Bobtail mileage
ARGO
  • 4 years later...
I have started to check and see what I get running BT. So far it appears to be 4.4 mpg. I haven't driven it far between fill ups so I don't know how accurate that is. My question is, if it is accurate what would that mean? Do I have an issue that is causing poor mileage? Injector(s) maybe?
Chuck
On 11/28/2017 at 12:36 AM, VegasFlyer said:
With a Volvo 780, the weight of your foot can also greatly reflect a big change to the mpg readings.
Hi, I have a 2010 780 with a cummins ISX 15. I think my mileage is about 4.4 bobtail. I need to verify it with more miles between fill ups. But if that is correct is there something I may need to have fixed to get it up to where it should be?
Chuck
37 minutes ago, Randyretired said:
I don't bobtail much but the couple of times I did it was 12mpg.  2001 ISX.
That's way better than I am probably getting. I am going to verify over the next few days. I am trying to get it in for a tune up/valve adjustments but everyone is behind or short handed due to COVID.
That is terrible fuel consumption for a regular tractor even under load.    Are you sure the fuel consumption numbers are correct?     The only accurate way to check is with actual fuel usage.
If the truck is using that much fuel is the engine burning it or is there other sources of use?    The DPF has an injector, are the fuel/return lines leaking, is the oil diluted with fuel?   That kind of fuel consumption would be the engine under 70+ percent load all the time, is there a driveline issue?     Does the truck coast freely or slowdown rapidly when you back off the pedal?
Something is way out of wack to have that kind of mileage bobtail.    What speed and wind conditions were these numbers derived from?
Steve
Steve
I am going to double check the numbers over the next few days. I have not seen any fuel leaks or any other leaks. The last oil sample the fuel dilution was 1.6% GC (not sure what GC is). It was 0.6% on the first sample about 1800 miles previously. I had just gotten the truck last summer used and wanted to see where it sat on the analysis. I have just taken another sample at 5000 miles since I've gotten it. I won't have those results back for a week or so. I did replace the center bearing and front u-joint. Haven't really driven it in terrible winds. It coasts pretty good when you let off the pedal.
If the fuel dilution is up on the next sample I am assuming at least one of the injectors may be bad?? I have the injector leak test tool but haven't gotten around to checking yet.
I don't drive it for hundreds of miles at a time. So I suspect that may have something to do with it. I am going to put a couple hundred on it and refill and do the math again.
I am also putting a new MAP sensor on. It is still the original and the truck has 892,000 miles. That may be part of it too. She's old and in need of some TLC(aka$$$). haha
Chuck
Man, I thought I was sucking towing 30k with my 2001 660/D12/Eaton Autoshift.  Loaded, running around out west in and out of the mountains, I'm getting about 6 mpg.  Bobtail, the little that I do it, the lie-o-meter puts me above 10 mpg.  So I'd say that's accurate to +/- 1 mpg.  Probably + if I'm telling someone and -  if I'm paying the fuel bill.  I agree with the others, something is amiss.
2001 VNL 660
2018 DRV Fullhouse JX450
2018 Jeep Wrangler Rubicon
As you call it, "lie-o-meter". Mine says 10.1 most of the time. I will be putting more miles on it today and tomorrow and then filling up and checking those real numbers.
My lie o meter on my Freightshaker is a scale of plus and minus scales. Is set at 7 mpg. It stays in plus side unless climbing a hill. When bobtail it pegs out on plus side. I find it difficult to gauge from fuel burned. Just can't get same amount in it. Reckon I could take time and fill until it almost runs over on each side but just don't have the patience.
In another thread, you mention running Jet A.  Isn't that a lot like kerosene, with less btu's than regular diesel?  Bingo, less btu=less mpg.
"Jet Fuel", sounds powerful right !!! It is in the right circumstances, very powerful.
When I was much younger and my Father was an "Oil Jobber" I asked him why we didn't sell "Jet Fuel" to the farmers instead of the "Number Two" fuel and why we hardly sold any "Number One" except in the winter. I don't remember his exact words, but it was something about when the crude oil was refined and I don't remember the other numbers. (Google it maybe). Number two was the third to last in quality. Number One was just above "Jet Fuel" he called the left overs from the refining of oil, without much of the needed lubrication properties of a diesel motor. I'm sure he went on with other stuff, but I'm now probably at the age he was when I asked him the question and didn't chose being an "Oil Jobber" as my career.
Rod
2007 Honda GL 1800
 Wash the back of your sleepers, then bobtail over a highway with wet spots in the shade etc., and see what the back of your sleeper looks like. That vertical wall sucks more stuff up off the road than the open tires can throw up there. Bobtail mileage depends so much on detail. If you have side fairings, full fenders over the rear, a bed or even a drom box, all make a difference in how that low pressure suction behind the sleeper reacts. Even the front bumper height off the surface makes a difference, as it determines how much air goes under the truck vs. around the outside.
 It would be good to know everyone's elevation average as well. Driving in the rain takes power. Driving in 110F looses power, etc.
I'm a work'n on it.
