Jinx & Wayne Posted November 14, 2020 Report Share Posted November 14, 2020 New problem cropped up two days ago. Water flow in the kitchen sink began to fade. Today we arrived in Bushnell and the kitchen is a trickle. Pressure at CG faucet is normal. Bathroom flow is good. Shower flow is good. There are no visible kinks in the line to the kitchen. I'm assuming there is a blockage in the kitchen line. Does anyone have suggestions for troubleshooting this one? Quote Jinx and Wayne 2006 Carriage Carri-Lite 36KSQ Link to comment Share on other sites More sharing options...
Al F Posted November 14, 2020 Report Share Posted November 14, 2020 2 minutes ago, Jinx & Wayne said: New problem cropped up two days ago. Water flow in the kitchen sink began to fade. Today we arrived in Bushnell and the kitchen is a trickle. Pressure at CG faucet is normal. Bathroom flow is good. Shower flow is good. There are no visible kinks in the line to the kitchen. I'm assuming there is a blockage in the kitchen line. Does anyone have suggestions for troubleshooting this one? Unscrew the aerator on the end of the faucet head and see if it is clogged. Quote Al & Sharon 2006 Winnebago Journey 36G 2020 Chevy Colorado Toad San Antonio, TX http://downtheroadaroundthebend.blogspot.com/ Link to comment Share on other sites More sharing options...
oldjohnt Posted November 14, 2020 Report Share Posted November 14, 2020 Ive seen EITHER a clog deep in the faucet assembly orrrrrrrrrrrrrrr a clogged up aerator screen cause that. Are BOTH the hot and cold slow????????? If ONLY one I suspect the faucet assembly but if BOTH maybe the aerator screen. John T NOT a plumber so no warranty but still those are the two places I suspect. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted November 15, 2020 Report Share Posted November 15, 2020 2 hours ago, Al F said: Unscrew the aerator on the end of the faucet head and see if it is clogged. That is a pretty common problem. By far the most likely. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
mptjelgin Posted November 15, 2020 Report Share Posted November 15, 2020 I have to remove our aerator once or twice a year and flush it. We always use a two-filter system on incoming water, but hard water will create deposits that hang up in the screen of the aerator. Quote Mark & Teri 2021 Grand Designs Imagine 2500RL, 2019 Ford F-350 Mark & Teri's Travels Link to comment Share on other sites More sharing options...
Pat & Pete Posted November 15, 2020 Report Share Posted November 15, 2020 I always remove the aerator . Much better flow . Quote Goes around , comes around . Link to comment Share on other sites More sharing options...
Jinx & Wayne Posted November 15, 2020 Author Report Share Posted November 15, 2020 I neglected to say that I checked the aerator and it is fine. I've thought about it some more. The problem affects both hot and cold. Since the cold feed to the hot water tank branches off from the kitchen sink cold feed (one branch to hot tank and one to kitchen sink), and the hot water outflow to the shower and bathroom is fine, the problem is downstream from that branch. Since the only thing that affects both hot and cold in the kitchen downstream from that point after the hot water tank is the one-handle faucet, I'm going to look at that. I've never taken one apart before (I'm a retired lawyer, not a plumber.) This may be interesting. Quote Jinx and Wayne 2006 Carriage Carri-Lite 36KSQ Link to comment Share on other sites More sharing options...
Kirk W Posted November 15, 2020 Report Share Posted November 15, 2020 49 minutes ago, Jinx & Wayne said: Since the only thing that affects both hot and cold in the kitchen downstream from that point after the hot water tank is the one-handle faucet, That would be my next step as well. You are thinking in the right way to eliminate the things which can't impact both water supplies and it looks like the faucet is about the only thing that could cause your symptoms. I had one of the ball type faucets in our house get to where it would not open fully and a rebuild kit corrected that. It was long enough ago that I don't remember exactly what the cause was, but the kit wasn't difficult to install. If your faucet set is from the RV supply world there may not be parts available but if it is one of the major plumbing supply brands there should be rebuild kits at Lowe's or Home Depot. Plumbing is one of my most disliked chores, and I made my living in the electrical/mechanical repair field. 😏 I really think that you are on the right track. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
DJohns Posted November 15, 2020 Report Share Posted November 15, 2020 Does your kitchen faucet pull out on a hose? If so, there is a screen between the faucet and the hose. Quote 2002 Beaver Marquis Emerald C-12 Cat 505 HP 2014 Volvo 630 D-13 I Shift SOLD 2017 New Horizons SOLD Link to comment Share on other sites More sharing options...
