Pat & Pete Posted November 16, 2020 Report Share Posted November 16, 2020 Just an FYI : We recently had the fuel pump of our onboard Onan 5000 generator start functioning sporadically . It would be fine for a couple minutes before quitting . After repeating this a few times , it would not function at all , until it cooled . Time for a new pump . Onan wants a ridiculous price of about $100 . I bought and installed a low volume , reasonably priced , aftermarket fuel pump . The pump I bought has very good reviews . Being as the OEM fuel pump is located in such a place as to make replacement a major pain , I left it where it was/is . The new pump has been relocated to be much more accessible . Installation was very simple and done with ordinary hand tools . We've used the generator a number times since and the pump has functioned flawlessly . So , for the less than 20 dollar investment and maybe a half hour of very easy labor , we have a generator that functions properly whenever needed/wanted , again . Quote Goes around , comes around . Link to comment Share on other sites More sharing options...
oldjohnt Posted November 16, 2020 Report Share Posted November 16, 2020 Pat & Pete AMEN ........The same holds true for sooooooooooo many brands of generators and marine products etc. The name brand, be it Onan or say Mercury etc for Marine, may be 2 to 4 times as high as a generic brand that can do the same job BUT SUBJECT TO the specs being correct which can be a fooler grrrrrrrrrrrrrrr. A 12 VDC electric fuel pump needs to be able to supply adequate X CFM flow at adequate Y PSI of pressure while drawing say Z amps..........One thing I did run into using generic elec fuel pumps on small carburetor engines was EXCESS PRESSURE which over rode the carbs needle valve and seat float assembly capability. The pumps pressure cant be too high unlike say a high volume automotive fuel pump. HOWEVER I have to admit there have been times when I thought Id substitute something cheap thinking it was close enough only to later find out I WAS WRONG grrrrrrrrrrrrr lol John T Live from SKP in Livingston Texas, a beautiful warm fall day sitting around jamming bluegrass on my banjo with others... Quote Link to comment Share on other sites More sharing options...
Pat & Pete Posted May 14, 2021 Author Report Share Posted May 14, 2021 Just an update/followup : We've used the generator more than a few times since I installed the replacement fuel pump . The big freeze this past winter gave more opportunity than we wanted , as the shore power was lost for a time . Through the whole 6 months since the installation , the pump hasn't had a single hiccup in operation , nor has it caused any detrimental effect . The generator ran/runs fine without skipping a beat . Quote Goes around , comes around . Link to comment Share on other sites More sharing options...
rpsinc Posted May 14, 2021 Report Share Posted May 14, 2021 Sounds like winner, winner, chicken dinner Quote Marcel Link to comment Share on other sites More sharing options...
Kirk W Posted May 14, 2021 Report Share Posted May 14, 2021 Thanks for the update. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Pat & Pete Posted May 14, 2021 Author Report Share Posted May 14, 2021 You're welcome . And , I'll have to look into that chicken dinner part . Quote Goes around , comes around . Link to comment Share on other sites More sharing options...
Dutch_12078 Posted May 14, 2021 Report Share Posted May 14, 2021 Our current Onan 5500 has been running with a universal low pressure fuel pump from NAPA for the past 4 years. A previous RV had an Onan Marquis 7000 where the fuel pump also failed, and Onan shops wanted at least $150 for the OEM replacement. I found I could read the pump name and numbers through the Onan paint, and the exact same Carter pump was $52 on Amazon. The only difference was the missing Onan paint and it came with a bunch of unneeded installation parts that I've mostly repurposed for other projects. Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
feepfeep Posted May 25, 2021 Report Share Posted May 25, 2021 is there a way to install a fuel pump on an older model that doesn't have one? Quote Link to comment Share on other sites More sharing options...
GlennWest Posted May 25, 2021 Report Share Posted May 25, 2021 Electric pump or vaccumm pump Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Dutch_12078 Posted May 25, 2021 Report Share Posted May 25, 2021 The Onan Marquis 5000 BGM uses an Onan P/N Onan 149-2267 electric fuel pump made by Carter. The Carter P4070 is the same pump for much less money. Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Pat & Pete Posted May 26, 2021 Author Report Share Posted May 26, 2021 17 hours ago, feepfeep said: is there a way to install a fuel pump on an older model that doesn't have one? Of course there's a way . You'll likely have to re-route / re-engineer the fuel inlet , but that's expected for any non - OEM configuration . I see you have your genset running , according to your other thread . There's always more then one way around a bush . Quote Goes around , comes around . Link to comment Share on other sites More sharing options...
feepfeep Posted May 28, 2021 Report Share Posted May 28, 2021 On 5/26/2021 at 8:37 AM, Pat & Pete said: Of course there's a way . You'll likely have to re-route / re-engineer the fuel inlet , but that's expected for any non - OEM configuration . I see you have your genset running , according to your other thread . There's always more then one way around a bush . It crapped out again. I finally understood I don't have a traditional fuel pump but a gravity fed one. I don't think it is working properly or I've got a kink in the line somewhere that is feeding it but I can't see past where it goes into the frame. Either way I'm ordering a new one and will replace it. Quote Link to comment Share on other sites More sharing options...
Pat & Pete Posted May 28, 2021 Author Report Share Posted May 28, 2021 23 minutes ago, feepfeep said: It crapped out again. I finally understood I don't have a traditional fuel pump but a gravity fed one. I don't think it is working properly or I've got a kink in the line somewhere that is feeding it but I can't see past where it goes into the frame. Either way I'm ordering a new one and will replace it. Please keep us posted on your progress . Quote Goes around , comes around . Link to comment Share on other sites More sharing options...
Dutch_12078 Posted May 28, 2021 Report Share Posted May 28, 2021 44 minutes ago, feepfeep said: It crapped out again. I finally understood I don't have a traditional fuel pump but a gravity fed one. I don't think it is working properly or I've got a kink in the line somewhere that is feeding it but I can't see past where it goes into the frame. Either way I'm ordering a new one and will replace it. It's not "gravity fed", despite any labels put on it. The pump is capable pulling fuel up at least a couple of feet, and delivering it to the carburetor at 4-6 PSI. Carter sells exactly the same pump as a "fuel transfer pump". Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Ray,IN Posted May 28, 2021 Report Share Posted May 28, 2021 On 5/25/2021 at 5:47 PM, feepfeep said: is there a way to install a fuel pump on an older model that doesn't have one? The only gas engine without a fuel pump is gravity-fed. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
