singling a 630/610
GlennWest
Looking at trucks and making plans. I really don't see where I need a large condo. Some times we are forced to get in rather old rv parks that were built before slide out and long units. In Blessings TX we were challenged with the crew cab long bed dually. I am considering a 610/630 singled and haul a Smart. These units don't look odd singled, at least the ones I saw didn't. What are your thoughts on this.
My past HDT was a 610 factory single axle..
Perfect for us, and loved it.
When I lived in WV we took it for overnight camping in areas similar to what you are describing...We had the bunk beds and found it totally adequate for our needs, and I am 6'5".
A great all around HDT in my opinion.
Cheers, and good luck,
Bob
Bob
Would love to find one factory single. Probably got a heavier axle also. Cool
We are singled short at 186. When we rebuild our bed, I'm planning on moving the axle back to the "Mid" position, or 26" back. This puts us at 212" which I think will better balance our rig. We have the M-11 Cummins which is a lighter engine to begin with. If I put our pin weight (4800lbs), 6 feet begin the rear axle it will lighten the front even more, even with a smart car behind the cab. So with having the axle moved to mid, we should balance better.
I am trying to figure out what wheel base to buy so I can simply move rear axle to front axle position.
Standard spread tandem sets are on 52" centers, Glenn. Once you figure how much wheelbase you'd like to have for what you're planning to do, if you find a truck that has a WB that's 26" longer than your "target" wheelbase, you'll be exactly where you want to be when singled short.
I have a T2000 singled short. I am in the 180 something wheelbase range (I forget exactly and the truck is in for its annual service so I can't go measure it). My hitch is just behind the axle at the rear of the bed. My bed is fairly short (not big enough for a Smart). My HDT is about 18 inches or so longer than my Chevy long bed dually was. I am about 8 feet longer overall with my trailer attached than I was with my Chevy (because of the hitch placement and the extra length of the truck). I find I can get into much tighter spots now than I could with the Chevy. Sites that used to take multiple tries to get into, now can be gotten into in one try. This is because of the hitch being at the back of the truck instead of over the axle and because of the much sharper front wheel cut. I wouldn't worry so much about the tight campgrounds.
thank you. I sorta figured that from other reading also. Another big problem in that park was using my 3500 for daily work commute. Getting out of our spot was several back and forth moves before leaving. I could park the HDT out of the way. The Smart would be simple.
If the truck has a heavy N-14 Cummins in it, can singling short cause a front axle overload? I am asking about the 61" cab. There is considerable deck space behind cab before front tandem. I have seen 610 with a Smart and car wheel was in line with single short axle truck. So lots of this weight on front axle.
My 610 was singled short at 182". That is about as short as you can get a 610/630. It would carry a MC but not a smart. I needed a minimum of 16" more deck to carry a smart. Rather than invest in that truck and rebuild the bed I bought another truck. On a 610 class truck I'd be wanting something over 200" to carry a smart. And you do NOT want to just single long because that will tend to bias weight (in most cases) to the front axle when you have deck cargo. There is a spreadsheet somewhere in the Resource Guide that will help you calculate axle loading with various scenarios.
I ran an ISM in my 610 (a baby engine) and was nowhere near front axle loading. With a high displacement engine you should do the calulations carefully, because you "can" get into an overload situation in some cases.
My 610 was an older (2001) ex FedEx truck that was owned and maintained by Watkins Motor Freight.
It had an N14 Cummins and was factory singled at ~192 or so if I remember correctly.
Very nice set up, and really perfect for what I wanted. Most all of the Watkins trucks were spec'd close to the same.
They are still around, but getting harder to find.
I hauled my Harley on the back and did not have front axle weight problems, but was close.
Cheers,
Bob
Hi Glenn,
Vonda started life as a Canadian steel hauler so she is now in her retirement years. I had the singling done before I took possession. Rick Lacombe brokered the deal and handled everything. My 2004 630 had the front axle removed and the rear axle moved to the front position. I did not shorten the frame and just built the bed around the original frame length. I could hold a dance on my bed.
One other thing. I have a 14.6K front axle so I have no problem with to much weight up front when we singled.
Brad
Brad, I have always said that your truck just doesn't look like it was singled "short". You are at 218 singled "short" and I am at 226 singled "mid".
I understand that trucks are spec'ed different and I think Vonda was a long truck to begin with. Maybe we need to pull some tape on trucks this year at Hutch to see how much variance other "short" and "mid" trucks have from BOC or something?
Maybe the term " singled short" or "mid" shouldn't be used so much as a designator for length but rather a reference to the method/position used to single?? Lord knows I am not a bed builder and am making my conclusion based on looks, but I have seen some short "short" trucks and yours isn't one of them. I mean, look at Hdonlybob's "short" truck in the pictures above, he is 26" shorter than yours yet I am singled "mid" and am only 8" longer than you. If our measurements are all correct, you are much closer in size to my "mid" position than his "short".
