CHIEFWAHO Posted February 22, 2017 Report Posted February 22, 2017 Finally getting around to installing a Coleman Semi Truck Back Wall Heating A/C unit # 46103-8114 http://www.airxcel.com/coleman-mach/products/roughneck-marine/backwall-ac-for-truck-cabs Picture of unit: Had to move the JOBOX (after unloading Jeep spare parts and tools) The stack bracing will be relocated too. Per the instruction diagrams this is how the unit is supposed to mount. Sleeper interior side and back panels removed. Unit mounting plate, trail fitting. After a lot of head scratching and careful measurements the holes were cut thru the back sleeper wall. Lower stack brace relocated, upper will get the same treatment after unit is hung in place. Use a couple of boards to determine depth of standoff bolts for mounting the interior duct assembly. The supplied standoff's were nowhere long enough so I had to fab some up (guess I forgot pics of those). Now ready for final installation of the mounting plate and unit will be ready to hang. Other plans: some sort of insulation and sound deadener on the sleeper walls, install some side windows. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator.
sclord2002 Posted February 22, 2017 Report Posted February 22, 2017 Nice.....certainly will look better than my 8k window unit sticking out the back of my 780. My unit is cool-only but does a good job. I'm sure you will enjoy your new A\C and heater. Be safe, Charlie Don't ever tell a soldier that he doesn't understand the cost of war.
Ronbo Posted February 22, 2017 Report Posted February 22, 2017 What are you going to run it off of. Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime
beyerjf Posted February 23, 2017 Report Posted February 23, 2017 I have been lusting over one of these for years. I will follow the installation with mas interest. Thanks Jeff Beyer temporarily retired from Trailer Transit 2000 Freightliner Argosy Cabover 2008 Work and Play 34FK Homebase NW Indiana, no longer full time
Jeff.Sloan Posted February 23, 2017 Report Posted February 23, 2017 What are you using to water seal the opening? I am installing a split AC/heat system in the spring and have been wondering how best to water seal. For closed cell foam spray insulation on the sleeper cab ceiling and walls, I plan to go this route as soon as things warm up: https://sprayfoamkit.com/products/spray-foam-insulation/foam-green-202-closed-cell-spray-foam-insulation-kit/ 2004 Volvo 630, Cummins ISX, Eaton 10 speed (air assist clutch), 3.71 3.07 rear locker, ET jr, 200" WB, GearMaster 2017 Forest River Sierra 372LOK Full time June 2017 DW, 2 kids, and 2 dogs
CHIEFWAHO Posted February 23, 2017 Author Report Posted February 23, 2017 What are you going to run it off of. Will be able to run it 1 of 3 ways: Inverter, shore power or generator. Inverter Truck has this little gem behind the axle for when we are off the grid. 8000 watt Kubota Generator 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator.
CHIEFWAHO Posted February 23, 2017 Author Report Posted February 23, 2017 What are you using to water seal the opening? Apply lots of 100% clear silicone between the mounting plate and sleeper wall. There is a thick foam gasket that is peel and stick to the mounting plate and then pressure fits to the unit. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator.
CHIEFWAHO Posted February 23, 2017 Author Report Posted February 23, 2017 I have been lusting over one of these for years. I will follow the installation with mas interest. Thanks I'm not sure they are even available any longer? I had watched this one on eBay for about a year. Price kept dropping each time they relisted it. Ended up getting it for less than $1000 and the RV place that had it was semi local so I was able to pickup and not pay shipping. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator.
beyerjf Posted February 26, 2017 Report Posted February 26, 2017 They are still listed on the Airxcel Website. I have seen 1 or 2 recent installations on trucks at shows where I have picked up trailers. I am considering this alternative: http://www.bigrigproducts.com/dometictruckac.html 14,000 btu, mounts in side box, condenser mounted outside on back wall. Jeff Beyer temporarily retired from Trailer Transit 2000 Freightliner Argosy Cabover 2008 Work and Play 34FK Homebase NW Indiana, no longer full time
CHIEFWAHO Posted February 28, 2017 Author Report Posted February 28, 2017 We got a little more accomplished over our busy weekend. Sleeper back wall ready for the mounting plate Silicone sealant Custom stand offs for the interior grill to mount to Guess I forgot to snap a pic of mounting plate bolted in position. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator.
hdonlybob Posted March 1, 2017 Report Posted March 1, 2017 Impressed !! And very nice job of installation.. Cheers, Bob 1989 Safari Serengeti 34'Towing a 1952 M38A1 Military Willys Past HDT owner
CHIEFWAHO Posted March 23, 2017 Author Report Posted March 23, 2017 Ok been awhile, got caught waiting on the sound deadening mat and the weather has not been to cooperative. Sound deadening mat and foil bubble installation install The interior vent/return panel has to be installed before the unit can be hung. Waiting on some electrical parts to come in. Need to blow a hole in the floor of the driver side storage compartment for the unit wiring to come thru. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator.
