HamRad Posted January 23, 2016 Report Share Posted January 23, 2016 I finally got tired of my trailer tires (5th wheel) blowing out so have installed some heavier duty tires. I now have G614's on my rig. Told the installer that I wanted to run around 80psi in tires. I had my trailer recently weighted and 80 pounds was appropriate for the trailer weight. Installer said that the 614's are recommended to run ONLY at the 110psi. So I'm wondering whether the dealer is correct and I should run the tires only at 110psi? Or should I run a pressure that is more appropriate to the actual weight of the trailer? Thanks for any input. Dennis Trailer: Montana 5th wheel, model 3582Rl, model year 2012 Truck: Ford 450 PSD Super Duty, 2002 Crew Cab, Long bed, 4:88 rear end, last of the 7.3 engines, Automatic Transmission. Link to comment Share on other sites More sharing options...
wildmandmc Posted January 23, 2016 Report Share Posted January 23, 2016 110psi, seems totally off the chart. i have class a with 295/80/22.5 an run them at 105psi. tire calls for 115. i have always run tires be it on cars trucks ect about 10 below max. on your tire does it say max psi = 110. if so i would keep it 95-100. 2000 Itasca Horizon DP (Got Total During Irma). Vice President of Charlotte County Defenders LE MC http://charlotte.defenderslemc.com/ Link to comment Share on other sites More sharing options...
Al F Posted January 23, 2016 Report Share Posted January 23, 2016 Browse through this Tire Safety website for what he has to say about tire pressure. Basically, he says to weigh your vehicle, consult the tire MFG tire pressure charts for what pressure the tire should be for the measured weight on the tire and then to add about 10 pounds for an additional safety factor. The additional 10 pounds allow for the normal month by month decrease in pressure w/o dropping below the minimum pressure needed. Also any slow leak occurring in a few hours of travel can be caught before dropping below the safe pressure. Al & Sharon 2006 Winnebago Journey 36G 2020 Chevy Colorado Toad San Antonio, TX http://downtheroadaroundthebend.blogspot.com/ Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted January 23, 2016 Report Share Posted January 23, 2016 The answer is to find how much weight is on each tire by having your rig weighed by wheel. This is important as your trailer weight is seldom distributed evenly. Then you have a value to work from. Every tire has a table for the inflation pressure for a tire weight load. That is the pressure to use. The recommendation to run at Max Psi rating, which is 110 psi for B614's, is what you do for do for low end tire, 14's,15's, etc. Not for G614s. Running over the needed pressure will convex your thread and wear out the center tread. Running over the needed pressure will concave your thread wearing out the edged of the thread. Also, under pressure will cause excessive flexing of the sidewalls causing early tire failure. Running 10 psi under Max psi as a guideline doesn't take tire weight load into account. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
Fulltimer51 Posted January 23, 2016 Report Share Posted January 23, 2016 The pressure you use may also be dependent on the max pressure rating of the wheels. George2011 F350 6.7PSD CC 4X4 DRW Lariate2015 Mobile Suites 41 RSSB4 5th Wheel Link to comment Share on other sites More sharing options...
wildmandmc Posted January 23, 2016 Report Share Posted January 23, 2016 ft51 that's what i go by -10psi 2000 Itasca Horizon DP (Got Total During Irma). Vice President of Charlotte County Defenders LE MC http://charlotte.defenderslemc.com/ Link to comment Share on other sites More sharing options...
chirakawa Posted January 23, 2016 Report Share Posted January 23, 2016 The pressure you use may also be dependent on the max pressure rating of the wheels. ft51 that's what i go by -10psi So, you fill your tires to 10 psi less than the wheel rating? That's not very wise and very bad advice. If I did that, I'd be filling my 80 psi max pressure tires to 115 psi. Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
gjhunter01 Posted January 23, 2016 Report Share Posted January 23, 2016 Get a tire monitor system installed and you will see that your tire pressure can increase by 20 psi running down the road. I also ran 110 psi and was blowing out tires (5), after the monitor system was installed I discovered the tires were going up to 135 psi. I now run 95 cold psi and get 115-120 psi going down the road and have had no blow outs in 7 months. Time will tell as this is a experiment in progress. Greg Link to comment Share on other sites More sharing options...
