bobsallyh Posted October 5, 2022 Report Share Posted October 5, 2022 (edited) Dutch12078, they open the bleed screw when beginning filling and when the spitting starts, shut the screw and pump off. If a #20 cylinder is empty, it usually cuts off at 4.3. A #30 usually shuts off at 6.9. Both depending on weather and temps. Of course, the pump is stickered by the county for accuracy. just pumps like at service stations. I just got propane yesterday, and the owner now has a cage there with 20, 30, and 40 pounders in it for exchange. I don't know if this still true but a number of years ago propane regulations etc. in Texas were controlled by the Railroad Commision. I knew immediately why the differences from other states. Edited October 5, 2022 by bobsallyh Quote Link to comment Share on other sites More sharing options...
Dutch_12078 Posted October 5, 2022 Report Share Posted October 5, 2022 (edited) 1 hour ago, bobsallyh said: Dutch12078, they open the bleed screw when beginning filling and when the spitting starts, shut the screw and pump off. If a #20 cylinder is empty, it usually cuts off at 4.3. A #30 usually shuts off at 6.9. Both depending on weather and temps. Of course, the pump is stickered by the county for accuracy. just pumps like at service stations. I just got propane yesterday, and the owner now has a cage there with 20, 30, and 40 pounders in it for exchange. I don't know if this still true but a number of years ago propane regulations etc. in Texas were controlled by the Railroad Commision. I knew immediately why the differences from other states. I'm glad to see that's how they were doing it. I'm well aware of how the Fixed Liquid Level Gauge works, Bob, having used it many times when filling both DOT cylinders and ASME tanks. I mentioned it to the attendant at Tractor Supply, but he said he was filling my 30 lb cylinder the way he was trained. I don't know who did their training, but clearly something was skipped. It's not a store I'm likely to use for refills very often, but it'll be interesting to see if anything has changed the next time I stay at the state park in the area. It's good to see they have the larger sizes available for exchange. I wish more refillers would do that. Edited October 5, 2022 by Dutch_12078 typo, clarity Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Customer1 Posted October 13, 2022 Report Share Posted October 13, 2022 On 10/3/2022 at 11:44 AM, Ray,IN said: OPD valve limits filling over 80%, 16# =3.4G is maximum capacity. They hold 80% WC (water capacity) the typical BBQ size bottle is at 80% WC when it contains 20# of lpg. Yours is a common mistake. Quote 2018 Keystone Cougar 2016 Chevrolet Silverado 3500 DRW D/A Link to comment Share on other sites More sharing options...
Ray,IN Posted October 18, 2022 Report Share Posted October 18, 2022 On 10/12/2022 at 10:42 PM, Customer1 said: They hold 80% WC (water capacity) the typical BBQ size bottle is at 80% WC when it contains 20# of lpg. Yours is a common mistake. This Measurement Technology paper has a different explanation. Quote  2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961  Link to comment Share on other sites More sharing options...
mptjelgin Posted October 18, 2022 Report Share Posted October 18, 2022 There are two different measurement types to consider. When the 80% term is being used, it is based on volume. That is, only 80% of the volume of the tank is filled with liquid propane to allow 20% gas volume above the liquid. The paper that you refer to is based on weight. Since liquid propane weighs much less than water (4.1 - 4.2 pounds per gallon, depending on temperature vs. water at 8.3 pounds per gallon) the fill percentage numbers based on weight are much different. The 42% of WC referred to in the referenced paper corrects for the weight difference between the two liquids as well as the 80% fill volume. So the maximum weight of liquid propane is 42% of the full liquid weight of water. Volume-wise, that is about 80% full of propane.  Quote Mark & Teri 2021 Grand Designs Imagine 2500RL, 2019 Ford F-350 Mark & Teri's Travels Link to comment Share on other sites More sharing options...
Customer1 Posted October 18, 2022 Report Share Posted October 18, 2022 3 hours ago, Ray,IN said: This Measurement Technology paper has a different explanation. "Cylinders Filled By Weight Following the visual exterior bottle inspection, the bottle filler will look for two other things prior to hooking up the fill hose with the cylinder on the scale. These two things are the water capacity and tare weight. The water capacity is how much water the propane bottle will hold in pounds. The "WC" stamped on the bottle followed by a number such as "47.6" means the bottle will hold 47.6 pounds of water. The tare weight (empty weight) indicated by a "TW" is also followed by a number such as "18" meaning the bottle weighs 18 pounds when empty. The numbers here would likely be found on a five gallon propane bottle (also known as a 20 pound cylinder) used for a barbeque grill. The bottle filling station will generally have a cylinder filling chart that converts water capacity (WC) to pounds of propane that the filler will refer to before filling the bottle. The chart will show that 47.6 pounds of water converts to 20 pounds of propane. In other words, a propane bottle that will hold 47.6 pounds of water will hold 20 pounds of propane. This indicates that the scale needs to be set a little over 38 pounds (20 lbs + 18 lbs = 38 lbs) to obtain the weight of the bottle when it reaches its allowable capacity." https://www.propane101.com/propanecylinderfilling.htm Quote 2018 Keystone Cougar 2016 Chevrolet Silverado 3500 DRW D/A Link to comment Share on other sites More sharing options...