CHIEFWAHO Posted April 6, 2017 Author Report Posted April 6, 2017 Very close to wrapping this up! Power to thermostat, check. Couch in stalled, it covers the vents. Don't think this will be a big deal as more than likely it will be laid down as a bed if backwall heat/ac unit is in use. Added a factory cabinet and a microwave while we were at it. This receptacle will be a handy addition too! Porta toilet fits nicely under the couch out of the way. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator.
Chad Heiser Posted April 6, 2017 Report Posted April 6, 2017 Nice job. 2009 Volvo 670 with dinette/workstation sleeper - Walter 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage) My First Solar Install Thread My Second Solar Install Thread & Photos and Documents Related to the build My MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website
Stan Wright Posted April 6, 2017 Report Posted April 6, 2017 Nice job! Thanks for posting the pictures.
rickeieio Posted April 6, 2017 Report Posted April 6, 2017 Chief, If you have some free time, you can do ours too. Nice. KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio@yahoo.com
CHIEFWAHO Posted April 10, 2017 Author Report Posted April 10, 2017 Thanks for the compliments all! Pretty well have it wrapped up! Gathering all my documentation to present at court house on getting it titled/registered as a Recreational Vehicle in Kansas. Relocated exhaust stack brackets ARB fridge/freezer 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator.
CHIEFWAHO Posted April 25, 2017 Author Report Posted April 25, 2017 Finally got this today, 3rd time (to the county treasures office) was the charm ! 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator.
oldride Posted April 25, 2017 Report Posted April 25, 2017 On the couch was this from a van or didi you use something like a futon sofa? 2011 CAN-AM Spyder Rt SE5, 2010 Alpine 5th wheel, 1998 Vovlo VNL610 Hopefully 2 years 6 month till full time retirement.
oldride Posted April 25, 2017 Report Posted April 25, 2017 Forgot to congratulate you on the registration. 2011 CAN-AM Spyder Rt SE5, 2010 Alpine 5th wheel, 1998 Vovlo VNL610 Hopefully 2 years 6 month till full time retirement.
CHIEFWAHO Posted April 25, 2017 Author Report Posted April 25, 2017 1 hour ago, oldride said: On the couch was this from a van or didi you use something like a futon sofa? Not sure what it is or out of. Was already there when we purchased truck. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator.
CHIEFWAHO Posted June 20, 2017 Author Report Posted June 20, 2017 The back wall unit performed great. Just returned from a 10 Jeep trip. Slept in the truck and couple nights and ran the unit A/C on shore power. It will flat freeze you out if need be. It is a little loud & do wish it had adjustable fan speeds. And yes I was hauling a full size refrigerator on the truck. I loaded it with pre-cooked BBQ and fed about a 100 of my Jeep friends one evening. Plus it's handy to keep several beers cold! Parked one evening at Moss Field, Webster Groves, MO. Cousin is the head football coach. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator.
Sculptor Posted June 21, 2017 Report Posted June 21, 2017 Very "Cool" Chief! Recently I was looking at a 610 or 630 and I thought I would have to have those side windows. Nice job!! Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3
Pete Kildow Posted August 21, 2017 Report Posted August 21, 2017 Could you get more pics of how that generator is mounted in your bed? Also on the sound deadening stuff. I have good luck with Peel-Seal-Instant-Waterproof-Repairs-6-in-x-25-ft-Aluminum-Roll-Flashing Its priced good. And I put it on the doors of my Koidak. And it went from sounding like a tin can. To solid and 75% quieter then before. Pete
maveric Posted August 21, 2017 Report Posted August 21, 2017 I would like to see more on the gen mounting as well. I purchased a 6500 Onan a couple months ago, but haven't decided where I want to mount it. New ideas are good. Chris & Tonya '99 Freightliner FLD120, '01 Wabash Toyhauler (32' garage, 20' LQ)
