dsimpson Posted September 9, 2016 Report Share Posted September 9, 2016 I finally decided to replace my Tire Pressure Monitoring System and went with the TST 510 after getting some recommendations here: http://www.rvnetwork.com/index.php?showtopic=120264 I went through Dutch and Di and was very pleased with the service I received. When I started reading through the installation procedures, I was surprised by the differences between the TST 510 system and the Pressure Pro system. On my old Pressure Pro system, when the installation process is initiated, a sensor, any sensor, is installed on the tire indicated on the monitor. Then the installation proceeds to the next tire. After all sensors have been installed, you are done. The sensor accepts the current tire pressure as the baseline pressure and the maximum and minimum pressures are preset around the baseline and cannot be changed. For both the Pressure Pro and TST systems, all tires must be properly inflated. On the new TST 510, a 4 digit code, read from the individual sensors, must be entered for each tire position. This code and tire position must be written down to provide a guide when the sensors are installed. Then, each axle requires the entry of a minimum and maximum pressure. Then, the maximum temperature must be entered but the default can be accepted, which is recommended. Entering the minimum pressure may be a good thing because, each year, I had to remove and reinstall one or more of my Pressure Pro sensors when the cool weather caused the morning pressure to drop below the minimum. When I installed the Pressure Pro sensors on the front wheels, I had to use a Dremel tool and grinding bit to enlarge the hole in the tire skin before the sensor would fit. The TST sensors are 2 mm wider than the Pressure Pro sensors as measured with my micrometer so I must enlarge the hole on the tire skin even further. Even then, the TST sensor comes in contact with a thick wire that circles around the circumference of the tire skin to brace and reinforce the skin. The TST sensors are theft resistant and require a special wrench to install and remove. This theft resistant feature is appealing but no sensors were stolen during the 5 years I had the Pressure Pro system. Installation on the rear dual wheels is not going to be easy using the wrenches unless I remove the outside wheel. And removing one of these sensors from there will be even more difficult - trying to get that wrench fitted around the sensor is going to be a challenge unless I remove the outside wheel. How have you dealt with these last two issues? Link to comment Share on other sites More sharing options...
Jack Mayer Posted September 9, 2016 Report Share Posted September 9, 2016 My sensors do not require an id code for each sensor. In addition, I specified I did NOT WANT and would not ACCEPT the security devices. So I don't have those issues. The tire liner clearances are simply part of the use of any device like this. I don't have the issues because I have aluminum wheels. I REALLY like my TSTs. They perform much better than the PP did, especially the newer PP sensors which seem to be particularly flakey. Link to comment Share on other sites More sharing options...
MrSeas Posted September 9, 2016 Report Share Posted September 9, 2016 "How have you dealt with these last two issues?" These might help..... http://www.dualdynamics.com/products/cross-fire/ Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted September 9, 2016 Report Share Posted September 9, 2016 I have the Crossfire on my rear duals. Works great with the extra stems for the TST monitors. They do read different temps based on conditions. If the outer tire is in the sun, it will read a higher temp than the inner. Might be the same pressure though. Being able to adjust pressure on 2 tires from 1 stem is great. Link to comment Share on other sites More sharing options...
SCClockDr Posted September 9, 2016 Report Share Posted September 9, 2016 I found I was able to thread the 510 sensors onto the inner & outer wheels just fine. I reached in through an adjacent wheel hole & only used the wrench to tighten near the end of installation. I cut down the solid SS wrench to be just a bit proud of the end of the sensor. I recently upgraded to the TST-507 flow-thru system. Its been over a year without issues on this model & still on the original batteries. I gave our SIL the 510 system. Link to comment Share on other sites More sharing options...
remoandiris Posted September 10, 2016 Report Share Posted September 10, 2016 Installation on the rear dual wheels is not going to be easy using the wrenches unless I remove the outside wheel. And removing one of these sensors from there will be even more difficult - trying to get that wrench fitted around the sensor is going to be a challenge unless I remove the outside wheel. How have you dealt with these last two issues? I'd just get long stems for the inner rear wheel. I went with the flow thru sensors for my 5er. I'll likely buy more sensors when I get new tires for my truck and metal stems all around, with long stems for the inner rear wheels. Link to comment Share on other sites More sharing options...
