alan0043 Posted June 2, 2017 Report Share Posted June 2, 2017 Hi Everyone, I have a new tool. You can guess what it is from the title. I need to start finding the air leaks on the truck. My questions is for the people that have used the Whisper. What is the best way to find air leaks ? I know that the truck does need to have air in the tanks. But does the truck need to be running during the testing ? What area to you start your testing at ? I want to go over the whole truck. Is there any little tip I should now ? There is always a breeze at my house. Does the wind blowing affect the testing ? Is there anything that I am missing ? Thank you for any help, Al 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
SuiteSuccess Posted June 2, 2017 Report Share Posted June 2, 2017 Al, Start the truck and fill the tanks to max. Turn off truck. Start under hood at max sensitivity then dial down sensitivity as you begin to isolate leak. Fix what you find and move on towards back and under. At max sensitivity it will detect from several feet away. A big leak will be difficult to isolate despite low sensitivity. Some folks use ear phones, I don't and it's been ok. Breezes aren't usually a huge issue unless it's constantly in the area you're working. By the way using the "elephant trunk" extension helps isolate. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Shallow Draft Posted June 2, 2017 Report Share Posted June 2, 2017 Shop air can be helpful as the truck will not be hot and that will make it easier and safer to crawl around under it. 2004 Volvo 630, Freedomline, Rear view camera, Max Brake, Jackalopee, 38 ft 4 horse LQ Platinum, 40ft Jayco Talon toy hauler Http:/www.flickr.com/photos/shallow_draft/ Https://flic.kr/p/fqhyAN You are not lost if you don't care where you are!! Link to comment Share on other sites More sharing options...
alan0043 Posted June 2, 2017 Author Report Share Posted June 2, 2017 4 minutes ago, Shallow Draft said: Shop air can be helpful as the truck will not be hot and that will make it easier and safer to crawl around under it. Hi Shallow Draft, Where does someone hook the shop air up to ? Is there a place on the truck that has a fitting ? Or does a fitting have to be added to the truck ? If you add a fitting to the truck, what does it look like ? Or are the fittings the same ones that you can use for your air tools ? It might be a good idea to have a place on the truck for shop air. Al 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
Imurphy907 Posted June 2, 2017 Report Share Posted June 2, 2017 There will usually be a schrader valve on the air governor. You hook a chuck to it like filling a tire. I use a wisper to find leaks in AC systems, have yet to use it on the truck as I can hear the leaks on my own so far. 2016 Road Warrior 420 2001 Volvo VNL 660 Alaska Based. Link to comment Share on other sites More sharing options...
Shallow Draft Posted June 2, 2017 Report Share Posted June 2, 2017 Yes on the governor. It is where you can air up the truck if you shut it off in gear. The truck will not start in gear and if air is low it will not shift into neutral. I have not had to do this but it is a bit of handy info if it ever happens. 2004 Volvo 630, Freedomline, Rear view camera, Max Brake, Jackalopee, 38 ft 4 horse LQ Platinum, 40ft Jayco Talon toy hauler Http:/www.flickr.com/photos/shallow_draft/ Https://flic.kr/p/fqhyAN You are not lost if you don't care where you are!! Link to comment Share on other sites More sharing options...
NeverEasy Posted June 2, 2017 Report Share Posted June 2, 2017 x2 on what SuiteSuccess said. I used the headset and elephant trunk. It worked great. I finally located all my leaks. The biggest and hardest to find was on the top/back of the transmission. It was caused by the person that laced up the air lines on the drivers side not leaving enough slack for movement. The Volvo will stay above 90 p.s.i for at least two weeks while parked! I pull the truck up on some 8 foot 8 x 8s (4 pairs with 2-8x8s bolted together with deck plating) to allow space to crawl under the fairings. Chet & Deb '01 Volvo 660 w/ Smart '19 Forest River Columbus 320RS 5th wheel 2022 Chev 2500HD Long Bed Retired CWO4, USN and federal service Electronics Tech/Network Engineer/Welder/Machinist Link to comment Share on other sites More sharing options...
alan0043 Posted June 2, 2017 Author Report Share Posted June 2, 2017 Hi Everyone, These are all great tips. Please keep them coming. By looking for leaks, I think is a great way to learn more about the truck. The more that I can learn about the air system the better. I should think about replacing some parts to the air system so I don't have to do the repairs on the side of the road. Al 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
SuiteSuccess Posted June 2, 2017 Report Share Posted June 2, 2017 Or you can make up one of these and connect it to shop air. There is a connection that looks like an air conditioner R134 fill on the left side of my D12 on an aluminum pipe that you can trace to your truck air compressor. Make up one of these and it will connect. You will be pre air dryer if you don't have a dryer on your shop air. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
sclord2002 Posted June 2, 2017 Report Share Posted June 2, 2017 Al, the fitting in Carls photo is a 134-A high side fitting with a standard air fitting connected to it. Charlie Don't ever tell a soldier that he doesn't understand the cost of war. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted June 2, 2017 Report Share Posted June 2, 2017 Another thought is while the truck is on level ground and Air'd up, chock at least 2 tires/wheels and release your brakes. This puts air to the brake cans and brake air system. But always safety first when doing this. Having a truck roll while under it will probably be ugly in outcome..... Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
Shallow Draft Posted June 3, 2017 Report Share Posted June 3, 2017 1 hour ago, SuiteSuccess said: Or you can make up one of these and connect it to shop air. There is a connection that looks like an air conditioner R134 fill on the left side of my D12 on an aluminum pipe that you can trace to your truck air compressor. Make up one of these and it will connect. You will be pre air dryer if you don't have a dryer on your shop air. Great idea. I am going to build one of these. I like the "before the air dryer" idea. Also it will stay connected better than a tire inflator. Could you add a pic of the connection on the D12 so I have a better idea of it's location. 2004 Volvo 630, Freedomline, Rear view camera, Max Brake, Jackalopee, 38 ft 4 horse LQ Platinum, 40ft Jayco Talon toy hauler Http:/www.flickr.com/photos/shallow_draft/ Https://flic.kr/p/fqhyAN You are not lost if you don't care where you are!! Link to comment Share on other sites More sharing options...
