DJW Posted January 12, 2016 Report Share Posted January 12, 2016 So is there a way to see what your hard drive is writing. I noticed while I was watching the FB game tonight that my HD light was just flashing away. I was not online and no Win 10 updates showed up? Nothing else that I am aware of would download updates without me saying ok. Thoughts Thanks Dennis Link to comment Share on other sites More sharing options...
RV_ Posted January 12, 2016 Report Share Posted January 12, 2016 You were not online but left your computer on and the modem connected? Turn the computer off! It could have been doing a scan of some sort? I shut down my systems when done with them except for the Surface Pro Tablet that sits by the recliner all day but is shut down when the battery gets below 15% or so. It is still new enough to be conditioning it for deepest cycles. Link to comment Share on other sites More sharing options...
DJW Posted January 12, 2016 Author Report Share Posted January 12, 2016 RV I never shut the laptop down during the day. I turn it off at night. I always log off the net when I am not using it. Dennis Link to comment Share on other sites More sharing options...
gypsydan Posted January 12, 2016 Report Share Posted January 12, 2016 RV - Check the settings for indexing, as your OS might also have been indexing the drive. Link to comment Share on other sites More sharing options...
DJW Posted January 12, 2016 Author Report Share Posted January 12, 2016 gyspydan What is indexing and how do you check for it? Dennis Link to comment Share on other sites More sharing options...
Pat & Pete Posted January 12, 2016 Report Share Posted January 12, 2016 I use to use a little program called "What's Running" . It showed just that , what was running at the moment . I'm not sure if it would work on W7 or later . Now I just use Iobit : Advanced System Care 9 . I'm sure there's something better out there , but this is pretty good for being free . Link to comment Share on other sites More sharing options...
lenp Posted January 13, 2016 Report Share Posted January 13, 2016 Open Task Manager and see what process(es) are using the hard drive. Lenp Link to comment Share on other sites More sharing options...
wildmandmc Posted January 13, 2016 Report Share Posted January 13, 2016 your HD could be just thinking, as its waiting for next job/command Link to comment Share on other sites More sharing options...
gypsydan Posted January 14, 2016 Report Share Posted January 14, 2016 gyspydan What is indexing and how do you check for it? Indexing creates a table of contents (data base) of words on your hard drive. open Control panel and click on Indexing Options to see what is being indexed. also you can google hard drive indexing for more info. You can also check windows help and read about indexing. http://www.techrepublic.com/forums/questions/what-exactly-is-indexing-a-drive/ Link to comment Share on other sites More sharing options...
Al F Posted January 14, 2016 Report Share Posted January 14, 2016 Open Task Manager and see what process(es) are using the hard drive. Lenp How do your use Task manager to see the usage for the hard drive?? I see CPU usage & memory usage, but I don't see a option to see the Hard Drive usage. I am running Windows 7. Link to comment Share on other sites More sharing options...
skunk workz Posted January 14, 2016 Report Share Posted January 14, 2016 How do your use Task manager to see the usage for the hard drive?? I see CPU usage & memory usage, but I don't see a option to see the Hard Drive usage. I am running Windows 7. Go to the Performance Tab, and click on the Resource Monitor button at the bottom. In Resource Monitor there is a Disk tab that shows what apps are reading and writing to the disk at any point in time. Link to comment Share on other sites More sharing options...
wildmandmc Posted January 15, 2016 Report Share Posted January 15, 2016 Ctrl Alt Del gives option for task mang. Link to comment Share on other sites More sharing options...
Al F Posted January 15, 2016 Report Share Posted January 15, 2016 Go to the Performance Tab, and click on the Resource Monitor button at the bottom. In Resource Monitor there is a Disk tab that shows what apps are reading and writing to the disk at any point in time. Many thanks. I frequently use task manager when things aren't working the way I think they should be, but never knew I could use task manager to see the hard drive, network, etc. Link to comment Share on other sites More sharing options...
RV_ Posted January 15, 2016 Report Share Posted January 15, 2016 Al, I reduce it to the taskbar on all my computers and pin it. It makes it easy if you suddenly think something is downloading or trying to or you just think the drive is running wrong in use only to just click it and stop whatever browser you are using which cuts the cord. When I shut it down it is back on the task bar. I use it a lot for all of the above. For those confused just click more detail;l at he bottom of the small task manager screen in Windows 8.1 and 10, and all the options appear. Link to comment Share on other sites More sharing options...
