SWharton Posted May 16, 2015 Report Share Posted May 16, 2015 I know we have discussed tires many times but couldn't find any discussions when I searched on tires. When in storage or parked for a lengthy time we always put wood under our tires. Wood is heavy and takes up a lot of space. Has anyone tried the heavy duty "commercial" mats that are used in shops etc? I would think they would work just as well. One concern I would have is the rock(s) poking through the rubber due to the weight of the MH or trailer. Comments? Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted May 16, 2015 Report Share Posted May 16, 2015 When we are in Retama Village for the winter, we put flexible cutting sheets under the wheels. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
SWharton Posted May 16, 2015 Author Report Share Posted May 16, 2015 Any problems with the rocks popping through the sheets? We tried place mats years ago with our 5th wheel and the rocks came through. Now we are getting a motor home which weighs a lot more but would prefer not having to haul wood. Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted May 16, 2015 Report Share Posted May 16, 2015 Most of the weight is on the leveler system. Sometimes some of the wheels are off the ground Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
Kirk W Posted May 16, 2015 Report Share Posted May 16, 2015 There are several things which the material under the RV tires should accomplish. First is that you want the tires such that any moisture that collects will drain away from the tire and not allow the tire to sit with the bottom footprint wet all/most of the time. For that reason it is good if the pad raises the tire just enough to be above the immediate area surface and not compress into a low point under the tire. The other purpose of the pad is to prevent contact with any kind of chemical that could react with tire compounds. Concrete RV pads look to be the perfect place for storage but concrete is actually porous in nature and frequently a tire sitting on it will constantly be damp under the footprint. In addition, concrete is one of those chemical compounds that will leach some harmful chemicals into contact with the tire so it needs to be isolated from it. I really don't like wood for tire pads unless the wood is sealed on all sides to prevent it absorbing moisture. A cheap cutting board or some type of plastic pad is a much better answer. If parked on a raised, concrete pad then all that is really needed is a plastic sheeting material to isolate the tire from the concrete compounds. If sitting on a gravel pad, I prefer to have some type of plank or such under the tire to raise it slightly, just to be sure of good drainage. It is also generally a good thing to cover the tires to prevent direct sun on them and if possible even bag them in some form to prevent ozone contact, although I have not done that with mounted tires. I would never park an RV for a long term with any of the wheels completely off of the ground unless they are so due to supports under the axles so that some weight still rests on the suspension. If you do lift one or more wheels, be very careful that you do not apply a twisting pressure to the frame of your RV. I have seen trailers stored for long periods by blocking up the axles to lift the tires and that is probably a good thing. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
AFchap Posted May 16, 2015 Report Share Posted May 16, 2015 Recycled rubber horse-stall mats are my current choice. One side is grooved which helps water run away. I cut them to size with a tile knife. Paul (KE5LXU), former fulltimer, now sometimer... '03 Winnebago Ultimate Advantage 40E '05 Honda Odyssey Escapees, FMCA, WIT, SMART http://www.pjrider.com Link to comment Share on other sites More sharing options...
SWharton Posted May 16, 2015 Author Report Share Posted May 16, 2015 AFChap, This is intriguing. I know Tractor Supply has new ones but where do you find recycled ones. Thanks Link to comment Share on other sites More sharing options...
AFchap Posted May 16, 2015 Report Share Posted May 16, 2015 Recycled rubber ...not recycled mats. The mats Tractor supply sells are made with reycled rubber. Paul (KE5LXU), former fulltimer, now sometimer... '03 Winnebago Ultimate Advantage 40E '05 Honda Odyssey Escapees, FMCA, WIT, SMART http://www.pjrider.com Link to comment Share on other sites More sharing options...
bobsallyh Posted May 16, 2015 Report Share Posted May 16, 2015 You can also check at a business that uses conveyer belts or installs them. I was going thru Idaho Falls, ID. a number of years ago and saw a sign for conveyer belts on Yellowstone Highway. Stopped in and asked if they had any old or used belts. The guy asked how wide and long I needed. He then pointed to a pile and said "help yourself". I picked u more than I needed at the time and glad I did. Found numerous uses for smaller pieces. Link to comment Share on other sites More sharing options...
