time_traveler Posted September 1, 2020 Report Share Posted September 1, 2020 What adapter do I need? Quote Link to comment Share on other sites More sharing options...
Nwcid Posted September 1, 2020 Report Share Posted September 1, 2020 50 amp twist lock to 50 amp RV I believe this one should work, but you will need to verify, https://www.amazon.com/Parkworld-886399-Adapter-SS2-50P-14-50R/dp/B079JYS4GT/ref=asc_df_B079JYS4GT/?tag=hyprod-20&linkCode=df0&hvadid=241924658829&hvpos=&hvnetw=g&hvrand=17556146774675789746&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9033769&hvtargid=pla-451300218221&psc=1 Quote 2014 Volvo 630. 2016 Fuzion 325T, RZR 900 Trail 675ah AGM, MSH 3012 inverter, 960w Solar. (2016 Chevy 3500 DRW, backup) Link to comment Share on other sites More sharing options...
Darryl&Rita Posted September 1, 2020 Report Share Posted September 1, 2020 The top pic is intended to connect to the RV, the second to the power pedestal. Use an extension cord, if you can't get close enough to the pedestal. 10 foot or 30 foot. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Nwcid Posted September 1, 2020 Report Share Posted September 1, 2020 After seeing the last poster, there is more than one way to ready your question. I took your question to mean you wanted to connect those two together. What are you wanting to "adapt" to? Quote 2014 Volvo 630. 2016 Fuzion 325T, RZR 900 Trail 675ah AGM, MSH 3012 inverter, 960w Solar. (2016 Chevy 3500 DRW, backup) Link to comment Share on other sites More sharing options...
time_traveler Posted September 1, 2020 Author Report Share Posted September 1, 2020 I want to connect the two 50 amp power cords I have for when I’m more than 25’ from the pedestal Quote Link to comment Share on other sites More sharing options...
time_traveler Posted September 1, 2020 Author Report Share Posted September 1, 2020 1 hour ago, Nwcid said: 50 amp twist lock to 50 amp RV I believe this one should work, but you will need to verify, https://www.amazon.com/Parkworld-886399-Adapter-SS2-50P-14-50R/dp/B079JYS4GT/ref=asc_df_B079JYS4GT/?tag=hyprod-20&linkCode=df0&hvadid=241924658829&hvpos=&hvnetw=g&hvrand=17556146774675789746&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9033769&hvtargid=pla-451300218221&psc=1 thanks this looks like what I’m looking for Quote Link to comment Share on other sites More sharing options...
Kirk W Posted September 1, 2020 Report Share Posted September 1, 2020 10 hours ago, Nwcid said: 50 amp twist lock to 50 amp RV The twist-lock pictured in the first post is a 30A cord. Note that it has only 3 pins. The adapter shown on Amazon should work fine as it is a 30A to 50A connector. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Dutch_12078 Posted September 1, 2020 Report Share Posted September 1, 2020 (edited) 18 minutes ago, Kirk W said: The twist-lock pictured in the first post is a 30A cord. Note that it has only 3 pins. The adapter shown on Amazon should work fine as it is a 30A to 50A connector. Look again, Kirk. There are three "prongs", two hots and the neutral, plus a safety ground tab on the side of the plug. A standard SS2-50R RV and marine twist lock setup... Edited September 1, 2020 by Dutch_12078 Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Nwcid Posted September 1, 2020 Report Share Posted September 1, 2020 3 hours ago, Kirk W said: The twist-lock pictured in the first post is a 30A cord. Note that it has only 3 pins. The adapter shown on Amazon should work fine as it is a 30A to 50A connector. It is a 50 amp for sure. Look at the 3 pins you do see, there are 2 that point out, on 30 amp, there is only one and it points in. https://www.etrailer.com/RV-Power-Cord/Mighty-Cord/A10-3025ED90.html?feed=npn&gclid=CjwKCAjw4rf6BRAvEiwAn2Q76o2rSSbfHTjU8LegMtcpIhk-3zoIgt0lfTD3dY7EXZIyBnChinD-PhoCmlUQAvD_BwE Quote 2014 Volvo 630. 2016 Fuzion 325T, RZR 900 Trail 675ah AGM, MSH 3012 inverter, 960w Solar. (2016 Chevy 3500 DRW, backup) Link to comment Share on other sites More sharing options...
