NoDirectionHome Posted May 29, 2017 Report Share Posted May 29, 2017 http://i.imgur.com/fFynFM5l.jpg "There are No Experts, Do the Math!" 2014 Freightliner Cascadia DD16 600hp 1850ft-lb 18spd 3.31 260"wb SpaceCraft S-470 SKP #131740 Link to comment Share on other sites More sharing options...
MrSeas Posted May 30, 2017 Report Share Posted May 30, 2017 Nice! Link to comment Share on other sites More sharing options...
rickeieio Posted May 30, 2017 Report Share Posted May 30, 2017 Cool, but I wouldn't want to drive it. Those old cabs are small, and noisy. KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
SuiteSuccess Posted May 30, 2017 Report Share Posted May 30, 2017 Saw this in Crossville, TN 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Pete Kildow Posted May 31, 2017 Report Share Posted May 31, 2017 There's an old mack not far from me. It has the old coffin Sleeper on back. A guy was looking at it last week. And he was looking at restoring it. And pulling an old Air stream with it. No way in the world would i want to shift that old 5 and 4 trans and hear that old Dog bark for hours. Pete Link to comment Share on other sites More sharing options...
noteven Posted June 1, 2017 Report Share Posted June 1, 2017 1953 Mack LT with a suprise under the hood: https://www.youtube.com/watch?v=VKJLMoJ8Ctc "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Pete Kildow Posted June 2, 2017 Report Share Posted June 2, 2017 That KT cummins should make that old gal scream. That stock trailer should be blown clean if he gets it in high gear. Pete Link to comment Share on other sites More sharing options...
noteven Posted June 2, 2017 Report Share Posted June 2, 2017 If I remember KTA's are kinda heavy. But they can pull on stuff. And they have their own exhaust note they say. Note how the KW Airglide suspension puts the power to the ground without a bunch of jacking up and down and fuss and bother: https://www.youtube.com/watch?v=UZy_v-Vl15I "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
CampClownPete Posted June 2, 2017 Report Share Posted June 2, 2017 I spoke to a lot of folks when I, at one time, wanted to buy a vintage truck and turn it into a Truck Rod. They told me that quite a few of them would just ditch the old stock wore out (too expensive to repair) and run built up Cummins 5.9 engines. I ended up not going that route so I never compared hp/torque between those stock engines and the built 5.9's. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted June 2, 2017 Report Share Posted June 2, 2017 A built 5.9 can turn 6-800hp and 1000fttq with ease.....cam, valve springs, injectors, turbo, tuning, if there is no environmental adaptation...EGR's, DEF, Catalytic converters etc, they run pretty nice. Look at the marine versions. 3000 RPM at max loading, I've seen them with 12-15000 (thousand) hours on them in trawlers. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
I'mdonewiththis forum Posted June 4, 2017 Report Share Posted June 4, 2017 If you want to use a 5.9 then the least expensive to get power out of is the old 12 valve. I had to buy six injectors to get mine where it is. I am at 365HP and 833LB/FT at the rear wheels. It has been a few years since the injectors, but the cost me $360 INSTALLED!! Link to comment Share on other sites More sharing options...
