What is this?
1 hour ago, Lisa Bright said:
I have no idea what this is. Does anyone know?!. Thanks. I'm a newbie.
Low voltage on/off switch.
Commonly used to disconnect the 12v batteries from the rest of the RV.  Less commonly used to disconnect individual 12v circuits for devices like a small inverter.
2017 Jayco Designer 37rs "Fiona"
2007 Volvo 670 "Henry"
That is a Blue Sea systems, single circuit switch and as the previous post states, it most likely there to isolate the coach battery. In your picture it appears to be mounted on the wall and if it is near the exit door then it ia pretty sure to be for the coach battery. If we are correct, the switch should be in the on position when you are using your coach and turned off when you put it into storage. In the off position you should not have any lights or 12V appliances.