Nwcid Posted September 1, 2020 Report Share Posted September 1, 2020 12 hours ago, time_traveler said: I want to connect the two 50 amp power cords I have for when I’m more than 25’ from the pedestal So do you have 2 twist lock ends and 2 RV plug ends? Typically your more modern RV with detachable cord will have one twist lock end and one "traditional" end. The you use a standard RV extension cord. I did look for a twist lock to twist lock extension cord and never did see one. There are the Hubbell style connectors used in construction, but I never did get a straight answer if they are compatible or not. Quote 2014 Volvo 630. 2016 Fuzion 325T, RZR 900 Trail 675ah AGM, MSH 3012 inverter, 960w Solar. (2016 Chevy 3500 DRW, backup) Link to comment Share on other sites More sharing options...
time_traveler Posted September 1, 2020 Author Report Share Posted September 1, 2020 4 hours ago, Kirk W said: The twist-lock pictured in the first post is a 30A cord. Note that it has only 3 pins. The adapter shown on Amazon should work fine as it is a 30A to 50A connector. This is the 50 plug on my 5iver the picture I posted above in the first post is a 50 amp power - twist lock Quote Link to comment Share on other sites More sharing options...
Dutch_12078 Posted September 1, 2020 Report Share Posted September 1, 2020 To extend your cord another 25-30 feet all you need is a standard 50 amp RV extension cord with a NEMA 14-50 plug on one end and 14-50 receptacle on the other. Many Walmart stores carry them in the RV section, or Amazon and others have them online. https://www.amazon.com/Cable-Matters-Prong-Extension-Handle/dp/B076ZVRSJ1/ Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
time_traveler Posted September 1, 2020 Author Report Share Posted September 1, 2020 6 minutes ago, Dutch_12078 said: To extend your cord another 25-30 feet all you need is a standard 50 amp RV extension cord with a NEMA 14-50 plug on one end and 14-50 receptacle on the other. Many Walmart stores carry them in the RV section, or Amazon and others have them online. https://www.amazon.com/Cable-Matters-Prong-Extension-Handle/dp/B076ZVRSJ1/ That is what I should have bought in the 1st place. Lol Quote Link to comment Share on other sites More sharing options...
Dutch_12078 Posted September 1, 2020 Report Share Posted September 1, 2020 9 minutes ago, time_traveler said: That is what I should have bought in the 1st place. Lol Well, the adapter that Nwcid will work to let you use the cord you have as an extension cord for the OEM cord that came with your RV. Or you could save a few dollars by cutting off the SS2-50R twist-lock plug and replacing it with a 14-50R instead. Just be careful that you get the wires connected to the right terminals. https://www.amazon.com/Camco-55353-Female-Replacement-Receptacle/dp/B00192QB9M/ Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Pappy Yokum Posted October 17, 2020 Report Share Posted October 17, 2020 (edited) On 9/1/2020 at 9:48 AM, time_traveler said: This is the 50 plug on my 5iver the picture I posted above in the first post is a 50 amp power - twist lock Kirk - read the *warning* label. This is typically a "Marinco" brand twist lock 50amp connection for an external power cord from an RV to the 50 amp connection at the pedestal of a campground/or RV park. An easier to read warning label, like the one on my 5th states in LARGE print above the connection: "This connection for 120/240 volt 3-pole, 4-wire, 60 Hertz 50 AMPERE SUPPLY" (the numeral "50" is outlined in a box, capital letters are as printed on the label). And yes - - the female only has 3 posts. It is *NOT* 30 amp! There are several short adapters available (utilizing the Marinco twist lock 50 amp) to go to a 30 or 15/20 amp supply cord. (have one connected to my 5er at my home now - 50 amp at the twist lock to three prong 15/20 amp 12 ga cord). They are not cheap! The Marinco version is usually about $70 for either 30 or 15/20 amp) However - as someone already stated - the best plan to extend the 50 amp cord is with a 50 amp EXTENSION CORD ! ** It will connect (w/ female) to the male end of the factory-supplied 50 amp cord, and still have the appropriate (male) 50 amp plug for the RV park pedestal. "If* the park does not have a 50 amp connection - use a 50 to 30 adapter to connect to the 30 amp at the pedestal. ** A less expensive option = the above, 50 to 30 (or 15/20) amp adapter on the end of the factory cord, then use a 30 amp extension cord (WalMart) or a 12 ga extension cord. (for "basic" power supply only, *not* A/Cs, etc.) . Edited October 17, 2020 by Pappy Yokum Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted October 17, 2020 Report Share Posted October 17, 2020 (edited) Pappy is correct. What is pictured is both ends of a 50A RV cord, not an extension cord. The ground wire connection is a metal tab on the outside of RV end of the cord. That plug and corrsponding receptacle are designed so the ground always engages first. Edited October 17, 2020 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
