Shulamite Posted May 4, 2015 Report Share Posted May 4, 2015 We have a Cat 400 hp engine that needs an oil change. It's a 2005 Newmar Dutch Star. We are in Redding CA. and got a $600. quote. Is that average? Link to comment Share on other sites More sharing options...
Ranger Smith Posted May 4, 2015 Report Share Posted May 4, 2015 For $600 I will change your oil. No that is not normal. I usually do my own but I believe for a RV it is usually $199 Steve and Joy Amateur Radio Operator WZ1T . . . Flex 6600 M, Flex PGXL, Flex TGXL, 2014 Itasca Suncruiser 38Q . . . Lincoln MKX Toad The Kids . . . Yogi the Yorkie passed 10/20/2018. . . Cookie the Chihuahua passed 11/30/2017 . . . Cooper the Aussie Doodle passed 3/10/2020 Abbie and Abel the Doodles . . . Brother and Sister Born 02/02/2020 . . . Lucy the Yorkie . . . and Axel . . .The Bernie Doodle Where We Are Now Link to comment Share on other sites More sharing options...
Jimalberta Posted May 4, 2015 Report Share Posted May 4, 2015 Dont pay that its a rip off rate. It means they really dont want to do it. <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
Shulamite Posted May 4, 2015 Author Report Share Posted May 4, 2015 Thanks guys. It's Catapillar on Catapillar St. in Redding. I don't know if it's synthetic, that may be why it's so high. Link to comment Share on other sites More sharing options...
MrSeas Posted May 4, 2015 Report Share Posted May 4, 2015 Have you tried Speedco? You have a few close by! Link to comment Share on other sites More sharing options...
sushidog Posted May 4, 2015 Report Share Posted May 4, 2015 Wow that's high. I'd change the oil in this cat for $600! Chip Link to comment Share on other sites More sharing options...
JRP Posted May 4, 2015 Report Share Posted May 4, 2015 for that size engine, Cat C9, it takes almost 10 gal of oil; so even at current Walmart prices for Rotella 15w40, that's almost $200 just for the oil material cost, plus a $20 filter, plus an hours labor and markup. I would say the avg cost for just the basic C9 oil & filter change is around $300 - $350 at a typical truck shop; more if you ask for other services added to the oil change. its not surprising that a Cat factory shop price would be significantly higher and they may have been quoting a service "package" that includes a few additional services. Jim Link to comment Share on other sites More sharing options...
aunut Posted May 4, 2015 Report Share Posted May 4, 2015 for that size engine, Cat C9, it takes almost 10 gal of oil; so even at current Walmart prices for Rotella 15w40, that's almost $200 just for the oil material cost, plus a $20 filter, plus an hours labor and markup. I would say the avg cost for just the basic C9 oil & filter change is around $300 - $350 at a typical truck shop; more if you ask for other services added to the oil change. its not surprising that a Cat factory shop price would be significantly higher and they may have been quoting a service "package" that includes a few additional services. 10 gallons? Wow! I thought 8 quarts was a lot in my gasser. 2014 Winnebago Vista 35B Class A. 2010 Honda CR-V. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted May 4, 2015 Report Share Posted May 4, 2015 LOL, my Freightliner DD13 takes 43 quarts and a DD15 will soak up 47 quarts.... That's one of the reasons the oil change intervals are 35,000 to 50,000 miles depending on how you use the truck. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
aunut Posted May 4, 2015 Report Share Posted May 4, 2015 LOL, my Freightliner DD13 takes 43 quarts and a DD15 will soak up 47 quarts.... That's one of the reasons the oil change intervals are 35,000 to 50,000 miles depending on how you use the truck. So, actually, you use less oil than I do, since mine is changed every 5,000. This makes more sense. I will use 20 gallons every 50,000. 2014 Winnebago Vista 35B Class A. 2010 Honda CR-V. Link to comment Share on other sites More sharing options...
jc2 Posted May 4, 2015 Report Share Posted May 4, 2015 Schulamite, What is the list of things that they would do for that price? When the Cummins-Onan service center does the pm service on our 370 ISL Cummins, which holds 24 qts, it runs in the $300-400 range. Cummins uses a good quality of regular dino oil for diesels, 15w-40, oil filter, (2) fuel filters, chassis lube, Onan diesel genie service(7.5kw), anti-freeze checked for proper additive level, etc. It will always be cheaper if you DIY but not always convenient. I also don't believe that synthetic oil is superior enough to warrant its price and to justify its use when somewhat frequent chances are done. 2010 Newmar Dutch Aire 4304-Spartan Chassis-Cummins ISL 425hp-2013 Chevrolet Equinox AWD Towed-SKP# 120487-FMCA #402879- Link to comment Share on other sites More sharing options...
