rstews Posted July 31, 2020 Report Share Posted July 31, 2020 Hi, Last trip out our fridge stopped cooling. I've checked other users queries and this is what I know. Dometic RM 2652 in 2006 trailer. I assume it's original. The thermistor read about 2k ohms in 90 degree weather but went up to near 9K ohm in ice water. In gas mode the flame lights and stays on. In electric mode the element pulls 2.78 amps which matches the 44 ohm element. It switches between modes properly. The chimney gets hot and the lower pipe into the cooling unit gets warm, I can keep my hand on it. Feels like near ambient temp on the upper pipes out of the cooling unit. I've never smelled ammonia inside and don't see any green residue outside with the unit still in place. The lights on the front panel all work as well as the interior lamp. I've downloaded the service manual as suggested. I've also removed all power from the board to do a hard reset. The two fuses on the control board are good. The vent seems to be clear. Now what? Is the purpose of the control board to turn on the heater as needed? If so I guess it's working. Could I have a leak up high on the coils that I can't see yet? Any way to test ammonia level? Thanks, Randy Quote Link to comment Share on other sites More sharing options...
griffy Posted August 1, 2020 Report Share Posted August 1, 2020 Does your freezer maintain normal temperatures but the refrigerator doesn't cool? If so, disconnect the thermistor from the control panel and see if your refrigerator gets cold overnight. Quote Link to comment Share on other sites More sharing options...
rstews Posted August 1, 2020 Author Report Share Posted August 1, 2020 Nothing cools, fridge nor freezer Quote Link to comment Share on other sites More sharing options...
sundancer268 Posted August 1, 2020 Report Share Posted August 1, 2020 Sounds like the cooling unit went south on you. There is no way the owner can check the refrigerant level that I know of and I don't know of any RV Service Departments that can either. They will want to sell you a new reefer or a cooling unit. You can purchase a cooling unit yourself and install it if you are handy and physically able. I would not go with a unit made by the manufacturer anymore. The units made before the turn of the century were better built in my opinion than the 21st century units. I have a unit in my Motor home from 95 and other than the control board failing shortly after I purchased the unit used, I have had no problems. I installed a used unit from a salvage yard in my 1984 Travel Trailer and it also works good. I believe it is a early 90s unit. One is a Norcold and the other is a Dometic. As long as the units are operated only when level or in motion, they should work almost forever as there are no moving parts to wear out. Quote U.S. Navy GSMC(SW) (RETIRED) 1993-11-01, 26 years service with 23 years of that active and 3 years reserve. Now retired after 20 years at local hospital in the maintenance department. 1995 Gulf Stream Scenic Cruiser 34' DP W/6Spd Allison. Road Master Sterling All terrain, Air Force One, towing new 2019 Jeep Cherokee Elite Link to comment Share on other sites More sharing options...
Dutch_12078 Posted August 1, 2020 Report Share Posted August 1, 2020 (edited) Most likely the sodium chromate rust inhibitor in the ammonia/hydrogen mix has crystallized and plugged the tubing due to off level operation and/or overheating. There is no repair possible in that case, and the cooling unit needs to be replaced. If your RV usage is primarily in campgrounds with electric hookups, a residential fridge replacement may be the most economical way to go. Depending on the dimensions of your current fridge, there may be a residential model that's a near perfect fit in the opening. Edited August 1, 2020 by Dutch_12078 Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
richfaa Posted August 1, 2020 Report Share Posted August 1, 2020 Sounds like the cooling unit ours did the same. The Amish cooing unit from Indiana is far superior to the OEM unit our ESP plan covered the cost of replacement. Quote Helen and I are long timers ..08 F-350 Ford,LB,CC,6.4L,4X4, Dually,4:10 diff dragging around a 2013 Montana 3402 Big Sky SKP 100137. North Ridgeville, Ohio in the summer, sort of and where ever it is warm in the winter. Link to comment Share on other sites More sharing options...
rstews Posted August 1, 2020 Author Report Share Posted August 1, 2020 1 hour ago, richfaa said: Sounds like the cooling unit ours did the same. The Amish cooing unit from Indiana is far superior to the OEM unit our ESP plan covered the cost of replacement. Thanks. I was just looking at RV Cooling Unit Warehouse that claims to sell the Amish units. Is this the same place you're talking about and if not do you have contact info? Randy Quote Link to comment Share on other sites More sharing options...
