thru air reception ?
My toyhauler has a little antenna on the roof that looks like a pancake . Can not figger it out ! We plug it in to TV and turn the green lite on the antenna amplifier box to on , nuttin happens , lite on, lite off makes no diff. What am I doing wrong , directions say plug it into TV , turn green amplifier lite on ,Nothing happens !
That "pancake" is an omni-directional TV antenna. Knowledgeable antenna folks often describe omni's as "equally bad in all directions", so you may not be close enough to any TV towers to get a usable signal.
Dutch
2001 GBM Landau 34' Class A
you might have to scan your tv to over the air signal in the settings section
It's not a question of MIGHT having to let your TV scan for signals. All digital TVs have to go through a signal scan in order for them to find available channels anytime they are first turned on in a new location. If you're not doing this then you will always have a blank screen. Depending on your TV brand and model, go to Settings/Antenna/Scan for channels or something like that.
Sandie & Joel
WiFiRanger Ambassador
Not necessarily. On my TV, if I had a channel 6 at the last location and there is a channel 6 at the new location I will get the new one without scanning.
If your TV is an older one it may require a converter box to convert today's digital format to something the TV can handle.
Clay(WA5NMR), Lee(Wife), Katie & Kelli (cats)
Full timed for eleven years in our 2004 Winnebago Sightseer 35N Workhorse chassis. Snowbirds for 1 year. Now settled down in western CO.
Honda Accord toad.
Only if both TV stations are physically transmitting on RF Channel 6.
In the analog age, the RF channel was the same as the station's advertised channel. Channel 2 transmitted on the physical RF Channel 2 and you selected it by tuning the TV set to Channel 2.
This went away with the switch to digital TV. The vast majority of the new digital signals wound up on UHF channels, sometimes changing channel locations 2 or even 3 times as the band consolidated. To avoid consumer confusion and placate the furious VHF stations that were aghast at losing the coveted low channel numbers that they prominently featured in their advertising for many years the FCC came up with a scheme called "Virtual Channels"
TV stations would continue to advertise as being on their original channel (i.e. Channel 2), even though their digital transmission is actually on another channel (i.e. UHF Channel 36).
In order for the TV to know to look on UHF Channel 36 when you tune it to Channel 2, the TV has to do a Channel Scan when it's first powered up or moved into a new area. It scans the entire TV band, memorizing the RF and Virtual channel numbers for every station it finds. Then it can tune to the actual RF channel (36) when you select the Virtual Channel (2).
