The Travelers Posted February 11 Report Share Posted February 11 Hi, do you know the name of a good company that sells LED bulbs for RV's? We're looking for the small pucks for the kitchen and others. We'll pay for anything that will not blink. Thanks The Travelers Quote Link to comment Share on other sites More sharing options...
Jaydrvr Posted February 11 Report Share Posted February 11 You might try this site. Jay https://www.google.com/aclk?sa=l&ai=DChcSEwi1l4f1uaKEAxXln1oFHZ8RAkYYABAAGgJ2dQ&gclid=CjwKCAiA2pyuBhBKEiwApLaIOwuz7H9h3lA51Q50W8-FWGAooRBXBOLqVHPd9vTFUqIT7yrh1RqiARoCIckQAvD_BwE&sig=AOD64_1M5BjneTynnDjCoNnNehOJVsAf3w&ved=2ahUKEwiG7_70uaKEAxW5QzABHQMoD8AQ0Qx6BAgLEAE&adurl= Quote Link to comment Share on other sites More sharing options...
Kirk W Posted February 11 Report Share Posted February 11 11 hours ago, The Travelers said: We'll pay for anything that will not blink. You need to tell us more about the problem of blinking. What exactly are the existing light assemblies and what sort of LEDs are you using that blinks? Do the lights work fine with the original bulbs and what type of bulbs are they? Have you checked the 12V supply at the sockets? Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Darryl&Rita Posted February 11 Report Share Posted February 11 SuperBrightLEDs.com Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Second Chance Posted February 11 Report Share Posted February 11 A little confused, here... you ask about "bulbs" and then mention "pucks." These are two different items. Rob Quote 2012 F350 CC LB DRW 6.7 2020 Solitude 310GK-R, MORryde IS, disc brakes, solar, DP windows Full-time since 8/2015 Link to comment Share on other sites More sharing options...
Chalkie Posted February 11 Report Share Posted February 11 24 minutes ago, Darryl&Rita said: SuperBrightLEDs.com I second this. You will pay a slight premium but they are worth it. We also on one RV replaced the pucks entirely with new fixtures where the LED is integral to the puck. We got them from Amazon. Facon 4.5Inch LED RV Puck Light Quote Link to comment Share on other sites More sharing options...
Danfreda1 Posted February 11 Report Share Posted February 11 I’m wondering if the blinking is when they are off and when something like the water heater or furnace kick on they get a blink that is dim. 12 volt and led light. Someone explained it to me before but I couldn’t repeat it without getting it mixed up. Ours do it too but you can’t see it during the day it’s only when I’m awake at night and all the lights are off. Has something to do with the negative side and a higher power draw turning on. If they just replace the lights I would think they will still blink. Quote Link to comment Share on other sites More sharing options...
jbh Posted February 11 Report Share Posted February 11 Blinking leds are often caused by low voltage, so check that first. Quote -C&J- CG reviews & more - www.fugawetribe.com Link to comment Share on other sites More sharing options...
Second Chance Posted February 11 Report Share Posted February 11 1 hour ago, jbh said: Blinking leds are often caused by low voltage, so check that first. And just as often by failed, poor quality ICs on the LED circuit board. We had to replace almost all of the LED ceiling puck lights in our rig early on due to blinking (voltage was fine per multimeter). I replaced the cheap OEM pucks with better quality ones and haven't had an issue since. Rob Quote 2012 F350 CC LB DRW 6.7 2020 Solitude 310GK-R, MORryde IS, disc brakes, solar, DP windows Full-time since 8/2015 Link to comment Share on other sites More sharing options...
jimnlin Posted February 12 Report Share Posted February 12 We have used M4LED.com for replacement of all non led's in our 1998 HH. Well pleased with service, support and quality. Jim Quote Link to comment Share on other sites More sharing options...
bthomforde Posted February 12 Report Share Posted February 12 I've had great luck with this guy. https://www.cabinbright.com/ Quote 2017 Allegro Bus 45OPP Link to comment Share on other sites More sharing options...
Ray,IN Posted February 13 Report Share Posted February 13 (edited) i bought all my LED "bulbs" from Amazon, yes they are cheap, a dozen will cost what 2 or 3 name brands cost. I replaced every incandescent bulb ( 56) plus entire LED stop light fixtures, with an LED about 5 years ago, so far 2 have failed, but since i bought by the dozen i have plenty of spares in my onboard toolbox. I seem to recall I spent a total of $93 to replace everything but headlamps. I don't drive at night so no reason to buy LED headlamps, the rear docking lights were not bright enough nor the correct color, making them useless, so I returned to the OEM headlamp bulbs in the rear docking lights. Edited February 13 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
