PaHunter Posted May 4, 2018 Report Share Posted May 4, 2018 Well today wired up the jackalopee, both sides, and then wired the rv plug, turned the truck on and no led's in the box are lit. Are they supposed to light ?? All connections were crimped in place and heat sealed. Not sure what I am missing ?? Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted May 4, 2018 Report Share Posted May 4, 2018 Did you plug the trailer in and try the lights or anything? Link to comment Share on other sites More sharing options...
PaHunter Posted May 4, 2018 Author Report Share Posted May 4, 2018 trailer is on the other side of the yard. Watched Gregg's video again, rechecked truck and low and behold, plug was not pushed in all the way. Crammed the plug all the way in and it seems to be working, the little led's are now lighting with the brakes and turn signals, Yea !!!! Link to comment Share on other sites More sharing options...
Av8r3400 Posted May 4, 2018 Report Share Posted May 4, 2018 Link to comment Share on other sites More sharing options...
Brad NSW Posted May 4, 2018 Report Share Posted May 4, 2018 Sounds like you have it hooked up right. Just installed my directlink and one way I could tell it was working with the Jackalopee was using the manual lever on the controller while the wife watched the brake LED. If it got brighter as you increased brake (wife looking) it is probably fully functional. Putting on Disc brakes on trailer this weekend and our setup should give us great braking control... Link to comment Share on other sites More sharing options...
PaHunter Posted May 5, 2018 Author Report Share Posted May 5, 2018 Today found me wiring up the direclink brake controller, pretty straight forward. Seems to be working, have to hook up to the trailer and do a light test. Need the hitch installed so I can test pull. Only thing left to do for wiring is to bring the backup light wire from the back of the tandem up to the jackalopee. Rain is threatening now and don't want to be in the middle when it hits. She is coming along, good thing, only 17 days left until camping trip. Link to comment Share on other sites More sharing options...
PaHunter Posted May 5, 2018 Author Report Share Posted May 5, 2018 Well directlink installed but not working correctly. It is showing OK on the screen. When I use the thumb activator, it shows the brakes being applied, hooked to trailer could hear brakes activate. When I hit the brakes, no brake activation and nothing showing on the controller. Not sure what I am missing, or maybe got a bad unit ? Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted May 5, 2018 Report Share Posted May 5, 2018 You are installing this on an HDT right? Does the truck have air pressure? Link to comment Share on other sites More sharing options...
PaHunter Posted May 5, 2018 Author Report Share Posted May 5, 2018 2 minutes ago, Alie&Jim's Carrilite said: You are installing this on an HDT right? Does the truck have air pressure? Yep, installing on our 2012 Volvo. Truck was aired up and running. We tried with it hooked to the trailer even. When we use the trigger to manually activate it works fine, can hear brakes engage on trailer. When we apply truck brakes, nothing. Brakes lights activate, but no bar and can not hear brakes activate. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted May 5, 2018 Report Share Posted May 5, 2018 I would recheck every connection and then call Direct Link tomorrow. Link to comment Share on other sites More sharing options...
Lance A Lott Posted May 5, 2018 Report Share Posted May 5, 2018 Were you moving? Link to comment Share on other sites More sharing options...
Nigel Posted May 5, 2018 Report Share Posted May 5, 2018 There is something called brake scale, what others call gain control. You will probably have to increase the setting if you have a large trailer. I am not sure how the Direct Link works, does it send power to the brakes if the truck is stationary? I believe it picks up info from the speed sensors among other parameters. Nigel Link to comment Share on other sites More sharing options...
PaHunter Posted May 5, 2018 Author Report Share Posted May 5, 2018 10 minutes ago, Lance A Lott said: Were you moving? No I was not moving, we do not have a hitch on the truck yet. But during his video, Gregg applied his brakes and it showed up on the display as a red bar. We have nothing. Link to comment Share on other sites More sharing options...
PaHunter Posted May 5, 2018 Author Report Share Posted May 5, 2018 22 minutes ago, Alie&Jim's Carrilite said: I would recheck every connection and then call Direct Link tomorrow. Have double checked, triple checked and plan on calling them tomorrow, although being Sunday not sure if anyone will be there. If not will call again Monday. Link to comment Share on other sites More sharing options...
DesertMiner Posted May 6, 2018 Report Share Posted May 6, 2018 Parking brake applied? Link to comment Share on other sites More sharing options...
PaHunter Posted May 6, 2018 Author Report Share Posted May 6, 2018 20 minutes ago, DesertMiner said: Parking brake applied? Yep, sure was. That did not occur to me. Link to comment Share on other sites More sharing options...
PaHunter Posted May 6, 2018 Author Report Share Posted May 6, 2018 So ran out to truck, fired it up. Put truck in drive, released parking brake and still nothing. I can hear the brake light led click on in the jackalopee, but no bar across screen. Manually bar to 100 no problem. Checked faults, none. On information screens showing temp, rpm, brake voltage when brakes applied. So far this group has been so very helpful. Just baffled here. Link to comment Share on other sites More sharing options...
Lance A Lott Posted May 6, 2018 Report Share Posted May 6, 2018 I cant move mine right now,the drive shaft is out being lengthend, but I will air it up tomorrow and see what happens. Link to comment Share on other sites More sharing options...
TreyandSusan Posted May 6, 2018 Report Share Posted May 6, 2018 The direclink has a number of settings for how the brakes work in various conditions. One of them has to do with what you want the trailer brakes to do when not moving. There is also a low speed setting. So, double check the manual menu options and your settings. Link to comment Share on other sites More sharing options...
Lance A Lott Posted May 6, 2018 Report Share Posted May 6, 2018 Air mine up and when I apply the service brake it says nc, for no conection. And of course as its in the shop no trailer to conect it to. Sorry I could not help you. Link to comment Share on other sites More sharing options...
Sculptor Posted May 6, 2018 Report Share Posted May 6, 2018 Hi PaHunter, I just hooked mine up this weekend also. Tomorrow I will be driving to pick up our camper. This will also be the first trial of the Directlink for me. I can't tell you what it's doing or not doing because we started up the truck, saw the OK and had to leave. No trailer at home to plug into and seem to have misplaced my new trailer plug tester. Sorry I'm no help today maybe tomorrow? Link to comment Share on other sites More sharing options...
PaHunter Posted May 6, 2018 Author Report Share Posted May 6, 2018 19 hours ago, TreyandSusan said: The direclink has a number of settings for how the brakes work in various conditions. One of them has to do with what you want the trailer brakes to do when not moving. There is also a low speed setting. So, double check the manual menu options and your settings. The stopped setting is on 10 percent and when i hit the brakes that lights up. Taking the truck to town tomorrow, so will see what it does at speed. Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted May 6, 2018 Report Share Posted May 6, 2018 21 hours ago, PaHunter said: So ran out to truck, fired it up. Put truck in drive, released parking brake and still nothing. I can hear the brake light led click on in the jackalopee, but no bar across screen. Manually bar to 100 no problem. Checked faults, none. On information screens showing temp, rpm, brake voltage when brakes applied. So far this group has been so very helpful. Just baffled here. If the truck is not moving the direct link does not read speed at trans and speed at the abs sensors no braking needed. Roger Link to comment Share on other sites More sharing options...
PaHunter Posted May 7, 2018 Author Report Share Posted May 7, 2018 1 hour ago, Hewhoknowslittle said: If the truck is not moving the direct link does not read speed at trans and speed at the abs sensors no braking needed. Roger Cool. Keeping my fingers crossed. Now it is just a matter of getting hitch mounted to the truck. Link to comment Share on other sites More sharing options...