PeteSKP Posted May 4, 2015 Report Share Posted May 4, 2015 Don't think of it as an "oil Change". Done correctly it is much more. My ISX service at 70mi was about $1400; Change engine oil (I use semi-synthetic @ 10,000 mile intrervals), Change Transmission with Allison Stnthetic fluid, chage air cleaner ($200+), Oil Filet, Fuel Filter,service air dryer, lube & check several chassis & brake parts. Want to play? you gotta pay! --Peter & Anne-Marie Arnold, Full-timers since 2011The National Camping Travelers, Camping Group for Masonic Families2004 Bounder 38N, Diesel Pusher 2005 Toyota RAV4, 4cyl, Stick 500W of Solar with seldom used generator. Link to comment Share on other sites More sharing options...
docj Posted May 4, 2015 Report Share Posted May 4, 2015 for that size engine, Cat C9, it takes almost 10 gal of oil; so even at current Walmart prices for Rotella 15w40, that's almost $200 just for the oil material cost, plus a $20 filter, plus an hours labor and markup. I would say the avg cost for just the basic C9 oil & filter change is around $300 - $350 at a typical truck shop; more if you ask for other services added to the oil change. its not surprising that a Cat factory shop price would be significantly higher and they may have been quoting a service "package" that includes a few additional services. My Cat C-12 takes 36 quarts of oil (9 gals). I seriously doubt that a C-9 uses 40 quarts. But I've never paid that much for an oil change. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
Ranger Smith Posted May 4, 2015 Report Share Posted May 4, 2015 My Cat C-12 takes 36 quarts of oil (9 gals). I seriously doubt that a C-9 uses 40 quarts. But I've never paid that much for an oil change. A C-9 takes 34 quarts or 8.5 gallons Steve and Joy Amateur Radio Operator WZ1T . . . Flex 6600 M, Flex PGXL, Flex TGXL, 2014 Itasca Suncruiser 38Q . . . Lincoln MKX Toad The Kids . . . Yogi the Yorkie passed 10/20/2018. . . Cookie the Chihuahua passed 11/30/2017 . . . Cooper the Aussie Doodle passed 3/10/2020 Abbie and Abel the Doodles . . . Brother and Sister Born 02/02/2020 . . . Lucy the Yorkie . . . and Axel . . .The Bernie Doodle Where We Are Now Link to comment Share on other sites More sharing options...
Raquel Posted May 8, 2015 Report Share Posted May 8, 2015 I second going to Speedco. There's one down in Corning that we use. Trish & Raquel -------- "Road Runner" -- 2005 Volvo VNL780, 500hp Cummins ISX, Ultra-Shift, ET-Hitch, 198" wb "Wile E." -- 2013 Heartland Landmark San Antonio Link to comment Share on other sites More sharing options...
Jimalberta Posted May 8, 2015 Report Share Posted May 8, 2015 What does Speedco cost you? <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted May 8, 2015 Report Share Posted May 8, 2015 Should be $250 plus local taxes for Speedco. Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
horizon36 Posted May 9, 2015 Report Share Posted May 9, 2015 I usually get mine serviced at the FMCA rally in Indio every January by Jim Fulkerson service. My CAT 3126E takes 22 Qts of oil. Last service he did the engine oil, filter, fuel filter, transmission and filters, genset oil & filter and lubed the chassis. Costs $700 plus tax. Full time since August 2010 2002 Itasca Horizon One fur kid - a Shih-Tsu rescue Jeep Grand Cherokee Ltd Link to comment Share on other sites More sharing options...
Medico Posted May 9, 2015 Report Share Posted May 9, 2015 for that size engine, Cat C9, it takes almost 10 gal of oil; so even at current Walmart prices for Rotella 15w40, that's almost $200 just for the oil material cost, plus a $20 filter, plus an hours labor and markup. I would say the avg cost for just the basic C9 oil & filter change is around $300 - $350 at a typical truck shop; more if you ask for other services added to the oil change. its not surprising that a Cat factory shop price would be significantly higher and they may have been quoting a service "package" that includes a few additional services. Excuse me but my C13 (525 HP Cat) only takes 34 qts (less than 9 gallons). That's how much the oil change was at Alliance coach. GS Lifetime #822128658, FMCA #F431170 2012 Airstream Mercedes Interstate Extended Class B Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 9, 2015 Report Share Posted May 9, 2015 Cat says 33.8 qts. Scroll down a bit. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Medico Posted May 10, 2015 Report Share Posted May 10, 2015 Damn, they did not return my 0.2 qts. They must have overfilled the crankcase. LOL GS Lifetime #822128658, FMCA #F431170 2012 Airstream Mercedes Interstate Extended Class B Link to comment Share on other sites More sharing options...
