Danandfreda Posted June 8, 2019 Report Share Posted June 8, 2019 Just tried out the project 50 amp tester at the Menard county fairgrounds down the road from us. We staying here this weekend for a trap shooter event. Thanks again randy Quote Link to comment Share on other sites More sharing options...
lockmup68 Posted July 4, 2019 Report Share Posted July 4, 2019 What’s the lights order/info? all lights are on but the top two middle ones. What does that mean? Quote 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted July 5, 2019 Report Share Posted July 5, 2019 6 hours ago, lockmup68 said: What’s the lights order/info? all lights are on but the top two middle ones. What does that mean? That the top two middle ones have quit working or there is no power to them. 😎 Quote 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
Danandfreda Posted July 5, 2019 Author Report Share Posted July 5, 2019 voltage. Proper outlet wiring with the following is tested: Ground and neutral present and contiguous 120-volt power between E1 and Neutral 120-volt power between E2 and neutral 240-volt power across E1 to E2 If there are errors in the outlet wiring like reversed power and neutral, missing grounds or improper voltage from E1 to E2 certain lights will not illuminate. All materials other than the Camco Plug are provided – you will need to bring a plug to complete the project. BRING THIS PLUG - IT IS NOT PROVIDED Quote Link to comment Share on other sites More sharing options...
SuiteSuccess Posted July 5, 2019 Report Share Posted July 5, 2019 15 hours ago, lockmup68 said: What’s the lights order/info? all lights are on but the top two middle ones. What does that mean? David Dixon was going to post the schematic on the ECR website. Let me check on that. If not I’ll see if I can find my copy and post here. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
RandyA Posted July 6, 2019 Report Share Posted July 6, 2019 Neon lamps like we used in the project are not prone to burning out. One of two things if the top two lights are not lit- the wires inside the tester may have not been soldered well and have broken loose OR the two legs bringing power to the RV are both of the same phase differential meaning the 120 - 120 legs are on the same wire. The danger here is if you are pulling a lot of power like two AC's, converter water heater, etc. at the same time you will burn the neutral wire or contact. You are also most likely to to have a single 50 amp line rather tan two 50 amp lines. If both lights come on E1 and E2 have a phase differential that is 180 degrees. You will have 220 across E1 and E2. All is good. Quote Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
lockmup68 Posted July 6, 2019 Report Share Posted July 6, 2019 7 hours ago, RandyA said: Neon lamps like we used in the project are not prone to burning out. One of two things if the top two lights are not lit- the wires inside the tester may have not been soldered well and have broken loose OR the two legs bringing power to the RV are both of the same phase differential meaning the 120 - 120 legs are on the same wire. The danger here is if you are pulling a lot of power like two AC's, converter water heater, etc. at the same time you will burn the neutral wire or contact. You are also most likely to to have a single 50 amp line rather tan two 50 amp lines. If both lights come on E1 and E2 have a phase differential that is 180 degrees. You will have 220 across E1 and E2. All is good. Thank you. Generator is 110 and I was just testing my wiring out and thought I would try the tester out too. So yes, two 110 legs single 50’amp line vs. 2 on 220. Quote 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
rickeieio Posted July 6, 2019 Report Share Posted July 6, 2019 Maybe some retired farmer with Shrek hands did your soldering........ Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
SuiteSuccess Posted July 6, 2019 Report Share Posted July 6, 2019 9 hours ago, RandyA said: Neon lamps like we used in the project are not prone to burning out. One of two things if the top two lights are not lit- the wires inside the tester may have not been soldered well and have broken loose OR the two legs bringing power to the RV are both of the same phase differential meaning the 120 - 120 legs are on the same wire. The danger here is if you are pulling a lot of power like two AC's, converter water heater, etc. at the same time you will burn the neutral wire or contact. You are also most likely to to have a single 50 amp line rather tan two 50 amp lines. If both lights come on E1 and E2 have a phase differential that is 180 degrees. You will have 220 across E1 and E2. All is good. Thanks for posting Randy. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
lockmup68 Posted July 6, 2019 Report Share Posted July 6, 2019 4 hours ago, rickeieio said: Maybe some retired farmer with Shrek hands did your soldering........ 👍 take that any day. Farmers keep me in food and they just figure it out deep working. Quote 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
rickeieio Posted July 6, 2019 Report Share Posted July 6, 2019 Ummm, I've retired. Only planted two tomato plants, no corn or soybeans. Now we can go play with the other olde phartes. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Darryl&Rita Posted July 7, 2019 Report Share Posted July 7, 2019 Old farmers never die, they just smell that way. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
