masterdrago Posted February 15, 2018 Report Share Posted February 15, 2018 At a cg near Fredericksburg Texas last week, a neighbor pointed out that the tires were off the ground on the drivers side. He said that it was not good for the level up system to have the tires not touching. I thought his comment was not right but thought I would ask here. The ground was crushed granite and not really very level - sloped to the rear. the level up system seemed to work fine and I had put those plastic waffle spacers under all the legs. Maybe if I had not added them under the front, it would not have had to raise the rear so high. Any thoughts? 1st Time RVer 2018 Montana 3791RD, 2018 Ram 3500 DRW Link to comment Share on other sites More sharing options...
Ronbo Posted February 15, 2018 Report Share Posted February 15, 2018 It will not hurt anything. I use them to change tires along the road and to raise the rv at the tire dealer when they need balance. Any 2 jacks are strong enough to lift the whole rv off the crowns and you are using 4 or 6 depending on which system you have. Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
Chad Heiser Posted February 15, 2018 Report Share Posted February 15, 2018 I have left my trailer tires off the ground as a result of an out of level site with no issues. The jacks on the level up system (especially the new version) are plenty strong to handle this. I don't know that I would do it for extended stays, but an overnight or long weekend (both of which I have done) have been no issue. If you think about it, the front of the trailer is always off the ground without any issues. There is no difference at the rear of the trailer. Those who say you shouldn't take the wheels off the ground are usually referencing (or confusing) a motorhome system. You do not want to take the rear wheels of a motorhome off the ground, because there is no longer any braking action once you do so and the motorhome can move or slip (there are no parking brakes on front axles on a motorhome). Trailers do not have parking brakes at all, so the wheels should be chocked when the trailer is disconnected from the tow vehicle. You do want to make sure the wheels that are on the ground are chocked so the trailer won't move. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
Kirk W Posted February 15, 2018 Report Share Posted February 15, 2018 With any RV when leveling to a point that the weight is all removed from the suspension it is important to be sure that you do not twist the frame and especially so if you will be sitting there for an extended period so that the frame could take a set and stay in that twist. The bigger issue, however, is with motorhomes as there are different issues to consider. Many motorhome chassis builders state that you should not remove the weight totally from the suspension so that should be checked as it isn't true in all cases. What is true in all motorhomes is that the park position of the transmission and the parking brake are applied to the driveline so that when you lift one or both rear wheels off of the ground you no longer have any braking and it means that your hacks are all that prevents movement of the RV. That may not concern you, but it does bother some of us. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
remoandiris Posted February 16, 2018 Report Share Posted February 16, 2018 3 hours ago, Kirk Wood said: With any RV when leveling to a point that the weight is all removed from the suspension it is important to be sure that you do not twist the frame and especially so if you will be sitting there for an extended period so that the frame could take a set and stay in that twist. Explain something to me if you know...leveling systems should keep the coach/frame level and straight, right? At least that is how those systems seem to be touted. Link to comment Share on other sites More sharing options...
richfaa Posted February 16, 2018 Report Share Posted February 16, 2018 Lippert the MFG of the 6 point leveling system said it will do no harm to have the wheels off the ground. We also have the Mor Ryde IS system and have had the wheels of the ground many times for various reasons. Helen and I are long timers ..08 F-350 Ford,LB,CC,6.4L,4X4, Dually,4:10 diff dragging around a 2013 Montana 3402 Big Sky SKP 100137. North Ridgeville, Ohio in the summer, sort of and where ever it is warm in the winter. Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted February 16, 2018 Report Share Posted February 16, 2018 It may be true that if the rear wheels of a motorhome are off the ground, there are no brakes. But then again, the weight of the motorhome is now on the jacks and the last I looked, none of the jacks have wheels. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
WeBeFulltimers Posted February 16, 2018 Report Share Posted February 16, 2018 I would be more concerned about the "plastic waffle spacers" you mentioned. I don't trust them. Fulltiming since September 1, 2010 2012 Ford F-350 PSD SRW Lariat Crew Cab 2012 Montana 3585SA Link to comment Share on other sites More sharing options...
