docj Posted January 8, 2019 Report Share Posted January 8, 2019 8 hours ago, jbh said: Although low SNR would usually indicate to me the problem, while at Bushnell I could count on 20+ Mbps overnights with the same low SNR. Odd. The nearest Verizon tower is about five miles away, across a big lake and orange groves. Have you measured the download speed in the midnight to 5 am time period? If you're being limited because of network congestion, it shouldn't be evident at that time of day. The few slowdowns I've had with my prepaid plan have all been of limited duration. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
jbh Posted January 8, 2019 Report Share Posted January 8, 2019 I haven't measured it here, however I've been able to successfully record streaming HD TV all nights this past week between 01:00 and 05:00. Not remotely possible in daytime. -C&J- CG reviews & more - www.fugawetribe.com Link to comment Share on other sites More sharing options...
docj Posted January 8, 2019 Report Share Posted January 8, 2019 Do you have a phone that is also on the Verizon network? Have you thought to measure the phone's download speed at the same time you're having issues with the Jetpack? If the phone is on a postpaid plan, like most are, then that would help determine if the download speed issue is related to it being a prepaid plan or if the network is seriously overloaded, in general. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
docj Posted January 8, 2019 Report Share Posted January 8, 2019 I discovered an interesting behavior with my unlimited Jetpack plan today. This is the my monthly "anniversary" day and I have the plan set up for automatic payment in order to get the $5 discount. But, at around noon, the Jetpack stopped connecting to the internet even though neither its display or its online admin screen indicated there was an problem. I power-cycled it and it began working normally. My assumption is that the prepaid plans function as stand-alone "blocks" of usage and, therefore, there is no way to "slide" from one month's usage to the next without a reboot. I'd be interested to see if others experience this same issue. You'd probably never notice it if you turn off your Jetpack when not using it. I don't bother to do that; I have its charger set to cycle on and off so it doesn't overcharge the battery but I see no reason to shut off the device itself. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
Big5er Posted January 10, 2019 Report Share Posted January 10, 2019 Joel, mine has been on for 3 payment cycles and never been off yet. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
docj Posted January 10, 2019 Report Share Posted January 10, 2019 12 hours ago, Big5er said: Joel, mine has been on for 3 payment cycles and never been off yet. Interesting. My "issues" continued throughout the renewal day despite the fact that my online account stated that payment had been received for the next month, etc. What was odd was that when these outages occurred the Jetpack's display screen was totally normal and showed that I had an LTE connection. But none of the devices on my internal network could access the internet until I rebooted the Jetpack. Of course it could have been a local Verizon issue, but my phones didn't seem to be having any problems. I'll see if it reoccurs next month. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
Big5er Posted January 10, 2019 Report Share Posted January 10, 2019 7 hours ago, docj said: What was odd was that when these outages occurred the Jetpack's display screen was totally normal and showed that I had an LTE connection. Bad jetpack???? MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
docj Posted January 10, 2019 Report Share Posted January 10, 2019 10 minutes ago, Big5er said: Bad jetpack???? Please don't say that! It's out of warranty and I don't want to pay $200 for a new 8800! 😪 Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
chirakawa Posted January 10, 2019 Report Share Posted January 10, 2019 1 minute ago, docj said: Please don't say that! It's out of warranty and I don't want to pay $200 for a new 8800! 😪 I don't have one, but I've been reading on HoFo that some 8800's are flawed and drop signal inconsistently. Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
DanZemke Posted January 10, 2019 Report Share Posted January 10, 2019 docj, I also have a Verizon 8800 that occasionally stops providing data too. My symptoms appear to be like yours. No data provided to any connected device, but connection maintained with multiple devices. Rebooting the 8800 fixes it. I use my 8800 every day, and in my case, the failure to provide data is not correlated with my billing cycle. Alas, I have not been able to perceive a pattern. It smells to me like a code bug, rather than a hardware problem. Unfortunately, one that will be difficult to track down. I've resigned myself to accept required reboots a few times a month as a minor annoyance. Volvo 770, New Horizons Majestic and an upcoming Smart car Link to comment Share on other sites More sharing options...
