Lance A Lott Posted March 21, 2018 Report Share Posted March 21, 2018 What is the best way to air up with garage air? I have a 2012 Volvo thanks Link to comment Share on other sites More sharing options...
Quickthrotl Posted March 21, 2018 Report Share Posted March 21, 2018 if you have a gladhand for trailer brakes you can air it up that way, you will need to push in the trailer brake air valve in cab to get it to take air 2004 Volvo VNL 780 2017 Momentum 376TH 2007 Harley Davidson FLHTC 2009 Smart4two Link to comment Share on other sites More sharing options...
rickeieio Posted March 21, 2018 Report Share Posted March 21, 2018 There are several ways. Is there a Schrader valve on the air governor? That's simple, and will air up all tanks. Or, you an make up a glad hand with a disconnect fitting and air through that, if you still have glad hands on the truck. This works well for an air source when out traveling too. Connect to the red gland hand. You can put a quick disconnect directly on your first air tank. This might be difficult to access, depending on how your tanks are situated. In any case, make up a male/male disconnect, and carry it in your air repair box. Eventually, you will need it. KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
SuiteSuccess Posted March 21, 2018 Report Share Posted March 21, 2018 Two ways. Air governor may have a Schrader valve on it which can be used. Best to have an air dryer on your compressor to keep moisture out of the system. Or you can build one of these. You can trace a line from your truck compressor that is pre air dryer and has a valve like a the low pressure side of an air conditioner line. Just be sure and trace the line to be sure it is air and not a refrigerant line. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Lance A Lott Posted March 21, 2018 Author Report Share Posted March 21, 2018 Thanks for the quick response. I don't have glad hands on the truck but the empty lines are there. I will probably put a quick conect on the tank. I was aware of that option but not which tank to use. Is the regular shop aide dryer good enough or do I need a better one? Link to comment Share on other sites More sharing options...
Quickthrotl Posted March 21, 2018 Report Share Posted March 21, 2018 it should be fine, i personally wouldn't worry about it 2004 Volvo VNL 780 2017 Momentum 376TH 2007 Harley Davidson FLHTC 2009 Smart4two Link to comment Share on other sites More sharing options...
bigredhdt Posted April 6, 2018 Report Share Posted April 6, 2018 What is the specification on the fitting that goes to the compressor line? Link to comment Share on other sites More sharing options...
SuiteSuccess Posted April 6, 2018 Report Share Posted April 6, 2018 Low pressure air conditioner line fitting. Amazon has paired high (blue )/ low(red)for about $19. May have the colors reversed but if you buy the pair the red should fit. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
DesertMiner Posted April 6, 2018 Report Share Posted April 6, 2018 Opps Link to comment Share on other sites More sharing options...
jenandjon Posted April 7, 2018 Report Share Posted April 7, 2018 When I removed the service lines for the trailer I just put a quick coupler in. If need air I just hook up an air hose and push the red button in on the dash. On some of our other trucks I installed a quick coupler into one of the air tanks. I have also hooked the glad hands together on 2 trucks to get air in one that was broken down. Most of us have the glad hands removed so that most likely is not an option. Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted April 7, 2018 Report Share Posted April 7, 2018 I have a T fitting just before the air dryer. One side comes from the compressor, the other goes into a side box on the bed to a quick connect that matches my shop airlines. That way I add air thru the dryer to prevent problems later. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
GlennWest Posted April 8, 2018 Report Share Posted April 8, 2018 I have Bluedot on Teton so glad hands in use. I cap them off when not towing. Quick disconnect on red hand. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