NH2 Posted January 23, 2016 Report Share Posted January 23, 2016 I agree with Mark. Individual tire pressure should be based on individual load. The manufacturer's load/inflation table was created by a team of engineers. Any other method is nothing more than a guess. http://www.goodyearrvtires.com/pdfs/rv_inflation.pdf Mark Mark & Sue---SKP#86611 '06 International 4400LoPro DT570 310hp 950ft-lbs.-Allison--3.70 gears '05 36' Teton Liberty '12 BMW F650 twin Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted January 23, 2016 Report Share Posted January 23, 2016 You set your tire pressure "cold" which means the tires haven't moved much. Driving 5 miles to a filling station screws up the "cold" setting. While running, the tire pressure will rise and may well climb over the Max psi if you fill near to that level. 10-20 psi is normal. You do reset the tire pressure when hot. Extreme high temperature, +24% or more may be an indication of wheel bearing or brake problems. The tire pressure tables are based on "cold" settings. Settings your tires low so they are at target pressure when hot means your are under-inflating your tires. Weighing is the only method to determine what your tire pressure should be. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
Big Greg Posted January 23, 2016 Report Share Posted January 23, 2016 I totally agree with Mark Bruss. Weight each tire with your rig loaded. Take the highest weight tire and consult the manufacturers air pressure chart and set all the tires based on the heaviest tire. Add about 10 pounds as a safety margin up to the manufacturers max rated pressure. Greg Greg & Judy Bahnmiller Class of 2007 2014 F350 2007 HitchHiker Champagne Both sold 2/19, settled in Foley, AL after 12 years on the road http://bahnmilleradventure.blogspot.com/ Link to comment Share on other sites More sharing options...
TireHobby Posted January 25, 2016 Report Share Posted January 25, 2016 The correct tire inflation pressure for your tires is found on the tire placard and in your vehicle owner's manual. However, when an owner makes a radical change is size and load capacity such as you have it's called "plus sizing". Industry standards says to provide the same or greater load capacity as the original equipment tires. To do that you check a load and inflation chart for your new tires and inflate them (cold) to whatever it takes to provide the load capacity the trailer manufacturer did with the OE tires. 38' fiver - Dodge Dually AKA: FastEagle USN Retired - DOD Retired - SSA Retired Link to comment Share on other sites More sharing options...
WILDEBILL308 Posted January 25, 2016 Report Share Posted January 25, 2016 You set your tire pressure "cold" which means the tires haven't moved much. Driving 5 miles to a filling station screws up the "cold" setting. While running, the tire pressure will rise and may well climb over the Max psi if you fill near to that level. 10-20 psi is normal. You do reset the tire pressure when hot. Extreme high temperature, +24% or more may be an indication of wheel bearing or brake problems. The tire pressure tables are based on "cold" settings. Settings your tires low so they are at target pressure when hot means your are under-inflating your tires. Weighing is the only method to determine what your tire pressure should be. Don't you mean not to re set your tire pressure when hot. The only way I would do that is if you find a tier that is substantially low and need to add air and if you know what your average hot tier pressure is. You could also check another tier to see what it is running and match it. Bill 2008 Newmar Mountain Aire model 4521 450 hp Cummins ISM Allison 4000MH tran. Towing a 2014 Honda CRV with a blue Ox tow bar Home base Fort Worth Texas A man who carries a cat by the tail learns something he can learn in no other way. -Mark Twain- Link to comment Share on other sites More sharing options...