Kirk W Posted February 16, 2018 Report Share Posted February 16, 2018 11 hours ago, remoandiris said: Explain something to me if you know...leveling systems should keep the coach/frame level and straight, right? Not sure what you are asking but, how evenly the frame is lifted depends on the design or the leveling system and how well the leveling system controls are working. Some manual control systems will allow you to operate a single jack which could easily put which a twisting force on the chassis. On my manual system, each jack has its own control allowing you to use any jack alone as you might to change a tire. If that is done with all other jacks retracted, the suspension allows the low side to shift as needed but if you were to put three jacks on the ground and then raise just one it will twist things. The caution about twisting the frame came with our RV. I once saw a new Foretravel Motorhome with an automatic leveling system have the windshield popped out to fall to the ground when the automatic leveling system failed and went to hunting up and down. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
masterdrago Posted February 17, 2018 Author Report Share Posted February 17, 2018 On 2/16/2018 at 5:24 AM, WeBeFulltimers said: I would be more concerned about the "plastic waffle spacers" you mentioned. I don't trust them. I've heard others mention that they have had them crack. I gave some consideration to making up some 1x or 2x12 pieces of hardwood cut treated blocks but have not gotten around to it yet. I am using the Valterra A10-0918 Stacker, (Pack of 10) from AMZN. They seen pretty tough and store well. I had one on very unlevel ground and it did not crack or disintegrate. The leg has a pivoting plate on the bottom and it was canted ~10 degrees but reset after raising up for travel. 1st Time RVer 2018 Montana 3791RD, 2018 Ram 3500 DRW Link to comment Share on other sites More sharing options...
remoandiris Posted February 17, 2018 Report Share Posted February 17, 2018 On 2/16/2018 at 8:32 AM, Kirk Wood said: Not sure what you are asking You said "With any RV when leveling to a point that the weight is all removed from the suspension it is important to be sure that you do not twist the frame and especially so if you will be sitting there for an extended period so that the frame could take a set and stay in that twist. " I was asking how can a leveling system twist the frame when, by design, they are supposed to keep the coach level, regardless of wheels touching the ground. Of course if they are not working properly I can see how that could be a problem. But a properly functioning leveling system should not twist the frame, whether 1 tire, all tires, or no tires are touching the ground, right? Unless the leveling system on a towable is designed to function differently than a motor coach, which is possible. I have seen more than one motor coach with 1 jack centered in the front and 2 jacks in the rear. Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted February 17, 2018 Report Share Posted February 17, 2018 For the record, a three legged stool is more stable that a four legged stool. That is why some of the motorhome are so equipped. It is just very difficult to implement a three jack system on a trailer. If the auto-level jack system is smart enough, it will put the jack down until ground contact. From there on, pair of jacks are used to achieve level. By using jack pairs, both front, both back, both right, or both left, the frame should not be subjected to warping. All the current systems using this smart leveling. Older systems did not do that. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
WeBeFulltimers Posted February 19, 2018 Report Share Posted February 19, 2018 On 2/17/2018 at 9:18 AM, masterdrago said: I've heard others mention that they have had them crack. I gave some consideration to making up some 1x or 2x12 pieces of hardwood cut treated blocks but have not gotten around to it yet. I am using the Valterra A10-0918 Stacker, (Pack of 10) from AMZN. They seen pretty tough and store well. I had one on very unlevel ground and it did not crack or disintegrate. The leg has a pivoting plate on the bottom and it was canted ~10 degrees but reset after raising up for travel. Thanks. I also failed to mention that our favorite campground requires blocks to be used and they MUST be wood. They also have free wood blocks available at check-in for those people that don't have their own. Fulltiming since September 1, 2010 2012 Ford F-350 PSD SRW Lariat Crew Cab 2012 Montana 3585SA Link to comment Share on other sites More sharing options...
Bill Joyce Posted February 20, 2018 Report Share Posted February 20, 2018 21 hours ago, WeBeFulltimers said: Thanks. I also failed to mention that our favorite campground requires blocks to be used and they MUST be wood. They also have free wood blocks available at check-in for those people that don't have their own. I have only seen that rule at one place in 14 years of fulltiming, the Santa Barbara CA Elks. I have seen others that require blocks, but don't specify wood. Some of those places said that large jack pads, like our HWH ones, are OK as is. 2004 40' Newmar Dutch Star DP towing an AWD 2020 Ford Escape Hybrid, Fulltimer July 2003 to October 2018, Parttimer now. Travels through much of 2013 - http://www.sacnoth.com - Bill, Diane and Evita (the cat) Link to comment Share on other sites More sharing options...