Kirk W Posted August 1, 2020 Report Share Posted August 1, 2020 No matter what cooling unit you choose to use if you do replace it, before you do so take the time to read this article about the RV-ARP devices and how they work. I would not operate an RV type refrigerator without one. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
rstews Posted August 1, 2020 Author Report Share Posted August 1, 2020 Thanks for the replies! I ordered a new, not remanufactured, unit from RV Cooling Unit Warehouse. Now comes the fun part. Need to trick that strong friend to show up to my house. Randy Quote Link to comment Share on other sites More sharing options...
TXiceman Posted August 2, 2020 Report Share Posted August 2, 2020 When installing the new cooling unit in the old cabinet, be sure and get the unit well sealed to the cabinet. Any moisture leakage will cause the unit to load up with moisture and ruin the insulation. Ken Quote Amateur radio operator, 2023 Cougar 22MLS, 2022 F150 Lariat 4x4 Off Road, Sport trim <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot Link to comment Share on other sites More sharing options...
rstews Posted August 2, 2020 Author Report Share Posted August 2, 2020 1 hour ago, TXiceman said: When installing the new cooling unit in the old cabinet, be sure and get the unit well sealed to the cabinet. Any moisture leakage will cause the unit to load up with moisture and ruin the insulation. Ken Thanks, Ken. Will do Randy Quote Link to comment Share on other sites More sharing options...
oldjohnt Posted August 2, 2020 Report Share Posted August 2, 2020 Ive seen a few You Tube videos showing cooling unit replacements, looks like a job I would NOT enjoy lol Good luck with it John T Quote Link to comment Share on other sites More sharing options...
richfaa Posted August 2, 2020 Report Share Posted August 2, 2020 14 hours ago, rstews said: Thanks for the replies! I ordered a new, not remanufactured, unit from RV Cooling Unit Warehouse. Now comes the fun part. Need to trick that strong friend to show up to my house. Randy Yes that is were we got both of our replacement units never another problem. Quote Helen and I are long timers ..08 F-350 Ford,LB,CC,6.4L,4X4, Dually,4:10 diff dragging around a 2013 Montana 3402 Big Sky SKP 100137. North Ridgeville, Ohio in the summer, sort of and where ever it is warm in the winter. Link to comment Share on other sites More sharing options...
bobsallyh Posted August 2, 2020 Report Share Posted August 2, 2020 I have replaced two cooling units over the years. Not that bad of a job. What we did was put our coffee table covered with a piece of carpet at the bottom of the refer cabinet, slid the refer out of the hole standing it on the coffee table. Then we laid it door down on the table after removing what needed to be done in the cold box and freezer. As per instructions just followed thru. One thing I distinctly remember was the prying loose of the old coil. Thought that was the end of the reefer. But followed thru and everything went according "to Hoyle" even though "Hoyle" wasn't there. Slid back in the hole connected everything, vacuumed up the floor and within several hours it started cooling down. Quote Link to comment Share on other sites More sharing options...
rstews Posted August 2, 2020 Author Report Share Posted August 2, 2020 6 hours ago, bobsallyh said: I have replaced two cooling units over the years. Not that bad of a job. What we did was put our coffee table covered with a piece of carpet at the bottom of the refer cabinet, slid the refer out of the hole standing it on the coffee table. Then we laid it door down on the table after removing what needed to be done in the cold box and freezer. As per instructions just followed thru. One thing I distinctly remember was the prying loose of the old coil. Thought that was the end of the reefer. But followed thru and everything went according "to Hoyle" even though "Hoyle" wasn't there. Slid back in the hole connected everything, vacuumed up the floor and within several hours it started cooling down. Thanks. Was trying to think of something to slide it out on. I'll see if I have a table the right height. Randy Quote Link to comment Share on other sites More sharing options...
rstews Posted August 28, 2020 Author Report Share Posted August 28, 2020 Just an update. Got the new unit installed a few weeks ago and went on a few trips. Fridge is now cooling great. Even had ice start to form on cooling fins so can't ask for much more. Did have to straighten out the frame a bit from shipping but sounds like that is common. Other thing was I couldn't get my trailer's outside cover on. Needed to remove the gas burner mount and cut 1" off then weld it back together and good to go. Thanks for all the help. It's nice when you have to make a large money investment when troubleshooting to have someone else agree with your diagnostics. Randy Quote Link to comment Share on other sites More sharing options...
Kirk W Posted August 28, 2020 Report Share Posted August 28, 2020 Thanks for coming back to let us know! Now tip a cool one for me. 😊 Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