HamRad Posted January 25, 2016 Author Report Share Posted January 25, 2016 Thanks for all the great replies. I understand most of what was suggested. I do have a TPMS on my vehicles. I have weighted both vehicles tire by tire so have a good idea of what weight is on each tire. I have downloaded the Goodyear G614 weight and pressure ratings and have determined that a PSI of between 85 and 90 would be what is needed on my rig. It is good to know that one does not just run at the MAX rating. Again thanks to all. Dennis Trailer: Montana 5th wheel, model 3582Rl, model year 2012 Truck: Ford 450 PSD Super Duty, 2002 Crew Cab, Long bed, 4:88 rear end, last of the 7.3 engines, Automatic Transmission. Link to comment Share on other sites More sharing options...
Fulltimer51 Posted January 25, 2016 Report Share Posted January 25, 2016 So, you fill your tires to 10 psi less than the wheel rating? That's not very wise and very bad advice. If I did that, I'd be filling my 80 psi max pressure tires to 115 psi. I am not sure how you reached that conclusion based on what I said. I referenced the max WHEEL pressure. Some who upgrade to G rated tires forget to check what the max pressure is for the wheel. George2011 F350 6.7PSD CC 4X4 DRW Lariate2015 Mobile Suites 41 RSSB4 5th Wheel Link to comment Share on other sites More sharing options...
chirakawa Posted January 25, 2016 Report Share Posted January 25, 2016 I am not sure how you reached that conclusion based on what I said. I referenced the max WHEEL pressure. Some who upgrade to G rated tires forget to check what the max pressure is for the wheel. No, I didn't reach that conclusion. I was responding to wildmandmc who was responding to your post, so I included both posts so it would make sense. I guess I didn't do a very good job. wildmandmc posted that he set his tire pressure to 10 psi under the wheel rating. Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
57becky Posted January 25, 2016 Report Share Posted January 25, 2016 My 2012 3402 came with the Marathons rated at 80 psi, but were mounted on the 110 psi wheels with a load rating of 3750 lbs. On that year, and others, Montana's had the G614's as an option. With the standard tire, the 7,000 lb axles are de-rated to 6750 lbs, and this due to the tires. With the G rated tire, the axle will be rated to the full 7,000 lbs. I, and most with these heavy rigs run the tires at least 100 psi, and I try to maintain as close to 110 psi as I can. They wear very well at this pressure, and the handling is much improved over the dangerous E range tires that came on these rigs. We went through 5 of the Marathons before upgrading to the G614's. If you don't get the pressure up to or over the 100 psi, you will not gain the maximum axle load ability. At 100 psi, Goodyear rates the tire at 3550 lbs. Link to comment Share on other sites More sharing options...
TireHobby Posted January 25, 2016 Report Share Posted January 25, 2016 My 2012 3402 came with the Marathons rated at 80 psi, but were mounted on the 110 psi wheels with a load rating of 3750 lbs. On that year, and others, Montana's had the G614's as an option. With the standard tire, the 7,000 lb axles are de-rated to 6750 lbs, and this due to the tires. With the G rated tire, the axle will be rated to the full 7,000 lbs. I, and most with these heavy rigs run the tires at least 100 psi, and I try to maintain as close to 110 psi as I can. They wear very well at this pressure, and the handling is much improved over the dangerous E range tires that came on these rigs. We went through 5 of the Marathons before upgrading to the G614's. If you don't get the pressure up to or over the 100 psi, you will not gain the maximum axle load ability. At 100 psi, Goodyear rates the tire at 3550 lbs. Almost correct. The GAWR was set for vehicle certification. It cannot be changed because of tires with more load capacity. Only a certified modifier or the vehicle manufacturer can change a vehicle's GAWR. The certified GAWR was used to set GVWR. 38' fiver - Dodge Dually AKA: FastEagle USN Retired - DOD Retired - SSA Retired Link to comment Share on other sites More sharing options...