docj Posted January 11, 2019 Report Share Posted January 11, 2019 1 hour ago, DanZemke said: I also have a Verizon 8800 that occasionally stops providing data too. My symptoms appear to be like yours. I have a 7730L, not an 8800, and the 7730's not supposed to have that problem! It never did before, but previously I didn't rely on it the way we do now. It's possible that the problem always existed but I wasn't trying to use ~150GB a month off of it. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
Darryl&Rita Posted January 11, 2019 Report Share Posted January 11, 2019 We only have one renewal under our belt, but our 7730 did the same thing on the last renewal. Mind you, we paid it in store, in cash, rather than auto-pay. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
edatlanta Posted January 11, 2019 Report Share Posted January 11, 2019 13 hours ago, docj said: Please don't say that! It's out of warranty and I don't want to pay $200 for a new 8800! 😪 I have 2 7730's post pay and 1 8800L prepay and the oldest 7730 quit picking up a good signal. 1-2 bars vs 4-5 (-114 eBm vs -80 dBm). This happened for the first time a couple of weeks ago and a reset fixed it. Yesterday it happened again and a reset did nothing so I contacted Verizon via chat. The agent did some checking on their end and had me reboot the 7730L a couple of times and called it bad. She asked if it was damaged at all and I said no it was pristine and it is. She offered a new 7730L for $150.00 vs the normal price since it was out of warranty. I asked about getting the 8800L for the same price and it took a few minutes, but it was approved and it is in the mail now. I have the 8800L on a prepay account and absolutely love it. It seems more robust then the 7730's that I have. Both of my 7730's have static IP's which will transfer to the replacement 8800L. There does seem to be some negotiation for a better deal for replacements, but I had to push a little. When you live and die with wireless internet you can't have too many jetpacks I guess. Ed KM4STL2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch2010 Jayco Designer 35RLTS, RV Flex Armor Roof Link to comment Share on other sites More sharing options...
docj Posted January 11, 2019 Report Share Posted January 11, 2019 30 minutes ago, edatlanta said: The agent did some checking on their end and had me reboot the 7730L a couple of times and called it bad. She asked if it was damaged at all and I said no it was pristine and it is. She offered a new 7730L for $150.00 vs the normal price since it was out of warranty. I asked about getting the 8800L for the same price and it took a few minutes, but it was approved and it is in the mail now. Thanks for the info. If I have to go that route I'll remember to ask for "the deal of the day!" 😀 Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
mkc Posted January 11, 2019 Report Share Posted January 11, 2019 Chris and Cherie have been tracking the 8800's drop out issue for a while now. If you are an rvmobileinternet.com member you can follow and contribute to the discussion in their forum. Link to comment Share on other sites More sharing options...
chindog Posted January 12, 2019 Report Share Posted January 12, 2019 For you guys with the 7730's that are having issues, it could be that the battery is going bad. I was having some problems with mine, and when I took the battery out, I could see it was slightly bulged out. I got a new battery, and the problems went away. The Verizon stores didn't have the batteries, but I found them at Walmart.com. Mike and Retha Hopkins 2014 Fleetwood Discovery 40G Link to comment Share on other sites More sharing options...
docj Posted January 12, 2019 Report Share Posted January 12, 2019 47 minutes ago, chindog said: For you guys with the 7730's that are having issues, it could be that the battery is going bad. My battery did go bad several months ago and I bought an OEM replacement on Amazon. The problems I reported all went away the day after the renewal "anniversary". I still think that had something to do with it. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
Darryl&Rita Posted January 12, 2019 Report Share Posted January 12, 2019 3 hours ago, chindog said: For you guys with the 7730's that are having issues, it could be that the battery is going bad. I was having some problems with mine, and when I took the battery out, I could see it was slightly bulged out. I got a new battery, and the problems went away. The Verizon stores didn't have the batteries, but I found them at Walmart.com. Brand new unit, brand new battery. Also, not using the battery, running off USB power supply. The battery will only be installed when we want to take the JetPack roving with us. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
dirtyboots Posted January 12, 2019 Report Share Posted January 12, 2019 For what it's worth... I also have been on the 'new' Verizon unlimited plan for 2 monthly cycles. The first time I can't say which came first, as the auto-pay did not activate, so I was just toast at 10:00 pm until I could get to a Verizon store the next day. Paid in cash and all was well. The next renewal, I had already paid the day before (at the store in cash) so was watching to be sure it was a smooth transition to the new month. Nope. As with others, the jetpack screen showed all was well....my computer didn't. I had no connection to internet. Shut it all down figuring another trip to the Verizon store. Next morning fired it up and it worked just like it should! Have no idea how long it took to get it's cycle arranged, but I'm thinking it's not a hardware issue. Will head into the Verizon store next week, but it's just a reseller, so not sure if they'll have any answers. Might be a couple weeks before I head back where there is a corporate store. Thanks to all who have given experiences in this thread. Link to comment Share on other sites More sharing options...
