Be careful with Propane
It doesn't seem like a little 1 lb disposable cylinder could do that much damage. At least not until you consider that it holds a bit less than 1 quart of liquid propane that expands to around 67 gallons of vapor if it's all released and my math is close. I hope they all recover ok!
For visualization purposes, 1# of propane contains approx. 20,909 BTU, 1# of TNT contains approx. 2,300 BTU, 1 stick of dynamite contains approx. 2,000 BTU. . You do the math. Propane is only  explosive between 2.1% and 9.5% mixture with air.
OK, time to stop this, Homeland Security may get interested.
Edited by Ray,IN
On 6/10/2020 at 11:17 AM, RV fan said:
Always use a solid cap for bottles stored inside and cap it tight. Check e-bay about $9.00 for 5 caps
5Pc BRASS Cylinder Cap 1LB Propane Bottle Cap
5Pc-BRASS-Cylinder-Cap-1LB-Propane-Bottle-Cap-Refill-Coupler-Protect-Disposable
Just be aware, you can still have an accidental release via the valve on the side. Keep propane outside! There's a reason the tank cabinet has an open floor.
4 hours ago, Dutch_12078 said:
Yes... Leakage issues usually occur after the cylinder has been in use though.
Yep, I  refilled one, sprayed it with soapy water = no bubbles. I  put it back in a basement bay, 3 days later smelled propane odorant, picked up the 1# cylinder, it was empty. The main valve had failed just sitting there. I quit refilling them for RVing use, now just for around the farm.
 Share