rbertalotto Posted September 10, 2016 Report Share Posted September 10, 2016 I simply removed the security she'll. Very small Philips head screw driver required. Other than that, no install issues. This system takes forever to find the sensor once you start the vehicle. It has taken up to a half hour to find all 8 sensors on my truck and trailer. I have the monitor hard wired into the electrical system on my truck and I leave it on all the time . I've left the truck for upwards of two weeks with no battery drain. Link to comment Share on other sites More sharing options...
dsimpson Posted September 11, 2016 Author Report Share Posted September 11, 2016 I completed the installation. I was able to install the sensors on the rear duals without removing the outside wheel but it was not easy. There was barely enough room for my fat hands and the wrench kept falling off. Maybe I'm just a klutz. I could have bent the wrench for a tighter fit. But I took comfort in knowing that the casual thief will not be able to remove them. I enlarged the holes in the front tire skins. This was pretty easy since the skins are plastic and not metal and I had a dremel tool with a drum sanding bit. My latest tire incident occurred recently on highway SR 28 between Salmon, ID and Rexburg, ID, out in the middle of nowhere, no cell phone service, no shoulder to pull off the road and I am towing. The Pressure Pro monitor indicated a leak on an inner dual rear wheel and the pressure is dropping fast. I limped to the next turn-out at 20 mph and discovered that the problem was the sensor itself. It was leaking air. I didn't discover this until I installed the spare, put the sensor on the spare, and noticed the same problem with the spare. I was able to quickly remove the sensor from the spare before too much air leaked out. Otherwise, I would have had two flat tires and been stranded for hours waiting for a service truck (no cell phone service, remember?). That's why I am so concerned with how easily and quickly I could remove a TST sensor. This was the second Pressure Pro sensor that had a problem with air leaks. Link to comment Share on other sites More sharing options...
Dutch&Di Posted September 11, 2016 Report Share Posted September 11, 2016 I simply removed the security she'll. Very small Philips head screw driver required. Other than that, no install issues. This system takes forever to find the sensor once you start the vehicle. It has taken up to a half hour to find all 8 sensors on my truck and trailer. I have the monitor hard wired into the electrical system on my truck and I leave it on all the time . I've left the truck for upwards of two weeks with no battery drain. Just wanted to make 2 comments. The 507 system has the sensors where the outer shell can be removed. The 510 that Doug bought has sealed & completely waterproof sensors so there is no taking anything off. If your system is taking that long to "find" the sensors, you may want to consider getting a repeater. We decided to add a repeater when we bought our 2015 Ram 3500 because of all the "stuff" that could cause interference in the dash. The added bonus was the monitor definitely found the sensors much faster. I will also help prevent a sensor from just disappearing once in awhile. Just a thought. Hugs, Di Link to comment Share on other sites More sharing options...
Dutch&Di Posted September 11, 2016 Report Share Posted September 11, 2016 I completed the installation. I was able to install the sensors on the rear duals without removing the outside wheel but it was not easy. There was barely enough room for my fat hands and the wrench kept falling off. Maybe I'm just a klutz. I could have bent the wrench for a tighter fit. But I took comfort in knowing that the casual thief will not be able to remove them. I enlarged the holes in the front tire skins. This was pretty easy since the skins are plastic and not metal and I had a dremel tool with a drum sanding bit. My latest tire incident occurred recently on highway SR 28 between Salmon, ID and Rexburg, ID, out in the middle of nowhere, no cell phone service, no shoulder to pull off the road and I am towing. The Pressure Pro monitor indicated a leak on an inner dual rear wheel and the pressure is dropping fast. I limped to the next turn-out at 20 mph and discovered that the problem was the sensor itself. It was leaking air. I didn't discover this until I installed the spare, put the sensor on the spare, and noticed the same problem with the spare. I was able to quickly remove the sensor from the spare before too much air leaked out. Otherwise, I would have had two flat tires and been stranded for hours waiting for a service truck (no cell phone service, remember?). That's why I am so concerned with how easily and quickly I could remove a TST sensor. This was the second Pressure Pro sensor that had a problem with air leaks. Doug, I'm happy to hear you completed you install. It is hard trying to help, clarify or explain things via e-mail but I'm glad you are all set up. Should you need me, I'm available 10 am to 10 pm 7 days a week {pacific time right now} at 941-416-0918. Hugs, Di Link to comment Share on other sites More sharing options...
