Slow shower drain
Twotoes
Our shower drained very slow when we first picked up our 5th wheel, it turned out that the Hep valve was sucked up backwards plus filled with sawdust, rinsed it out and made sure the rubber boot in it was correct been fine since. I would try to check first before using any chemicals.
2017 River Stone Legacy 38MB
2001 T2000 Kenworth
2009 Smart Passion
ET Junior hitch
I would not use Drano or Liquid Plumber.  I usually use hot water, vinegar and maybe baking soda trying one or two of those together.  I have a small plunger that I use on the sink drain to speed it up if necessary, so that might be an option.  Vinegar usually cuts soapy residue especially with a hot water chaser.
Cathy
The other thing is that shower drains, especially RV shower drains, are notorious for capturing hail and with hair soap and body oils combined the result is a slow drain. I have found that the Hair Grabber used on a fairly regular basis keeps things draining well.
I learned fast that the shower drain fills up with hair and soap residue fast.  I clean it out every week to help prevent that from happening as fast.  The Hair Grabber makes it quicker.  I also have a strainer on the shower floor to help catch hair.  That is cleaned out after each shower.
Richard "Doc" Strait, USN Retired
2017 Coachmen Leprechaun 319MB
Point of Contact for the Military, Veterans, and Gold Star Families BOF
I'm just having a hard time wrapping my head around Kirk recommending something called "The Hairgrabber" ;). Sorry, Kirk.
2007 32.5' Fleetwood Quantum
Please e-mail us here.
 I have used https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwj3gpWKv5blAhUzGH0KHWDPBYkYABACGgJwdg&ohost=www.google.com&cid=CAASE-RoV45imIsozAGhSa90r_ry0LU&sig=AOD64_3vyV5vU-zFDv0bNY2G2zPJUOjkLA&ctype=46&q=&ved=0ahUKEwjGs46Kv5blAhVLgp4KHZPHD1YQzzkIOw&adurl=.
  I have tested it in clear bottles to see its effect. On gray water and black water. It takes 5 days or so to break down black water that had very little solids in it.
  But it did cleanup the gray water nicely. I have used it on dirty auto eguipment. It takes numerous applications. But it does clean oily greasy stuff.
  Many years ago I bought a old oil field drilling rig that had crude oil on it. The rig needed a lot of repairs that I did over the summer that year. So every time it was going to rain I sprayed it with Simple Green and over the summer it cleaned that rig up fairly good.
  About two years ago I had our kitchen sink drain clog up. There was nothing in the trap and nothing in the clean out to the tank. It had to be in the flexible pipe for the slide. Water would hardly drain overnight if the sink was filled up. So I put one cup of Simple green in the sink before going to bed. Next morning it worked as it should.
 No problems since.
 Just a thought,.  Vern
11 hours ago, DesertMiner said:
No one uses a “strainer” in their drain to catch all that nasty stuff?
I call it a strainer yet it most likely has a different name.  The item is designed to sit in showers to help minimize the amount of hair that goes into the drain.  Similar to the ones that you can buy for sinks.
The 'strainer' couldn't be used in our motorhome as the drain hole wasn't completely open to it.  The hole was covered partially by the tub plunger & open only around the sides so nothing could go in the hole.  To clean the drain we had to unscrew the plunger & remove it for access.  Good idea though!
Full-timed for 16 Years
  • 5 weeks later...
  • 2 weeks later...
