dometic fridge help
Zman65
 Share
Hi All
We just got back from first trip. All went well for first timers. But on morning of third day, our dometic fridge/freezer started beeping. I powered it off and on. Also looked in manual and only thing it said is if there is an ice buildup it would beep. Didn't really have any ice buildup but wiped off what little we had. Nothing helped. Finally just put everything in a cooler  and turned it off. Called in to service department at dealer several times to see if they had any ideas but never got a return call. This is brand new unit. Was hoping someone here might have some ideas to try. Thx
Since it is still under warranty, I wouldn't do more than what your owner's manual suggests. I would call the nearest RV service to get it looked at as most RV service shops can do warranty work for Dometic, even if they don't handle the make of RV that you have.
34 minutes ago, Zman65 said:
The service center said 3 weeks out and we have another trip planned for july 4th weekend so was hoping to see if something simple,.
If you can post the model you have we might be able to help more. There are service manuals for most models available online, if you know where to look. They typically give more and better information than do owner's manuals.
Sure thx! It is model dm2872rbx
thx
Dometic and Norcold , both tightly control any service manuals.  I was trying to get service info on a Norcold and the main office told me to contact an authorized service center and that they did not release service info due to liability issues.  No doubt with the fires and lawsuits that they do not want any technical literature out.
I have worked  in industrial refrigeration and have designed much larger ammonia absorption systems.  I finally figured it out enough to make the repairs.  Just do not expect any service info.
Ken
While that seems to be true, there are several user groups and also Bryant RV Service who make them available for download in .pdf format. I have copies of several and often refer to others online.
Yes, I was plugged into shore power.
Yesterday afternoon I plugged 110 to the rv and turned on fridge. It beeped right away and then after a couple off and on's it stopped. I checked this morning and fridge is cold. Will let it run for a day or so and see if it starts beeping again. The whole thing is a bit puzzling
While a battery shouldn't fail so quickly, it sounds very suspicious that it may be your problem. Do you have a good volt/ohm meter? If you do, try lifting the negative cable from the coach battery and then measure the voltage between the two battery posts.
3 minutes ago, Zman65 said:
Is it possible that even though plugged into shore power, the fridge is using the battery to run?
An RV refrigerator always uses 12V direct current to operate the controls, even if you select 120V for energy. All that is ever supplied by 120V is the heating element. It is that way because it is the most reliable power and allows you to operate in automatic. That 12V power can either be supplied from the RV battery, or from the RV converter, but it must be there for things to operate. A bad battery will occasionally cause the converter to stop supplying 12V power but if taken out of the system, the converter will take over as long as you have 120V power from the pedestal.
14 minutes ago, Zman65 said:
Ok thanks, makes sense. So it primarily uses the battery but if batt fails or drains it will switch to converter?
No, it uses 12V which is supplied by the battery and the converter.  There is no "switching" involved.  If you are connected to shore power the converter should always be on.  Any lights or other devices that use 12V will be powered by the battery bank which is backed up by the converter.  There's no way for you to tell where the electrons come from.
Okay. The dealer I bought from said I should turn battery power off by the disconnect switch installed when not in use. So when I plugged the 120 in yesterday and it started beeping could that be because I had the disconnect switch off?
They provided a "rv course" prior to delivery but really didnt cover any of this or some other vital stuff :(
thx
Yes, that would do it. The refrigerator was trying to tell you that it lost 12V power. The disconnect in most RVs is connected to turn off all 12V power to appliances and lights to prevent the discharging of the batteries when the RV is stored. In many RVs the disconnect does leave a few things like the propane detector and the CO detectors powered and yours might still supply a few things but it probably doesn't supply the refrigerator.  The disconnect is not intended to be used if you have things inside of the RV that you wish to keep operating.
In most cases, the converter power is connected to the 12V system at the battery since recharging it would be the largest load that it usually sees. It would be very unusual for the converter to be able to supply power to appliances with it open as that would defeat the purpose of it.
This might be too simple, but check that the door is not ajar or that the light switch is actually turning the light off.
On my first trip with my motorhome i heard a beeping and in searching for the source i found the door to the fridge ajar.  Didn't even know there was an alarm.
Hope your problem is as simple!
53 minutes ago, Zman65 said:
Dont have a load tester but battery monitoring switch show batt is full.
Those standard battery level indications are one of the more useless things to be found in an RV. They do not actually measure battery condition, but only give a rough idea of the voltage at the location of the meter. You can tell just a little less by turning on a light to see how bright it is.
 Share
RV Cable Grip
RV Cable Grip
RV Air.