Barbaraok Posted February 20, 2018 Report Share Posted February 20, 2018 Lake Pleasant in Bothell, WA use to mandate wood blocks and had a pile of them by the office. I notice that they no longer have the pile, nor do they mention using only wood. Barb & Dave O'Keeffe 2002 Alpine 36 MDDS (Figment II), 2018 Ford C-Max HYBRID Blog: http://www.barbanddave.net SPK# 90761 FMCA #F337834 Link to comment Share on other sites More sharing options...
Kirk W Posted February 20, 2018 Report Share Posted February 20, 2018 I don't remember where it was but we stayed in one RV park where an employee lead you to your site, directed you in parking (another subject for discussion) and then placed the parks blocks under your jacks before you were allowed to use them. We were directed to just leave the blocks where placed when we left the park. I have seen a few other places requiring the use of blocks and most have them available in case you do not. Usually, it is because they have asphalt paving and some of the leveling jacks do have very small footprints. In most cases, the park's blocks were very little larger than the footprint of our Bigfoot jacks but unless they have made them larger in recent years, those of HWH were quite small and frequently leave marks in newer asphalt paving. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Dutch_12078 Posted February 20, 2018 Report Share Posted February 20, 2018 HWH uses round pads that range from 8" dia. up to 13.4" dia, depending on the jack capacity. With the dished pad they use though, I don't know what the actual ground contact area is. Bigfoot's standard 10"x10" pads have an actual contact area of about 85 sq in., and Bigfoot's heavy duty pads are 14" dia. with a contact area of about 145 sq in. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Bill Joyce Posted February 21, 2018 Report Share Posted February 21, 2018 20 hours ago, Dutch_12078 said: HWH uses round pads that range from 8" dia. up to 13.4" dia, depending on the jack capacity. With the dished pad they use though, I don't know what the actual ground contact area is. Bigfoot's standard 10"x10" pads have an actual contact area of about 85 sq in., and Bigfoot's heavy duty pads are 14" dia. with a contact area of about 145 sq in. My HWH pads are 10" squares. 2004 40' Newmar Dutch Star DP towing an AWD 2020 Ford Escape Hybrid, Fulltimer July 2003 to October 2018, Parttimer now. Travels through much of 2013 - http://www.sacnoth.com - Bill, Diane and Evita (the cat) Link to comment Share on other sites More sharing options...
WeBeFulltimers Posted February 21, 2018 Report Share Posted February 21, 2018 On 2/20/2018 at 8:31 AM, Bill Joyce said: I have only seen that rule at one place in 14 years of fulltiming, the Santa Barbara CA Elks. I have seen others that require blocks, but don't specify wood. Some of those places said that large jack pads, like our HWH ones, are OK as is. The park I referenced is Chester Frost Park Campground (a county parks facility) on the Tennessee River in Chattanooga, TN. All RV spaces are asphalt. Fulltiming since September 1, 2010 2012 Ford F-350 PSD SRW Lariat Crew Cab 2012 Montana 3585SA Link to comment Share on other sites More sharing options...
Dutch_12078 Posted February 21, 2018 Report Share Posted February 21, 2018 10 hours ago, Bill Joyce said: My HWH pads are 10" squares. And you're right of course, Bill. I forgot that HWH had some square/rectangular pads on their intermediate capacity jacks. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
oscarvan Posted February 26, 2018 Report Share Posted February 26, 2018 Greetings again, haven't been around for a while. Good to see the discussion is alive and well here. My $0.03 Getting the rear wheels in the air CAN put strain on the jacks as there is no longer anything keeping wheels (the front ones) from turning. I put a fat chock under at least one front wheel on the downhill side. Air suspension bags don't like being stretched for extended periods of time. If I'm somewhere for a longer period of time and there's no load on a wheel or wheels I will bring that end up more with the levelers, put a block under the wheel and re-level. Previously a 2017 Forest River, Berkshire 38A, "The Dragonship". https://dragonship.blog/ Link to comment Share on other sites More sharing options...
Dutch_12078 Posted February 26, 2018 Report Share Posted February 26, 2018 If the front jacks are down, as they would normally be, how will the front wheels turn? That said, I do agree that any wheels that are off the ground should likely be blocked up rather than hanging down on the suspension. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
masterdrago Posted March 9, 2018 Author Report Share Posted March 9, 2018 My neighbor just gave me 2 pieces of oak from a 100 year old tree that fell a few years back. He has a monster band saw and has milled it into pieces that are 1.25"x14"x 7' - those should make some nice wood pads! 1st Time RVer 2018 Montana 3791RD, 2018 Ram 3500 DRW Link to comment Share on other sites More sharing options...
