GlennWest Posted May 19, 2020 Report Share Posted May 19, 2020 (edited) I use the commercial truck electrical plug on my fithwheel. and also use air for my Blu dot system brakes. Where you guys hang yours plugs and gladhands.at? I orginally used the plastic one that was on back of truck. Transfered it to Teton pin box. Could not though get all the bolts needed in it and it broke off. Edited May 19, 2020 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
ARGO Posted May 19, 2020 Report Share Posted May 19, 2020 Mine on the truck are within the hitch cutout in the bed. Hoses are mounted on the trailer up thru pin box. Quote You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
rickeieio Posted May 19, 2020 Report Share Posted May 19, 2020 I hang my air hoses from the pin box and hook them together to keep nest building insects out. I loop the electrical plug through the rear of the pin box too. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
GlennWest Posted May 19, 2020 Author Report Share Posted May 19, 2020 Yes when it just hangs it is on the ground. I really liked the holder i had but it is a plastic peice and will break unless all the bolts in. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
rickeieio Posted May 19, 2020 Report Share Posted May 19, 2020 I don't just let them hang, I loop them through a gap so they're a couple feet off the ground. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
porky69 Posted May 19, 2020 Report Share Posted May 19, 2020 (edited) Napa.... Napa Metal Glad hand Holder or any truck parts store should have or be able to get. For the electrical cord....these are supposedly aluminum.... https://www.summitracing.com/parts/pit-525 or https://www.summitracing.com/parts/pit-520 Edited May 19, 2020 by porky69 Quote Link to comment Share on other sites More sharing options...
Pete Kildow Posted May 26, 2020 Report Share Posted May 26, 2020 Buy a set of these https://www.wheelerfleet.com/product/blue-service-gladhand/27615 Mount where you want to keep the gladhands. Quote Link to comment Share on other sites More sharing options...
Scrap Posted May 26, 2020 Report Share Posted May 26, 2020 Boring. And they get your hands like all dirty and stuff. Put em on with a robot arm! 😉 Quote Link to comment Share on other sites More sharing options...
GlennWest Posted May 26, 2020 Author Report Share Posted May 26, 2020 That is why cool. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
lockmup68 Posted May 29, 2020 Report Share Posted May 29, 2020 If I remember correctly, David H made all his connections plug in/removable on both sides (truck/trailer). Takes the hoses/cables off and puts them in a compartment on the truck. I think I have a pic somewhere. Found it. Quote 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
lappir Posted May 31, 2020 Report Share Posted May 31, 2020 I had the curly plastic ones when I first got my Spacecraft. Had to buy at the local Truck stop in Concordia. First mistake. They lasted a couple years. I had Glad Hands on both ends and took the hoses off and stored them in my garage (climate controlled) between moves. Even with maybe 10 total trips and being outside in the elements only during those trips. I was hooking up at the HDT Rally in Hutch and one of the hoses snapped in my hand. Thankfully another member was close by and had yet loaded his jeep and he took me to the local truck stop where I bought two sets of curly hoses. Second Mistake. I now have the hoses on a spring. Much more heavy duty and while I can still take them off and bring them inside I have only done it once. If I am staying in a place where I can't protect them from the afternoon sun I will probably remove them, but so far I've been good. I do always put the "Protectors" on the open glad hands as soon as I remove a hose. Do not want a nest inside my hose ever. I'm not sure if I yet have the best position on the truck. I've changed it a lot. I cannot change it on my trailer, but it's in a typical position for ease of use. Drivers side front corner. A middle position would allow for shorter hoses and electric line, but then the hook up would require climbing on the truck. Billions of over the road miles with commercial operations have put the connections though the mill already so I'm not going to try and change. It would be wonderful for a no touch connection incorporated with the commercial place though. In case someone does want to reinvent the wheel. Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
