TPMS
lockmup68
Posted
My rig came with a never installed pressure pro system and sensors. Well, monitor was plummed in and there, but not really hooked up and no sensors installed. I installed a few sensors, but no readings, so I assume since it is 7 years old now, the batteries died.
In checking, replacement sensors will be $700 for 16 sensors, and a new system is about the same, maybe a bit more. I noticed that many in the HDT forum have replaced pressure pro with other options. Should I replace the pressure pro with another mfg or just get new sensors for the PP?
Thanks,
Shannon
2007 Teton Scottsdale XT4
Posted
Look at TST systems.  I have had them for seven years.  Their customer service has been outstanding.  The 507 system has user replaceable batteries ( cheap on amazon).  You can compare prices.  Nothing wrong with PressurePro, I just liked the TST better.  If you do buy the TST go ahead and get a repeater to mount on the rear of your truck or with your length, you may get drop outs.
https://tsttruck.com/
2017 DRV 39DBRS3
Posted
I've had a Pressure Pro for about 7 years. I like it. I did replace all sensors last year. I called them and they gave me a better price than your $43. I think $35/piece? It does take a few minutes sometimes to get a reading you know. There is also a programming thing you have to go through when first setting it up. Maybe you need to do that? I think their customer service is pretty good. Maybe call them and see if they'll talk you through programming before ditching it.
'03 United Specialties truck conversion, Freightliner FL112, Cat C12, 10 sp Autoshift, 295" w/b, 26' living quarters.
St. Paul, MN
www.bobwinsor.com
Posted
I have the TST 507 system on my truck.  I upgraded from there older 510 system a couple of years ago to get the flow through sensors so I didn't have to take the sensors off to add air when needed.  They also have replaceable batteries, but I haven't had to replace them yet and like I said it has been a couple of years.  I have been very happy with the system and would definitely recommend them.  I know Jack Mayer had repeated issues with drop outs on his Pressure Pro system on his long rig.  He recently switched to TST on the trailer and no longer has the same issues.  I run the repeater on my system and I believe Jack does as well.  Both systems are good, but based on my experience and having to replace all the sensors in your case I would move over to the TST.
2009 Volvo 670 with dinette/workstation sleeper - Walter
My First Solar Install Thread
Posted
We used PressurePro for 10 years with Red Rover and Tige so we bought PressurePro for our Bounder.
We did rotate the sensors at 7.5 years on Red Rover and Tige.  Never had problem with dropout once we installed the external antenna.  We used 18 sensors, Red Rover 6, Tige 7, Sparky 5.
Mark & Dale
www.dmbruss.com
Posted
If you don't have the documentation to set up the Pressure Pro system here's a link to their website and installation instructions.
http://www.pressurepro.us/index.asp?PageTypeId=14
I replaced our sensors at 7 years as they stated to die.  I considered replacing the Pressure Pro with another system at that time but decided to keep it because we trusted it and I didn't want to replace batteries annually in some of the other systems.  If these last 7 years they will outlast me!  I did have to add a repeater years ago as the rear sensors intermittently dropped out.  Zero problems since the repeater was added.      Greg
Greg & Judy Bahnmiller
Class of 2007
2014 F350
2007 HitchHiker Champagne
Posted
I bought my pressure pro in 2003. When I went to the HDT (2010) I needed more sensors. They gave me a "deal" on all new sensors and even a new monitoring unit. I also installed an external antenna at the time due to length. I mounted it in the rear of my bed, next to the hitch camera. I haven't dropped a signal yet. I never considered switching. The pressure pro has worked reliably for me for a long time.
2014 smart Fortwo
Posted
My pressure pro system was purchased in '09 or '10 and this past year I've replaced all sensors and obviously plan to stay with Pressure Pro.  What would interest me is the flo thru caps that TST uses, but then I'd guess I have to take them off somewhere between 1 and 2 years to change the batteries out, and honestly, I haven't taken my sensors off half that much in 7 - 8 yrs.  Maybe I should say that half of my sensors have been off only once in 7 or 8 years, instead of all of them every couple of years.
Rocky & Sheri Rhoades
'01 Volvo 770
2016 DRV Mobile Suites, Houston
HERO Makers Ministry
Giraffe G4.
