Parrformance Posted August 29, 2021 Report Share Posted August 29, 2021 Does anyone know if there is a rebuilder for the engine computer on these volvo? I have voltage on the appropriate pins, my grounds check good as well. The bus wires have continuity between the VECU, and the ECU. The ECU appears to be bad, I suspect a bad solder joint as it worked intermittently but now dead. I might be willing to crack it open and look for bad solder joints, probably one at pin 60 or 57 on the B connector side. I would prefer to send it off for repair, I think. Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Darryl&Rita Posted August 29, 2021 Report Share Posted August 29, 2021 ECM King Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Parrformance Posted August 30, 2021 Author Report Share Posted August 30, 2021 Thanks Darryl&Rita, Found this one too: https://goecm.com/ Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted August 30, 2021 Report Share Posted August 30, 2021 Midwest ECM might do it. They specialize in the Cummins ECM but its worth a call. I'm pleased with what they did with mine. Quote Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Parrformance Posted August 31, 2021 Author Report Share Posted August 31, 2021 Did you have anything adjusted while they had your ECM Jim? Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted September 2, 2021 Report Share Posted September 2, 2021 On 8/31/2021 at 7:03 AM, Parrformance said: Did you have anything adjusted while they had your ECM Jim? Yes, They raised the RPM limiter to 2200 from 1800, reprogramed for more HP and torque. To take full advantage of it I need to swap injectors out. Also changed the shut down setting and high Idle parameters, got the speedometer back in calibration. Quote Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Parrformance Posted September 9, 2021 Author Report Share Posted September 9, 2021 Looks like I am going to give Hi-Tech Electro ECM in Irving Texas a try with the ECM repair for my Volvo VED12D motor. Anyone have any reason that I should find another repair place? Looks like TRUCK ECM and ECM King do not repair the Volvo ECU part# 20561256. Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Parrformance Posted September 9, 2021 Author Report Share Posted September 9, 2021 Hi-Tech has horrific reviews as well. Anyone have first hand knowledge of swapping a used ECM into a Volvo and what else will need to be done? Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Parrformance Posted September 19, 2021 Author Report Share Posted September 19, 2021 The used ECM worked, the oil pressure guage is working again. The Truck is no longer de-rated. I am having a couple of new issues, engine fan speed error, and the two intake air heater codes. I am hoping not an ECM issue but perhaps a wiring problem. Tackle these tomorrow. I recently replaced the engine fan solenoid and the short pigtail harness, so going to start there first. Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
SuiteSuccess Posted June 13, 2023 Report Share Posted June 13, 2023 On 9/18/2021 at 9:20 PM, Parrformance said: The used ECM worked, the oil pressure guage is working again. The Truck is no longer de-rated. I am having a couple of new issues, engine fan speed error, and the two intake air heater codes. I am hoping not an ECM issue but perhaps a wiring problem. Tackle these tomorrow. I recently replaced the engine fan solenoid and the short pigtail harness, so going to start there first. I know older thread but any updates on issues? BTW sent you a p.m. Think we have sister trucks. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Parrformance Posted June 14, 2023 Author Report Share Posted June 14, 2023 Used ECM still working👍🏽 Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
