Front end is all over the road
maggie blair
  • Replies 84
  • Created
  • Last Reply
How long have you been driving a motorhome? If you are new to motorhomes it is very easy to over steer which can be just like what you are describing. My suggestion is to lower your steering wheel as far as possible, plant your elbows on your thighs and grip the wheel at a low to middle point. This locks your elbows and limits your wheel turing abilities thus reducing over steer.
As the others have mentioned, get your motorhome weighed and tires inflated properly as well.
Is the motorhome perhaps overloaded in the rear, causing too little weight on the front end. This would make the steering less effective and seem like there is a mechanical issue.
All the other suggestions are right on also. It really will take finding the cause before being able to understand what will correct it.
If you can't, get someone to check the steering linkage, that's tie rod ends, drag links, that stuff. All the parts that move when you steer There should be no play in the connecting points. Things get loose as they wear out, but then they break. Get it checked now. Before you drive further.
Mileage on that unit?
Yes, basics first then bolt on aftermarket solutions. Proper type tires, properly inflated. Alignment. All bushings, tie rods, steering box, sway bars etc etc. If everything is up to spec (which I bet you it isn't) per original design there's some aftermarket stuff.
Take it to a decent shop.
Thanks so much!
What kind of motor home is it? What chassis? Some have known issues that can be addressed.
I have a 2007, 26 ft Fleetwood Fiesta with 8000 miles and this thing is awful to drive! I won't be going full-time till July 1st but would sure like to get this resolved before I hit the road.
An Rv place here in Redding quoted me around 5000.00 to get it shored up. That would take care of the sway. I am a bit concerned about the price and everything he mentioned. One of the neighbors in the RV park looked under the coach and he said a bushing is leaking. I am not mechanically inclined so I guess I will have to take it to a shop and have them go over everything.
I put new tires on the rig and they charged me for balancing the tires but the tires do not have those little metal things anywhere in sight so I am confused on that one too.
Have had several Chevy chassis class A,s. (P30)
Check front sir bags. PSI should be about 70 to stiffen up the coil springs. Big reason front end floats.
I installed Steer Safe on my MH,s.
Check to see if after market air bags were installed on rear end.
Where are fresh water and waste tanks. If too close to rear end. They can make front end float if too full.
Henderson's in Grants Pass, a days drive from Redding, is a good place to take your rig. They have a good reputation for being honest and should give you good advice about things like the leaking bushing someone told you about. Make an appointment. They will let you park in their parking lot with 30amp elect the night before your appointment.
Keep in mind the add on things which have been suggested by others who have replied, will probably help, but are not cheap. If you add everything which is available you are looking at some $3000 to $5000 in add on's.
Henderson's will also probably recommend you install the add on's, but they won't sell you lots of repairs you don't need. They should give you very good evaluation of the status of your suspension.
Many people swear that these add on's have fixed all the handling problems.
I believe its a Chevy. It says Vortec and someone said that's a Chevy. ????
Yes the Vortec engine means it is a GM product (Chevy). The bow tie Chevy symbol should be obviously displayed in several places, like the grill and center of the steering wheel.
Get someone to wiggle the steering wheel while you watch the joint just above the steering box. I'll bet $$ v. doughnuts the problem is right there.
Is the joint just above the steering box easy to find?
Maggie,
I strongly recommend you find a honest professional to assist you. While checking the steering joints are not difficult, you do need to have a very good idea of what you are looking at and just how much play is normal and how much is a problem.
I don't mean to keep harping on Henderson's but they have a very good reputation with RV'ers. We took our 29' class A Winnebago to them and were well treated. We didn't buy all the add on products they suggested, but did buy the ones I felt would help in my specific case.