jbh Posted January 12, 2019 Report Share Posted January 12, 2019 Lately I've been doing the CG wifi thing since my 8800 gives a poor data rate at my location for whatever reason. Anyway, I checked it this morning with Speedtest and got about 100kbps download and 2.5mbps upload. If the problem was entirely low snr would this be possible? BTW, I've never had it shut off unexpectedly. -C&J- CG reviews & more - www.fugawetribe.com Link to comment Share on other sites More sharing options...
docj Posted January 12, 2019 Report Share Posted January 12, 2019 12 hours ago, Darryl&Rita said: Brand new unit, brand new battery. Also, not using the battery, running off USB power supply. The battery will only be installed when we want to take the JetPack roving with us. My 7730L was "very unhappy" when I tried running it without a battery. Did you employ any hacks to get it to operate without one? Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
Darryl&Rita Posted January 12, 2019 Report Share Posted January 12, 2019 22 minutes ago, docj said: My 7730L was "very unhappy" when I tried running it without a battery. Did you employ any hacks to get it to operate without one? Nope, plug and play. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
docj Posted January 12, 2019 Report Share Posted January 12, 2019 On 1/12/2019 at 11:28 AM, Darryl&Rita said: Nope, plug and play. Well, mine won't work without one and attached is a post from VZW customer support stating that it's not designed to work without one. Maybe the firmware was changed in more recent versions of the device. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
Darryl&Rita Posted January 12, 2019 Report Share Posted January 12, 2019 2 hours ago, docj said: Well, mine won't work without one and attached is a post from VZW customer support stating that it's not designed to work without one. Maybe the firmware was changed in more recent versions of the device. Could have even been dumb luck. I don't remember the sequence, whether it was running before I pulled the battery, or it was powered up on the cord. The next time we take it outside, I'll experiment with it. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Al F Posted January 14, 2019 Report Share Posted January 14, 2019 On 1/8/2019 at 2:41 PM, docj said: I discovered an interesting behavior with my unlimited Jetpack plan today. This is the my monthly "anniversary" day and I have the plan set up for automatic payment in order to get the $5 discount. But, at around noon, the Jetpack stopped connecting to the internet even though neither its display or its online admin screen indicated there was an problem. I power-cycled it and it began working normally. My assumption is that the prepaid plans function as stand-alone "blocks" of usage and, therefore, there is no way to "slide" from one month's usage to the next without a reboot. I'd be interested to see if others experience this same issue. You'd probably never notice it if you turn off your Jetpack when not using it. I don't bother to do that; I have its charger set to cycle on and off so it doesn't overcharge the battery but I see no reason to shut off the device itself. Yesterday (1/13/19) was my renewal day and in mid morning my 6620 jetpack started showing "no internet secured" on my laptop. Rebooting the jetpack and it would work for several minutes and then I would loose the internet. Rebooted 3 times and same thing. No messages or indication of a problem on the jetpack. Switched to my ph hotspot and then came back to the jetpack in a few hours and all worked OK. We'll see if this repeats next month. Al & Sharon 2006 Winnebago Journey 36G 2020 Chevy Colorado Toad San Antonio, TX http://downtheroadaroundthebend.blogspot.com/ Link to comment Share on other sites More sharing options...