Jimalberta Posted May 16, 2015 Report Share Posted May 16, 2015 Seeing as tires age out long before they wear out or deteriorate from the ground.....I dont really use anything. I suppose if I were near an acid factory I might but I just refuse to worry myself with a lot of what ifs that never come about. <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
bockofma Posted May 17, 2015 Report Share Posted May 17, 2015 Good evening. I, too, like AFChap, use recycled rubber horse-stall mats. Been using them for several years. They are easy to store, and if I'm going to be more than a few days at a location be it paved or not, I always use them. Regards, Michael 2007 Volvo VNL 670 2007 NuWa HitchHiker Champagne Link to comment Share on other sites More sharing options...
SWharton Posted May 17, 2015 Author Report Share Posted May 17, 2015 Thanks everyone. I am going to look into the horse stall mats. Link to comment Share on other sites More sharing options...
griffinmike Posted May 17, 2015 Report Share Posted May 17, 2015 ? Wandering1 Link to comment Share on other sites More sharing options...
griffinmike Posted May 17, 2015 Report Share Posted May 17, 2015 Never had a problem with my tires when storing my 5er on grass, dirt, gravel, rocks, and cement for months at a time. It would be interesting to see what the tire manufacturer recommends, let us know. Wandering1 Link to comment Share on other sites More sharing options...
SWharton Posted May 17, 2015 Author Report Share Posted May 17, 2015 Quote from Michelin RV Tire article in Motorhome mag: Also, some storage surfaces can cause tires to age faster. That’s why Michelin recommends placing a barrier (cardboard, plastic or plywood) between the tire and the storage surface. Entire Article: http://www.michelinrvtires.com/assets/pdf/MotorHomeTireArticle.pdf Link to comment Share on other sites More sharing options...
Ray,IN Posted May 17, 2015 Report Share Posted May 17, 2015 Quote from Michelin RV Tire article in Motorhome mag: Also, some storage surfaces can cause tires to age faster. That’s why Michelin recommends placing a barrier (cardboard, plastic or plywood) between the tire and the storage surface. Entire Article: http://www.michelinrvtires.com/assets/pdf/MotorHomeTireArticle.pdf Well, he pretty much blew the moisture/water harming tires away with that statement. Seeing as tires age out long before they wear out or deteriorate from the ground.....I dont really use anything. I suppose if I were near an acid factory I might but I just refuse to worry myself with a lot of what ifs that never come about. You reminded me of my farm equipment tires. It sits parked in a barn with a dirt floor all winter, and when unused other times. Now my front tractor tires are only 40 years old this year, so perhaps they may be damaged from sitting on the dirt. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
RV_ Posted May 17, 2015 Report Share Posted May 17, 2015 I won't run tires much more than five years old and inspect them regularly. Tires oxidize from air outside them too, not just from UX and moisture. When last we RVd fulltime there were no pressure sensors for fiver tires and I believe that may have changed too in 12 years. But that is another topic. I store mine now on 2X10X8 boards. They are not pressure treated because of interaction probabilities with the tire composition. But I believe I'll drill some strategically placed holes for drainage. What is useful is the idea of storage because I am about to build an RV storage and use pull through RV pad complete with sewage, water, electric pedestal and OTA TV cable with a steel carport cover wide enough to open the slide so we can use it for guests if needed. Now I'm thinking French drains where the tires will sit on steel grates which I can tie into the sewer line. Good topic. RV/Derekhttp://www.rvroadie.com Email on the bottom of my website page.Retired AF 1971-1998 When you see a worthy man, endeavor to emulate him. When you see an unworthy man, look inside yourself. - Confucius “Those who can make you believe absurdities, can make you commit atrocities.” ... Voltaire Link to comment Share on other sites More sharing options...
