would even recommend scrubbing the entire RV with Bar Keepers Friend or Bon Ami and a kitchen scrubber. If you do a google search you will also find some interesting facts on UV. First, acrylics are highly effective in blocking UV light. No additives are needed for an acrylic finish. Second, you can find studies on the effectiveness of UV additives in carnauba wax products. The additives are minimal, mostly there for advertising purposes, and even the minimal UV protection deteriorates within a few weeks. That said, I do agree that Zep is not for everyone. The shine may not last for long, but a carnauba wax finish can have more shine than a Zep finish. Some people enjoy waxing the RV. I have a neighbor that does. He goes on short trips several times a year and washes and waxes before every trip. Quote Link to comment Share on other sites More sharing options...
rpsinc Posted April 24 Report Share Posted April 24 I've been looking for this product and cant seem to find it, unless I am not looking for the correct product. I had some that I used to wax a new VCT floor in a rental unit and it worked well, but used it all. I wanted some to try on my current 5er. Anybody have a link?? Quote Link to comment Share on other sites More sharing options...
RandyA Posted April 24 Report Share Posted April 24 (edited) ZEP has a sealer they recommend using first and then the Acrylic ZEP wax. Does anyone use the first coat sealer before applying the wax? Be careful with ammonia or wax strippers as they will turn bare polished aluminum dull within a few days. Edited April 24 by RandyA Quote Link to comment Share on other sites More sharing options...
JimK Posted April 25 Author Report Share Posted April 25 3 hours ago, rpsinc said: I've been looking for this product and cant seem to find it, unless I am not looking for the correct product. I had some that I used to wax a new VCT floor in a rental unit and it worked well, but used it all. I wanted some to try on my current 5er. Anybody have a link?? Zep products are sold at Lowe's, Home Depot, Walmart and most hardware stores including Ace. There are a couple of formulations that seem quite similar. I have used the high traffic floor finish. There is another formulation called wet look. Quote Link to comment Share on other sites More sharing options...
sandsys Posted April 25 Report Share Posted April 25 4 hours ago, JimK said: There is another formulation called wet look. Good for when you have a new puppy? Maybe not. I'd prefer to know where the puddles are. Linda Quote Link to comment Share on other sites More sharing options...
JimK Posted April 25 Author Report Share Posted April 25 ☺️ I have a vinyl floor in my RV but have never bothered with using floor wax. Instead I bought a piece of indoor/outdoor carpeting and cut it to fit the irregular floor shape. I can pull it out and shake or beat the dirt out. After considerable use, I usually take it out, hose it down and hang to dry. I have traveled with house trained cats but never with a dog. Quote Link to comment Share on other sites More sharing options...
TXiceman Posted April 25 Report Share Posted April 25 Jim, they are discussing using the ZEP floor way on the exterior of the RV. Ken Quote Link to comment Share on other sites More sharing options...
rpsinc Posted April 25 Report Share Posted April 25 14 hours ago, JimK said: Zep products are sold at Lowe's, Home Depot, Walmart and most hardware stores including Ace. There are a couple of formulations that seem quite similar. I have used the high traffic floor finish. There is another formulation called wet look. I am aware of those options but I have seen them needing periodic maintenance and burnishing. Not what I think I need. Quote Link to comment Share on other sites More sharing options...