Ray,IN Posted January 26, 2016 Report Share Posted January 26, 2016 Confusion causes incorrect settings. Read this pdf from the Rubber Manufacturers Association = RMA. Chapter 4 pertains to RV tires, page 52 states: " However, never use inflation pressure lower than specified by the vehicle tire placard, certification label or owner’s manual. Nor should inflation pressure exceed the maximum pressure molded on the tire sidewall." Both the Michelin and Goodyear websites contain a similar statement. This is what Goodyear says about running less than vehicle mfgrs tire placard pressure: "IMPORTANT: It's a common practice for RV owners to lower tire pressure in their search for a smoother ride. This is not only dangerous, it's relatively ineffective, as the difference in ride quality is not significant. When minimum inflation pressure requirements are not met, tire durability and optimum operating conditions are compromised. Tire inflation pressure should always meet at least the minimum guidelines for vehicle weight." The RMA website states over 80% of all tire failures are due to underinflation/oveloading. I installed oversize tires on my 5er when I too got fed-up with tire failures. So, I installed Sailun load range G tires and eliminated tire problems. I still inflated them to 80#, as that was what the mfgrs tire placard required. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
oscarvan Posted January 26, 2016 Report Share Posted January 26, 2016 Almost correct. The GAWR was set for vehicle certification. It cannot be changed because of tires with more load capacity. Only a certified modifier or the vehicle manufacturer can change a vehicle's GAWR. The certified GAWR was used to set GVWR. He didn't reference the GVWR, he referenced the axle rating. Previously a 2017 Forest River, Berkshire 38A, "The Dragonship". https://dragonship.blog/ Link to comment Share on other sites More sharing options...
KodiakJack Posted January 26, 2016 Report Share Posted January 26, 2016 I run our G614's at 110 psig just like the placard on our rig indicates. So far good wear and no problems. Later, J PS Our TPMS has caught both low pressure and high temperature issues before more damage could occur. The low pressure was a slow leak but brought to my attention a failed brake. The high temp resulted from an blown axle seal that doused the brake with grease. 2012 Landmark, San Antonio 2013 Silverado CC, 3500HD, Duramax, DRW, 4x4 Backup, side and hitch cameras, Tireminder TPMS Link to comment Share on other sites More sharing options...
TireHobby Posted January 26, 2016 Report Share Posted January 26, 2016 He didn't reference the GVWR, he referenced the axle rating. An individual axle has a tag on it showing its actual maximum load capacity from its manufacturer. It is not the official axle rating unless it matches the rating (GAWR) set by the vehicle manufacturer and certified on the vehicle's federal certification label. Its described in FMVSS 571.120 and 49 CFR part 567 - Certification. 38' fiver - Dodge Dually AKA: FastEagle USN Retired - DOD Retired - SSA Retired Link to comment Share on other sites More sharing options...
TireHobby Posted January 26, 2016 Report Share Posted January 26, 2016 However, never use inflation pressure lower than specified by the vehicle tire placard, certification label or owner’s manual. Nor should inflation pressure exceed the maximum pressure molded on the tire sidewall." Inflation pressures on the labels are/were set for the original equipment tires. Replacement tires do not always use the same inflation chart as the OE tires. Industry standards allows the use of auxiliary tire inflation placards for those replacements using inflation pressures different than the OE tires. Such inflation pressures need to provide a load capacity equal to the OE tires. 38' fiver - Dodge Dually AKA: FastEagle USN Retired - DOD Retired - SSA Retired Link to comment Share on other sites More sharing options...
Ray,IN Posted January 27, 2016 Report Share Posted January 27, 2016 Inflation pressures on the labels are/were set for the original equipment tires. Replacement tires do not always use the same inflation chart as the OE tires. Industry standards allows the use of auxiliary tire inflation placards for those replacements using inflation pressures different than the OE tires. Such inflation pressures need to provide a load capacity equal to the OE tires. Yep, that's why I inflated them to 80#. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
