Towing Specs
I looked at the VIN Decoder for my Chevy Silverado 3500 regarding towing capacity.  I'm confused, to say the least, and am hopeful the knowledge here can help decode this.  Here are the towing weights as listed on the print out:
Dead Weight Hitch - Max Trailer Wt.
5000 lbs  5000.0 min  5000.0 max
Wt Distributing Hitch _ Max Trailer Wt.
8800, 13300, 9200, 13700 lbs  8800.0 min  22600.0 max
Fifth Wheel Hitch Max Trailer Wt.
What's the maximum I can tow?  I was looking at a fifth wheel unit and I know what the salesman told me.  I don't trust RV salesmen, with apologies to any on the site.  Thanks for any input.
Not enough info to answer.
What year Chevy?
What engine?
What Tranny?
What rear end?
What body style crew cab or two door cab?
We can find your answer with some information.
RV/Derek
Retired AF 1971-1998
Freebirds, we need what Gary asked for too. Thanks Gary!
Edited by RV_
RV/Derek
So are we have:
2016 Chevrolet Silverado 3500
6L engine
6 speed automatic transmission
4.10 rear end
Crew cab
Still need:
Long bed/Short bed
2 Wheel drive/4WD
Single rear wheel or dual rear wheels?
Then we can look it up for you and show you where we found your towing specs.
RV/Derek
The way I read that website his pickup has a 11,000lb. towing capacity; that pickup will run out of carrying capacity before anything else. It's limited by the weight capacity of the SRW load range .
For example (since we don't know his tire size), a 235/85R16 load range E tire has a maximum load capacity of 3,040#. Which means the rear axle has a maximum capacity of 6,080# for a SRW pickup.
Crew cab, 8’ box (4WD) with single rear wheels:
6.0L: 4990 / 11000
6.6L: 5262 / 11600
Towing specs are listed in the owners manual.
Thanks to the collective wisdom here.  I was looking at a fifth wheel toy hauler and the salesman was telling me about how me truck could haul a much heavier fifth wheel unit than a trailer.  I learned long ago never to trust a salesman.
I don't remember the exact numbers to look for but in the glove box on most if not all Chev trucks there is a decall with the build codes for that vehicle and the one for the rear end  like g5 or g4 or somethiing. One means 3:73 and one means 4:10. There are other but that is the ones I was concerned about. Like stated most modern chev diesels have 3:73.
update GT5 4:10  GT4-3:73  GT2-2:29  GT1-2:56  and there are others
Edited by bigjim
Just got here and Gary answered it.
I don't trust RV salesman at all on towing capacities. They are right that you can tow almost anything with a pickup on flat ground. But emergency stops and stopping on a downhill run?
I look forward to your future posts.
RV/Derek
Generally you can to a heavier travel trailer than a 5er due to the increase hitch/pin weight on the 5er.  SRW trucks reach the cargo capacity or rear axle GAWR well before they reach the towing limits.
And remember you can always tell when an RV or auto salesperson is not telling the truth...he or she will move their lips every time.
Excerpt:
"The truth is, there's more to choosing a vehicle/trailer combo than matching a vague idea of your max tow capacity to the largest trailer within this limit. Below, we'll go over a few important factors your dealership probably didn't mention: your vehicle configuration, your payload, and your wheelbase ratio. All of these factors are just as important in determining how big of a trailer you can safely tow.
In this article:
Source:
https://www.etrailer.com/faq-how-much-trailer-can-I-tow.aspx
This next video is excellent. Fifth wheels are more stable on the road if you have enough truck. I towed with a Ram 1 ton diesel Dually towing ~ 12k-12.5pounds.
Safe Travels!
RV/Derek