FastEagle Posted May 18, 2015 Report Share Posted May 18, 2015 This is a very good PDF from the RMA about tires. You don't have to read all of it. Chapter four is the RV section. Tire blocking is on page 60. http://www.mcgeecompany.com/wp-content/uploads/2010/12/complete-manual.pdf FastEagle Everest 363K 38'Dodge DRW 3500 Turbo DieselUSN Retired - DOD Retired Link to comment Share on other sites More sharing options...
SWharton Posted May 18, 2015 Author Report Share Posted May 18, 2015 A blowout on farm equipment is an annoyance, a blowout at 60-70 miles per hour is potential death. We worry about our tires and do everything possible to protect ourselves from a tire disaster(having had one in the past). We change our tires every 6 years, protect them from the sun, have them off the ground when necessary, proper inflation, using the TPMS when on the road and check the pressure every day before starting off. . Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted May 18, 2015 Report Share Posted May 18, 2015 My first car cost $85 and then I put $220 worth of tires on it. Those few pieces of rubber can radically change my life and there is conserving on what I do to insure they are in great shape. Like SWarton, I take those step to protect my tires, and I only buy upper grade US Made tires. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
SWharton Posted May 18, 2015 Author Report Share Posted May 18, 2015 Yes, US tires only(though Toyos seem OK)................No China Bombs(these seem to be the worst)....... Link to comment Share on other sites More sharing options...
Kirk W Posted May 18, 2015 Report Share Posted May 18, 2015 You reminded me of my farm equipment tires. It sits parked in a barn with a dirt floor all winter, and when unused other times. Now my front tractor tires are only 40 years old this year, so perhaps they may be damaged from sitting on the dirt. And how often do you drive your farm equipment down the highway at speeds in excess of 50 mph, with all of your family on board? How many of them are belted, radial tires like we run on most RVs? Not exactly the same thing.......... Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Biker56 Posted May 18, 2015 Report Share Posted May 18, 2015 For long term storage Good Year recommend to add 20% more air to the tires then usually carried for the weight. Don't put in more then the wheels are rated for. I have done that for the last 10 winters on my present G670 tires. They are going to be replaced this week. Waiting on 2 more to come in. The 4 they have was made in Jan 15. They still look good no cracks anywhere on them. And they just made their last 1,347 mile trip to the same location they started out at 10 years ago. Only bad thing is they cost $1,054.21 more out the door, then they did 10 years ago. Full Time since Oct. 199999 Discovery 34Q DP | ISBDatastorm | VMSpc | Co-Pilot Live | Pressure Pro2014 MKS Twin Turbo V6 365 HP Toad Link to comment Share on other sites More sharing options...
Ray,IN Posted May 19, 2015 Report Share Posted May 19, 2015 And how often do you drive your farm equipment down the highway at speeds in excess of 50 mph, with all of your family on board? How many of them are belted, radial tires like we run on most RVs? Not exactly the same thing.......... Only thing similar to automobile or truck tires is, they too are rubber and contain air. That was tongue in cheek, guess the smily didn't convey that. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
mptjelgin Posted May 19, 2015 Report Share Posted May 19, 2015 When we park for a volunteer job (3 - 5 months) we put plastic cutting boards under each tire. They are about 1/2" thick and are slightly larger than the footprint of the tire. They provide an impermeable, flat surface and are easy to carry. We used to place vinyl tire covers over the tires as well, but we had a couple of occasions where something (mice?) carried grass and other nesting materials into the lower part of the covers. And our slides do a pretty complete job of shading the tires, so we've done away with the tire covers. Mark & Teri 2021 Grand Designs Imagine 2500RL, 2019 Ford F-350 Mark & Teri's Travels Link to comment Share on other sites More sharing options...