Dutch&Di Posted September 11, 2016 Report Share Posted September 11, 2016 I simply removed the security she'll. Very small Philips head screw driver required. Other than that, no install issues. This system takes forever to find the sensor once you start the vehicle. It has taken up to a half hour to find all 8 sensors on my truck and trailer. I have the monitor hard wired into the electrical system on my truck and I leave it on all the time . I've left the truck for upwards of two weeks with no battery drain. sorry-fast fingers make for a double post. Hugs, Di Link to comment Share on other sites More sharing options...
Ray,IN Posted September 12, 2016 Report Share Posted September 12, 2016 When I put the inner dual sensors on, I could fit my hand between the duals and tighten the sensor. The TST system will recognize each sensor when installed if you put the monitor in your shirt pocket then follow installation directions. Do not carry more than 1 at a time near your vehicle when installing to avoid having the monitor pick-up the wrong one. I bought my first TST system from Dutch and Di in 2006(I think). I've have to replace sensors due to battery expiration, other than that it still works great. Don't need it now, I upgraded to the 507 truck system, which also works great. Link to comment Share on other sites More sharing options...
lappir Posted September 12, 2016 Report Share Posted September 12, 2016 I tried the PP, but was not happy. Am going with Crossfire before my next trip to Florida on all my Dual wheel sets. (I have six). I know it's not imperative that each tire has the exact to the pound pressure with each set but the closer the better I think. Ease of putting a gauge on them is my main priority. I check the pressure before each trip and at each stop I use my temperature sensor to check the temps of each tire. So far have found no significant issues so no need to check the pressure of a "Hot" tire. With the pressure monitoring system I got a low pressure alarm, stopped found the tires to be fine but stuck a gauge on one of the inside duals on the truck and the valve core stuck. The aluminum wheels and their tiny holes prevented me from being able to reach the core to change it out. (yes I had the tool and a new core) $100 later with the service truck coming to remove the outside tire remove the core and replace the tire I ordered steel wheels with real hand sized holes. Should have done the crossfire then, but my brother doesn't like them and he's my tire guy. Going to broach the subject again this morning. Rod By the way, the tire pressure was fine until the core stuck. Gauge and temperature are my pressure monitors. There isn't anything that will prevent a blowout if it's going to happen. Especially if you have checked your tires before and during the trip. My opinion. RL Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted September 12, 2016 Report Share Posted September 12, 2016 I had a tool for putting the inner dual PressurePro sensors on the Volvo. It is made with 1" PVC pipe and a 1" PVC connector. The connector on the end of the pipe gets a friction grip on the sensor and it fits through the wheels just fine. The new Bounder came with high quality valve extenders. Link to comment Share on other sites More sharing options...
Jack Mayer Posted September 12, 2016 Report Share Posted September 12, 2016 Doug, I'm glad you got it worked out. I used Pressure Pro for many years, and were with them from the beginning. In recent years I had a LOT of trouble with them both leaking, and not "coming in" on the monitor. I tried ALL the fixes, over the course of a year or more. I never could get a reliable setup from the newer sensors. The last straw was when one of the sensors caused a flat tire on my trailer. That is when I switched to TST. I have not had any real issues since....although one of my TSTs does leak a little (like one psi a day)....I'll put a new O ring in it before leaving here. Link to comment Share on other sites More sharing options...
richfaa Posted September 12, 2016 Report Share Posted September 12, 2016 We have had both PP and Now TST no problems in any way with either system. Link to comment Share on other sites More sharing options...
