Bob1999 Posted November 15, 2019 Report Share Posted November 15, 2019 Question: I have a 2016 Jayco Eagle Travel Trailer 338RETS. I have problems with the kitchen slide out when I am retracting it, it keeps popping the auto reset fuse. Can anybody help with this problem? Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted November 15, 2019 Report Share Posted November 15, 2019 Sounds like it's binding, somewhere. Fix the stick, it should cure the breaker issues. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
DesertMiner Posted November 15, 2019 Report Share Posted November 15, 2019 5 hours ago, Bob1999 said: Question: I have a 2016 Jayco Eagle Travel Trailer 338RETS. I have problems with the kitchen slide out when I am retracting it, it keeps popping the auto reset fuse. Can anybody help with this problem? Your circuit breaker may be worn out or undersized....replace it. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted November 16, 2019 Report Share Posted November 16, 2019 (edited) Welcome to the Escapee forums. If the auto-reset breaker is tripping when it didn't before that would indicate that the motor is drawing excessi.ve current which usually means some type of mechanical problem. I would check the drive system for problems. If you replace it with one that has a higher current rating you could well be courting disaster. If you don't mind, I happen to know someone with that SKP# so are you by chance Jeanette? Edited November 16, 2019 by Kirk W Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
lenp Posted November 16, 2019 Report Share Posted November 16, 2019 I second the replace the breaker suggestion. Continued tripping weakens them. Are your batteries fully charged? Low voltage will cause higher current. Lenp Quote USN Retired 2002 Winnebago Ultimate Freedom 2012 F150 4x4 2018 Lincoln MKX 2019 HD Ultra Limited Link to comment Share on other sites More sharing options...
Bob1999 Posted November 16, 2019 Author Report Share Posted November 16, 2019 Thank you for the information. I replaced the breaker with a 25 amp and it still did it so I put the 20 amp back in. The batteries are fully charged. To Kirk, no I am Bob. My SKP has 6 numbers. Quote Link to comment Share on other sites More sharing options...
DesertMiner Posted November 16, 2019 Report Share Posted November 16, 2019 It only has a 20 amp breaker? Is it electric or hydraulic? Can you put an “amp meter“ on the wire coming from the breaker and get an amp reading while operating the slide? Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted November 17, 2019 Report Share Posted November 17, 2019 (edited) 56 minutes ago, DesertMiner said: It only has a 20 amp breaker? Is it electric or hydraulic? Can you put an “amp meter“ on the wire coming from the breaker and get an amp reading while operating the slide? I agree, like this one: https://www.sears.com/klein-tools-cl700-600-amp-true-rms-ac/p-A058028491?plpSellerId=Savings Kingdom&prdNo=1&blockNo=1&blockType=G1 The HWH hydraulic system is also 12VDC powered, so works for both systems. Edited November 17, 2019 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Barbaraok Posted November 17, 2019 Report Share Posted November 17, 2019 On 11/15/2019 at 8:50 AM, Bob1999 said: Question: I have a 2016 Jayco Eagle Travel Trailer 338RETS. I have problems with the kitchen slide out when I am retracting it, it keeps popping the auto reset fuse. Can anybody help with this problem? Fuse or breaker? You talk about fuse I the OP but then talk about replacing the breaker. Quote Barb & Dave O'Keeffe 2002 Alpine 36 MDDS (Figment II), 2018 Ford C-Max HYBRID Blog: http://www.barbanddave.net SPK# 90761 FMCA #F337834 Link to comment Share on other sites More sharing options...
DesertMiner Posted November 17, 2019 Report Share Posted November 17, 2019 Is there such a thing as a “resettable” fuse in a RV? Quote Link to comment Share on other sites More sharing options...
whj469 Posted November 19, 2019 Report Share Posted November 19, 2019 Yes there are I have had a few in my last two fivers. Quote Link to comment Share on other sites More sharing options...
DesertMiner Posted November 19, 2019 Report Share Posted November 19, 2019 10 minutes ago, whj469 said: Yes there are I have had a few in my last two fivers. A fuse or circuit breaker... please post a link to a resettable “fuse”! Quote Link to comment Share on other sites More sharing options...
whj469 Posted November 19, 2019 Report Share Posted November 19, 2019 Fuse Quote Link to comment Share on other sites More sharing options...
DesertMiner Posted November 19, 2019 Report Share Posted November 19, 2019 Look something like...this Quote Link to comment Share on other sites More sharing options...