Jinx & Wayne Posted November 16, 2020 Author Report Share Posted November 16, 2020 On 11/15/2020 at 8:28 AM, Kirk W said: If your faucet set is from the RV supply world there may not be parts available but if it is one of the major plumbing supply brands there should be rebuild kits at Lowe's or Home Depot. Kirk, Thank you. It is a ball type faucet. Although our rig is old (2006 Carriage) we rebuilt the kitchen last year so the faucet is relatively new. It is from Dura, so parts or a new faucet are available On 11/15/2020 at 8:47 AM, DJohns said: Does your kitchen faucet pull out on a hose? If so, there is a screen between the faucet and the hose. Quote Jinx and Wayne 2006 Carriage Carri-Lite 36KSQ Link to comment Share on other sites More sharing options...
Jinx & Wayne Posted November 16, 2020 Author Report Share Posted November 16, 2020 Sorry DJohns, posted by accident. No pull out but thank you for the idea. Quote Jinx and Wayne 2006 Carriage Carri-Lite 36KSQ Link to comment Share on other sites More sharing options...
Jinx & Wayne Posted November 18, 2020 Author Report Share Posted November 18, 2020 On 11/15/2020 at 8:28 AM, Kirk W said: I had one of the ball type faucets in our house get to where it would not open fully and a rebuild kit corrected that. I contacted Dura customer service and they agreed that is most likely. We had it installed about 14 months ago so Dura is shipping a kit under warranty. It should be in Avon Park when we arrive. They also sent a video on how to make the replacement. For those considering a new RV faucet, Dura's customer service was very prompt and very helpful. Quote Jinx and Wayne 2006 Carriage Carri-Lite 36KSQ Link to comment Share on other sites More sharing options...
hemsteadc Posted November 18, 2020 Report Share Posted November 18, 2020 Something similar, and very strange, is what happens after a day's travel. The water flow in the bathroom is terrible, and the water pump makes noise like crazy. The solution is to flush the toilet. Weird huh? Quote Link to comment Share on other sites More sharing options...
Kirk W Posted November 18, 2020 Report Share Posted November 18, 2020 38 minutes ago, Jinx & Wayne said: I contacted Dura customer service Thank you for taking the time to update us. Let us know when you finish how things go and if it resolves the problem. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Jinx & Wayne Posted November 25, 2020 Author Report Share Posted November 25, 2020 Well, I'm stumped. Monday I received the the ball replacement kit from Dura and installed it. It took a matter of minutes. And then nothing had changed. I was considering my next step when - lo and behold - the water flow was back to normal this morning. I have a couple of thoughts. One, my re-build was slightly out of alignment. Two, something was partially blocking the line and broke loose. Three, my plumbing system shares the same sense of humor as my GPS (routing through residential streets when towing is a big favorite of the GPS). Four, none of the above. I'm going to make more coffee now. I will admire the water flow and resist the urge to claim credit for it. Quote Jinx and Wayne 2006 Carriage Carri-Lite 36KSQ Link to comment Share on other sites More sharing options...
Al F Posted November 25, 2020 Report Share Posted November 25, 2020 1 hour ago, Jinx & Wayne said: Well, I'm stumped. Monday I received the the ball replacement kit from Dura and installed it. It took a matter of minutes. And then nothing had changed. I was considering my next step when - lo and behold - the water flow was back to normal this morning. I have a couple of thoughts. One, my re-build was slightly out of alignment. Two, something was partially blocking the line and broke loose. Three, my plumbing system shares the same sense of humor as my GPS (routing through residential streets when towing is a big favorite of the GPS). Four, none of the above. I'm going to make more coffee now. I will admire the water flow and resist the urge to claim credit for it. Just think of it like we do our smart phones and other computers. Just turn then off and back on and it starts working again. 😁 In your case, taking it apart and putting it back together again is what it needed. Quote Al & Sharon 2006 Winnebago Journey 36G 2020 Chevy Colorado Toad San Antonio, TX http://downtheroadaroundthebend.blogspot.com/ Link to comment Share on other sites More sharing options...
Jinx & Wayne Posted November 25, 2020 Author Report Share Posted November 25, 2020 7 hours ago, Al F said: Just think of it like we do our smart phones and other computers. Just turn then off and back on and it starts working again. 😁 I've always taken the view that magic is as good a description for some phenomena as any scientific answer, depending upon your level of technological expertise. The workings of cellphone and computers beyond basic programing issues are magic to me. I can make them work most of the time, but I have too little knowledge to describe the rest of their workings as anything other than as magic. Where that point is depends upon the person. Turning computers on and off to fix them is about my level. That is above the cargo cult level, but not by much. Quote Jinx and Wayne 2006 Carriage Carri-Lite 36KSQ Link to comment Share on other sites More sharing options...
Kirk W Posted November 25, 2020 Report Share Posted November 25, 2020 9 hours ago, Jinx & Wayne said: I will admire the water flow and resist the urge to claim credit for it. I suspect that the repair kit did correct the problem, even if it didn't immediately. As long as it continues to operate properly after you "fixed" it then I would say you do deserve the credit. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
