trimster Posted August 25, 2020 Report Share Posted August 25, 2020 I'm getting the hayse air over electric controller. Need help with the additional parts (exact parts & possible source appreciated), and which air line(s) to cut into. Photos? I did search the forum and came up empty. I have little luck with the search function. TIA Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Seniramsu Posted August 25, 2020 Report Share Posted August 25, 2020 Here's an older write up from the resource guide. http://www.hhrvresource.com/node/69 The use of the Hayes is towards the bottom. Pretty sure any DOT approved 1/4" T union would work fine for tapping into the air line. Quote 2013 Volvo 780 "Grunt" D13 I-Shift w/ ET Hitch 2016 Cyclone 4200 Link to comment Share on other sites More sharing options...
trimster Posted August 25, 2020 Author Report Share Posted August 25, 2020 (edited) ...and what are the alternatives? The one that plugs into the port is out of of our price range with the unit + adapter. Update: Hayse is 4+ weeks out on delivery to suppliers. Ugh. Bob Edited August 25, 2020 by trimster Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted August 25, 2020 Report Share Posted August 25, 2020 The Hayes air line ties into the trailer hand brake line on the dash. The signal wire TO the Hayes comes off the Brake Light Switch. Or you can pull a wire from the Jackaloppe brake light wire- truck side. The Black and White are your power and ground, If you can find a Key'd hot at the fuse panel to tape into its easy. The blue wire runs back to the Jacky and goes to the Trailer Brake lug on the board input side. Quote Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
GlennWest Posted August 26, 2020 Report Share Posted August 26, 2020 (edited) I never could get ours right. Everybody else seem to love them. Voltage checked good. Finally got disgusted and ripped everything out and put on disc. Put air over hydraulic on. Sweet Edited August 26, 2020 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
lockmup68 Posted August 26, 2020 Report Share Posted August 26, 2020 I ran brake signal from jackaloppe and separate power distribution panel hot/ground to that hayes. Quote 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
NeverEasy Posted August 28, 2020 Report Share Posted August 28, 2020 (edited) I have a Hayes I could sell you. $.50 on the dollar. Used but in good shape. It is the latest model that I bought to replace the old, poor functioning one. It worked well enough on my air over electric but when I upped the trailer to air over hydraulic disc (more like air over electric over hydraulic disc) it was way too aggressive. I had to put a stopper on the manual slide to keep it from locking up the trailer brakes. It is still mounted in the truck. I found a new Max Brake controller that someone bought and never installed it. Use this search string in Google: site:https://www.rvnetwork.com Hayes Edited August 28, 2020 by NeverEasy Added url Quote Chet & Deb '01 Volvo 660 w/ Smart '19 Forest River Columbus 320RS 5th wheel 2022 Chev 2500HD Long Bed Retired CWO4, USN and federal service Electronics Tech/Network Engineer/Welder/Machinist Link to comment Share on other sites More sharing options...
trimster Posted August 28, 2020 Author Report Share Posted August 28, 2020 NeverEasy.... messaged you. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
trimster Posted September 7, 2020 Author Report Share Posted September 7, 2020 (edited) Well, I guess I'm going to be one who has problems with the Hayes controller. I have power & ground direct to the batteries. The blue (controller) runs to the Jackalopee controller in. Red (brake light) is not connected. I'm getting .02 v on the blue wire when manually activating the Hayes. Not what it should be I'm guessing. Trailer attached.. Any thoughts would be appreciated. And what does this air control do? Can I tie into the black line ? Bob Edited September 7, 2020 by trimster Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
hatrack Posted September 8, 2020 Report Share Posted September 8, 2020 bob, I don't know if it is similiar to the directlink but with the directlink you have to touch the brake to activate it. I almost sent mine back because before I call them and they told me the brake has to wired and touched. Ken.... Quote 2024 DRV Fullhouse JX450 2017 DRV Fullhouse JX450 2020 Volvo VNR 42-640, D13, 455hp, Ishift, 189"wb, factory single, ET Junior Hitch @ 195", Jacklopee, Directlink 2016 GMC 3500 Denali DRW, CC, LB, Curt 25k, Sold Link to comment Share on other sites More sharing options...
GlennWest Posted September 8, 2020 Report Share Posted September 8, 2020 Mine as long as I had air worked. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
trimster Posted September 8, 2020 Author Report Share Posted September 8, 2020 I think I tied into the wrong air lines. Fixing that tomorrow. Still no reason for the low voltage, yet. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
GlennWest Posted September 8, 2020 Report Share Posted September 8, 2020 You can take the cover off and press pedal. Should move arm. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
FlyBoy66 Posted September 8, 2020 Report Share Posted September 8, 2020 On 8/28/2020 at 11:50 AM, NeverEasy said: I have a Hayes I could sell you. $.50 on the dollar. Used but in good shape. It is the latest model that I bought to replace the old, poor functioning one. It worked well enough on my air over electric but when I upped the trailer to air over hydraulic disc (more like air over electric over hydraulic disc) it was way too aggressive. I had to put a stopper on the manual slide to keep it from locking up the trailer brakes. It is still mounted in the truck. I found a new Max Brake controller that someone bought and never installed it. Use this search string in Google: site:https://www.rvnetwork.com Hayes NeverEasy... do you still have your Hayes for sale? I would be interested in buying it from you. 612.269.2376 Quote Link to comment Share on other sites More sharing options...
noteven Posted September 8, 2020 Report Share Posted September 8, 2020 If you can locate your trailer air brake application circuit T’ing the Hayes there will give you nice progressive braking and allow you to use the trailer air brake control to apply trailer electric brakes vs reaching for the Hayes unit. Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
