Wrknrvr Posted August 24, 2023 Author Report Share Posted August 24, 2023 This a photo of our fuel tank today. We have not added fuel or driven the truck since we arrived in Montana. Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 24, 2023 Author Report Share Posted August 24, 2023 Looking around the tank and the bottom looks like it did before the algae appeared. Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 26, 2023 Author Report Share Posted August 26, 2023 Today I counted my used fuel filters. 20 in all. So that was 10 times of changing the filters. I probably change at least 3 sets that were not needed. And they were all at very inconvenient locations. But we made it to Montana. That is what counts. Safe Travels to all, Vern Quote Link to comment Share on other sites More sharing options...
mike5511 Posted August 27, 2023 Report Share Posted August 27, 2023 8 hours ago, Wrknrvr said: Today I counted my used fuel filters. 20 in all. So that was 10 times of changing the filters. I probably change at least 3 sets that were not needed. And they were all at very inconvenient locations. But we made it to Montana. That is what counts. Safe Travels to all, Vern So, what is your plan going forward? What fuel additives you plan to use? I have a 98 Cummins. I use the Power Service in the silver bottle every time I fill up. I also use some brand of biocide when I know the fuel is going to sit in the tanks for an extended time. So far, so good. I haven't had any problems with my fuel except once. It wasn't really a fuel problem per se. I left Arkansas and headed west to Oregon. Every TA or Petro (big fan of the TSD fuel card) I bought fuel at, was bio diesel. Bio diesel is a really good cleaner and an excellent lubricant. By the time I started back east towards home, the bio diesel had cleaned my fuel system very well. My fuel filters stopped up with little granules that looked like pepper. The filters were new when I left home. Luckily I had made it into Reno when that happened and I drove to a dealer and bought new filters and changed them out in the parking lot. Needless to say, I peer down into my tanks often now and haven't had any more problems sense. But, I am a bit paranoid about having fuel problems after that experience. Following your thread hasn't help that paranoia at all!! Thus my question of your plan going forward to avoid further issues. What I do now, as stated above, is what I learned from somebody online that had retired from the refinery industry. I'm not a full timer. My truck sits thru the winter. But, even so, doing what I mentioned above has worked well for me so far. Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 27, 2023 Author Report Share Posted August 27, 2023 I am curious? Does 0 degrees temperature kill algae. Could just wait for that to happen. So I do have some of that algicide leftover from the trip. I may add that next weekend and get it mixed in for a day or two. Then take the truck for ride somewhere. I will be on the lookout for that crap, every time I can look into the tanks. I think that pumping the treatment through the fuel system may have helped eliminate that algae. Even eliminated some fuel leaks plugging stuff. Not sure how to word that subject. Sure makes ya wonder if it will bite again. Quote Link to comment Share on other sites More sharing options...
rickeieio Posted August 28, 2023 Report Share Posted August 28, 2023 In my 50+ years of owning/operating diesel equipment, I've experienced algae 3 times. First two were in a tractor that had been using nothing but treated ( by us) fuel. Can't remember on the third. This from small tractors to large 4wd and harvesters with 250 gal. capacity. But, all my equipment has sat for many months at a time with less than 1/2 tank, usually over winter when the worst condensation should occur. Never any appreciable water in the filters. Therefore, my thought is, why bother? My old fuel supplier said all his fuel was treated, so don't be double dosing. Now I'm down to just 4 diesels. Less to worry about. Like it says on the fuel cap of many old tractors, "Buy clean fuel. Keep it clean." BTW Vern, my cholesterol and sodium levels were getting out of hand, so I switched to watermelon. 😁 Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio@yahoo.com Link to comment Share on other sites More sharing options...
SuiteSuccess Posted August 28, 2023 Report Share Posted August 28, 2023 Cold will inhibit the growth of the algae but will not kill it. Just goes dormant until sunlight. There’s algae and bacteria present in the polar ice. Remember though, the “slime” is a combination of BACTERIA & ALGAE and it grows mostly at the diesel water interface. I have the Davco and can periodically drain off any accumulated water but that doesn’t help with any water that may be sitting in the tank. I trust Rick’s opinion on most things but for me a $30 bottle of biocide is cheap insurance against what Vern went through. https://askabiologist.asu.edu/explore/frozen-life#:~:text=The Arctic ecosystem is home,large amount of food available. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
rickeieio Posted August 28, 2023 Report Share Posted August 28, 2023 Carl, you bring up an observation I missed. Indeed, lack of water in the filter is not a good indicator that there's no water in the tank. Take a peek once in a while to be sure. Most of our farm equipment has a drain at the low point in the tank, where we can crack it a bit and see what comes out. Our trucks do not. And if you're worried about algae, sure, add some biocide occasionally. It won't break the bank. My point is, it's pretty unlikely that any of us will ever run into this problem. But never say never. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio@yahoo.com Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 28, 2023 Author Report Share Posted August 28, 2023 When I say pumping treatment through the fuel system. Along with the recirculating of fuel in The tanks for hours with treatment in it. I pumped that same treated fuel through the fuel lines up to the fuel pump on the engine. I used a small pump that would pump like 5 gallons a hour. That way the treatment was through both filters and all the suction sides supply lines. Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted August 28, 2023 Report Share Posted August 28, 2023 Geography is interesting. Walk inside any average petro stop around here, and the fuel additive shelf stock is 99% anti-gel related. Most stores don't even stock bio-cide/algicide. There's simply no demand for it. Winter Relative Humidity levels in the teens will do that for you. Of course, beside the till in these businesses is a collection of up to a dozen varieties of lip/hand care. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 28, 2023 Author Report Share Posted August 28, 2023 I was around well drilling equipment for 30 years. I had heard of the problem before. Just never experienced it before. Looking back the fuel tanks should have been topped off before parking. And being in South Carolina, it should of had treatment in it. More mini series are being thought of. They could have something to do with our adventure this year. Switching to watermelon is a good idea. Just leave the salt off The melon. Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted August 28, 2023 Report Share Posted August 28, 2023 1 minute ago, Wrknrvr said: Switching to watermelon is a good idea. Just leave the salt off The melon. Haven't got the bacon to work with watermelon. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 28, 2023 Author Report Share Posted August 28, 2023 What happens to the bacon. Does it just slide off. Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 28, 2023 Author Report Share Posted August 28, 2023 Darryl got me to thinking about fuel treatment. I will check in local stores to see if they have any on there shelves. Quote Link to comment Share on other sites More sharing options...
SuiteSuccess Posted August 29, 2023 Report Share Posted August 29, 2023 22 hours ago, Wrknrvr said: Darryl got me to thinking about fuel treatment. I will check in local stores to see if they have any on their shelves. Take a look at this product to consider for your arsenal. https://petroleumservicecompany.com/power-service-clear-diesel/?sku=9264-06&utm_source=google&utm_medium=cpc&utm_term=&utm_campaign=&gclid=CjwKCAjwrranBhAEEiwAzbhNtXeHYs9CoiZq7h2I122guuRq1-wAJbRZYBU0k4OIs75DCBLZ-C-KuxoCuhcQAvD_BwE Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 29, 2023 Author Report Share Posted August 29, 2023 Yesterday I stopped at the local Walmart. Yes they did have several different fuel treatments. Including the one you posted. That is one of there products that I have been using. Thanks for that information. Quote Link to comment Share on other sites More sharing options...
lockmup68 Posted August 29, 2023 Report Share Posted August 29, 2023 Where in Montana, we've been there since June, just left. West of Missoula. Quote 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 30, 2023 Author Report Share Posted August 30, 2023 Kalispell Montana Quote Link to comment Share on other sites More sharing options...
