SuiteSuccess Posted October 10, 2020 Report Share Posted October 10, 2020 39DBRS3 DRV. Our off door kitchen slide is lifting and pulling up the vinyl tiles with each extension. I can see the rollers and the only one that I can see that is adjustable is under the fridge. I’ve tried adjusting up and down with no benefit. We’ve also tried thin vinyl planks under the rollers but can’t get them to come up on top of these strips. Have also tried carpet remnants with no luck. Any suggestions? Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
GlennWest Posted October 10, 2020 Report Share Posted October 10, 2020 Doesn't all rv lift that slideout? Know my previous DRV did and also my Teton. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
SuiteSuccess Posted October 10, 2020 Author Report Share Posted October 10, 2020 26 minutes ago, GlennWest said: Doesn't all rv lift that slideout? Know my previous DRV did and also my Teton. I’m sorry but don’t follow what you’re saying. All RV? Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
GlennWest Posted October 10, 2020 Report Share Posted October 10, 2020 (edited) Both I owned did. I believe it is a common item. To get a flush floor it has to lift up to clear or it scrubs when it comes in. Interesting topic though. I intend later doing away with the carpet also. Edited October 10, 2020 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
lappir Posted October 10, 2020 Report Share Posted October 10, 2020 To have flat floors in a slide out there has to be a lift by "Rollers" somewhere. I chose to go with raised floor in the slide outs because they seal completely and do not have to raise the whole slide to allow them to be pulled in. My first RV had all of my Kitchen on a slideout. In less than two years I had a severe breakdown of every part of the slide out because of all the weight. My current slides have nothing built in and I have gotten used to having to step up. Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
a_elkins Posted October 14, 2020 Report Share Posted October 14, 2020 (edited) Hey SuiteSuccess. You said adding vinyl planks didn't work; I have read of others with a similar problem using those super-thin flexible cutting boards on the floor. Maybe stick them down with painter's tape? We've got the grooves on the door side and haven't come up with a solution either. We'll probably eventually just replace the 2 planks. Edited October 22, 2020 by a_elkins Quote Link to comment Share on other sites More sharing options...
SuiteSuccess Posted October 14, 2020 Author Report Share Posted October 14, 2020 22 minutes ago, a_elkins said: Hey SuiteSuccess. You said adding vinyl planks didn't work; I have read of others with a similar problem using those super-think flexible cutting boards on the floor. Maybe stick them down with painter's tape? We've got the grooves on the door side and haven't come up with a solution either. We'll probably eventually just replace the 2 planks. Think that’s gonna be a solution. A wedge made from a thin HDPE cutting board permanently mounted so the roller gets some elevation to roll onto a plank. Will post the results. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
bags Posted October 18, 2020 Report Share Posted October 18, 2020 When we replaced carpet with laminate flooring we had an issue of the slide scraching the floor. Our slide just raises up and slides in with no rollers. We ordered (0.031" plastic sheet 48" x 24" GP) sheets of plastic fromhttps://www.onlinemetals.com. These sheets are used to move heavy equipment on. We have 3 sheets that we put under the problem places and pull the slide in and out. I hope this makes sense for you. Cheap fix $55.85 in 2015. They are kind of a pain as you have to put them down prior to bringing in the slide and then (we store ours under the bed) store them when the slides are out. You also have to watch to make sure they do not get sucked out with the slide. I they do just bring the slide in and re position. Stay safe. JB Quote John and Michal Bagley 1999 Volvo 610 the 'Millennium Falcon', 400 hp ISM, Autoshift Gen 2, single axel w/steel bed, Pressure Pro, VMSPC, Trailer Saver Air Hitch, 3 bags, 38 foot Royals International, and our 3 dogs. Link to comment Share on other sites More sharing options...
DJohns Posted October 19, 2020 Report Share Posted October 19, 2020 When I bought my 2017 new New Horizons it came with three sheets of plastic. If the sheets are not under the rollers it will make marks on the floor. Quote 2002 Beaver Marquis Emerald C-12 Cat 505 HP 2014 Volvo 630 D-13 I Shift SOLD 2017 New Horizons SOLD Link to comment Share on other sites More sharing options...
orca Posted October 19, 2020 Report Share Posted October 19, 2020 While doing a walkthru of our new Fullhouse with the dealer i pointed out two scratches on the kitchen floors. They replaced the tiles and gave us a pair of sliders made from hard plastic about 4 inches by 36 inches by about 1/8 inch thick. I make sure they are placed under the fridge area before i bring in the slide. So far no more scratches! Quote 2004 Freightliner m2 106 2015 DRV lx450 Fullhouse 2019 Indian Springfield 2014 Yamaha 950 V-Star Link to comment Share on other sites More sharing options...
SuiteSuccess Posted October 23, 2020 Author Report Share Posted October 23, 2020 Thanks folks. We have been using vinyl flooring planks with success on the door side slide and have worked well. Think my solution is going to be a thin tapered HDPE “wedge” permanently mounted out of sight at the leading edge of the slide so the rollers will raise up enough to get on top of our planks. Will post pics when done. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
HERO Maker Posted October 23, 2020 Report Share Posted October 23, 2020 Carl, try small strips or squares of carpet. Turn it upside down, place it on the floor before bringing the slide in. Works well! I believe Phil also uses some rolled carpet to do the same thing! We have those (I think Lippert) 3' x 6" plastic strips. they don't work as well. Quote Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
SuiteSuccess Posted October 23, 2020 Author Report Share Posted October 23, 2020 (edited) 3 hours ago, HERO Maker said: Carl, try small strips or squares of carpet. Turn it upside down, place it on the floor before bringing the slide in. Works well! I believe Phil also uses some rolled carpet to do the same thing! We have those (I think Lippert) 3' x 6" plastic strips. they don't work as well. Thanks Rocky. We tried that and rollers wouldn’t get on top and would just push them. The vinyl flooring planks are thin so I just need the rollers to raise just a bit hence the wedge idea. Edited October 23, 2020 by SuiteSuccess Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
NTPA Announcer Posted October 28, 2020 Report Share Posted October 28, 2020 Suitesuccess: Please post as many as you can. We to are going to the new flooring and Miss Judy has 4 new recliners bought. She said I want .... and I said SURE !!! Miss Judy gets whatever she wishes. That way I cab go to HF more often !! See everyone in Tnn. In the spring ! Quote Denver and Ms Judy Geitgey 2006 VOLVO 780 41 ' Redwood NTPA Event Announcer dngeitgey@gmail.com Link to comment Share on other sites More sharing options...