alan0043 Posted June 3, 2017 Author Report Share Posted June 3, 2017 12 hours ago, Shallow Draft said: Great idea. I am going to build one of these. I like the "before the air dryer" idea. Also it will stay connected better than a tire inflator. Could you add a pic of the connection on the D12 so I have a better idea of it's location. Hi Carl, Thanks for the picture. I would also like to see a picture of the connection. 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
SuiteSuccess Posted June 3, 2017 Report Share Posted June 3, 2017 Thanks, but this was Charlie's creation so he deserves the credit. Will get a pic today and post. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
SuiteSuccess Posted June 3, 2017 Report Share Posted June 3, 2017 Connection on aluminum tube 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Shallow Draft Posted June 3, 2017 Report Share Posted June 3, 2017 Thank you. This has got to be the greatest site on the internet. 2004 Volvo 630, Freedomline, Rear view camera, Max Brake, Jackalopee, 38 ft 4 horse LQ Platinum, 40ft Jayco Talon toy hauler Http:/www.flickr.com/photos/shallow_draft/ Https://flic.kr/p/fqhyAN You are not lost if you don't care where you are!! Link to comment Share on other sites More sharing options...
CampClownPete Posted June 3, 2017 Report Share Posted June 3, 2017 17 hours ago, Alie&Jim's Carrilite said: Another thought is while the truck is on level ground and Air'd up, chock at least 2 tires/wheels and release your brakes. This puts air to the brake cans and brake air system. But always safety first when doing this. Having a truck roll while under it will probably be ugly in outcome..... Chock all 4 corners of the truck. I had a friend die this way in his own driveway! Link to comment Share on other sites More sharing options...
noteven Posted June 3, 2017 Report Share Posted June 3, 2017 Where can I buy one of these instruments in western Canada? Amazon no got. Inficon's corporate website is um ... too smart for me... "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
wtgeodog Posted June 3, 2017 Report Share Posted June 3, 2017 You can find a listing on e-bay ShortyO Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted June 4, 2017 Report Share Posted June 4, 2017 3 hours ago, noteven said: Where can I buy one of these instruments in western Canada? Amazon no got. Inficon's corporate website is um ... too smart for me... https://www.amazon.com/Inficon-711-202-G1-Whisper-Ultrasonic-Detector/dp/B000TRJA8M/ref=sr_1_4?ie=UTF8&qid=1496536898&sr=8-4&keywords=inficon+leak+detector Showing 18 in stock. Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
Nigel Posted June 4, 2017 Report Share Posted June 4, 2017 Does not ship to Canada and amazon.ca doesn't have them. The other sellers in the U.S. that do ship to Canada are significantly more money plus shipping, brokerage fees and taxes. Probably best to ship to a campground next time you go south. Nigel 2006 Volvo VNL 430, 2006 smart cabrio cdi, 2000 Triple E Topaz 30' Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted June 4, 2017 Report Share Posted June 4, 2017 5 hours ago, noteven said: Where can I buy one of these instruments in western Canada? Amazon no got. Inficon's corporate website is um ... too smart for me... Are you going to the WCR? If so have Amazon ship to the campground in your name. You can have it when you get there. Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
RickS Posted June 4, 2017 Report Share Posted June 4, 2017 I don't know if they'll have room to store anymore stuff after I get done delivering stuff to the RV park...... Rick & Carey,Excel W41GKE Wild Cargo Toyhauler Volvo 730, D13, I-shift, 500/1850Brabus Smart Car Link to comment Share on other sites More sharing options...
alan0043 Posted June 4, 2017 Author Report Share Posted June 4, 2017 On 6/3/2017 at 9:26 AM, SuiteSuccess said: Thanks, but this was Charlie's creation so he deserves the credit. Will get a pic today and post. Hi Carl, Thank you for posting the picture. Hi Charlie, Thank you for the idea. I know remember you showing a group of us the fitting at last year's ECR. I need to make that handy tool. I still need to make my claw foot for the Cross Fires. Al 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
noteven Posted June 4, 2017 Report Share Posted June 4, 2017 Not in the plans to get to the WCR as of now - I help a bit around el rancho in the summer. "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
