ARGO Posted January 25, 2018 Author Report Share Posted January 25, 2018 Too busy with the show to have a try at the leaks. That, and processing Corona followed by pressure testing the recliner. Engine brake a good guess, but I'm talking 65 MPH, straight flat road on cruise losing that much on the f tank. Fan is off at that speed anyway, and I checked the connections several times & the hub, too. R tank holds dead steady. I'm thinking maybe the F tank has a hole I haven't found. You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
SuiteSuccess Posted January 26, 2018 Report Share Posted January 26, 2018 45 minutes ago, ARGO said: Too busy with the show to have a try at the leaks. That, and processing Corona followed by pressure testing the recliner. Engine brake a good guess, but I'm talking 65 MPH, straight flat road on cruise losing that much on the f tank. Fan is off at that speed anyway, and I checked the connections several times & the hub, too. R tank holds dead steady. I'm thinking maybe the F tank has a hole I haven't found. Just wondering out loud. Don’t the truckers in Yukon and Alaska put some type of antifreeze in their airlines? If you think it’s a hole in the tank, couldn’t you do the same then look for bubbles on the tank? Still think “The Whisper” would find a tank leak. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted January 26, 2018 Report Share Posted January 26, 2018 I'd start with the front tank and all the fittings on it. Then start tracing all the lines and checking all those connection points. It's time-consuming but not hard as long as you can get under the truck. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
dennisvr Posted January 26, 2018 Report Share Posted January 26, 2018 Not sure if anyone has mentioned it, but have you checked the one way check valve between the compressor and the tank. If it doesn't seat you would not hear the air leaking back to the compressor. "It is better to have more truck than you need than to need more truck than you have" 2001 Volvo 660, Cummins 400 ISX, Eaton 3 Peddle Auto Shift 2014 Fuzion 40' Toyhauler 2015 Smart Car Link to comment Share on other sites More sharing options...
ARGO Posted January 26, 2018 Author Report Share Posted January 26, 2018 Good suggestion! The bad valve would give the symptoms I have. Tks, I'll check it out next time I fire up. The offer of a case of Corona is still good if someone wants to come up to Baltimore & have at it.......................... You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
alan0043 Posted January 26, 2018 Report Share Posted January 26, 2018 Hi ARGO, Are your air tanks steel or aluminum ? I remember someone here on the forum that had steel tanks that where leaking under the holding straps. Just an idea. Al 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
ARGO Posted January 26, 2018 Author Report Share Posted January 26, 2018 19 minutes ago, alan0043 said: Hi ARGO, Are your air tanks steel or aluminum ? I remember someone here on the forum that had steel tanks that where leaking under the holding straps. Just an idea. Al They are steel, but & I stuffed the wang on the whisper as far down from above & in from underneath between them & no alarm. Tks. You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
Imurphy907 Posted January 26, 2018 Report Share Posted January 26, 2018 3 hours ago, ARGO said: They are steel, but & I stuffed the wang on the whisper as far down from above & in from underneath between them & no alarm. Tks. I find using the headphones is MUCH MUCH more accurate than looking for the leds to light up. 2016 Road Warrior 420 2001 Volvo VNL 660 Alaska Based. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted January 27, 2018 Report Share Posted January 27, 2018 12 hours ago, ARGO said: They are steel, but & I stuffed the wang on the whisper as far down from above & in from underneath between them & no alarm. Tks. I think you are supposed to use the wang on the whisper on the truck, just saying. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
ARGO Posted January 27, 2018 Author Report Share Posted January 27, 2018 You're right! Much easier to get near the tank, and a LOT longer than my other one. You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
ARGO Posted January 27, 2018 Author Report Share Posted January 27, 2018 Update- applied garage air to my connection for airing tires. F tank goes to 120. Disconnected the discharge line from the engine air compressor, no back-leak. Disconnected garage air, F tank drops like a stone, like 20 lbs less than a minute. OK, we're getting close! Got under w/Whisper, ALL OVER F tank, no leak. No leak at air dryer, only other thing in discharge line. Can't get the **WHISPER** wang up to the top of the tanks, will drop the tanks today. You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
Scrap Posted January 27, 2018 Report Share Posted January 27, 2018 Have a system purge air dryer? Bad delivery check valve? Bad pressure protected check in the tank (actually sounds like a good SC-PR that is doing its 20 lb thing-maybe leak in the supply tank?)? System purge dryers take up to 20psi out of the front tank every time they regenerate. Maybe bad delivery check or other dryer problem is making it try to do it continuously? Link to comment Share on other sites More sharing options...
