Tim and Peggy Posted May 9, 2021 Report Share Posted May 9, 2021 Life in an RV. So I need to order a new control panel (mother board), but that part and model of microwave is out of date. So, I got to buy a new Microwave, same size, etc. BUT, I cannot get this one out. It is held on the wall with a standard mounting bracket, but as most of you know, you generally have to tip the microwave at a moderate angel to detach it from the bracket. So there i no room ABOVE the appliance to do so and the molding is one piece. Would love any ideas how to get the damn thing out. See attached picture. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted May 9, 2021 Report Share Posted May 9, 2021 Should be 2 long screws on bottom at an angle to top. Loosen them and comes out from top and comes down at an angle to you. Quote Link to comment Share on other sites More sharing options...
Tim and Peggy Posted May 9, 2021 Author Report Share Posted May 9, 2021 Thanks, but the top of the appliance is flush to the top on the cabinetry/molding and crown molding on that, see picture. if they are there, would love to find them. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted May 9, 2021 Report Share Posted May 9, 2021 The bolts are at the bottom of the microwave. Not the top. There is a plate screwed to the wall behind it. Screws go into it. Unit sits on plate and push up and install screws. just reverse process. Quote Link to comment Share on other sites More sharing options...
pjstough Posted May 9, 2021 Report Share Posted May 9, 2021 (edited) Here is a video that shows removing a microwave/convection oven in a Winnebago. Yours may be similar.How to remove and install Sharp Microwave R-1870 thats in a 2005 38J Winnebago Voyage - YouTube Edited May 9, 2021 by pjstough Quote Link to comment Share on other sites More sharing options...
Tim and Peggy Posted May 9, 2021 Author Report Share Posted May 9, 2021 thanks but no access top/behind microwave. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted May 9, 2021 Report Share Posted May 9, 2021 Forget about top access. Mine is same and most are. You have no reason to get to the top. Bolts at bottom hold it to wall. Remove and it comes off. Quote Link to comment Share on other sites More sharing options...
Tim and Peggy Posted May 9, 2021 Author Report Share Posted May 9, 2021 which that was the case but mine (apparently) has two screws from the top. see picture below. no easy way to get to it. Remove molding to try and gain access to top of screw to remove. Seems daunting at least. Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted May 9, 2021 Report Share Posted May 9, 2021 Perhaps watching an installation will help you see how it is mounted and how reversing the procedure will remove the oven. Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 9, 2021 Report Share Posted May 9, 2021 You probably have a false bottom in the cabinet above. That's what we had. Quote Link to comment Share on other sites More sharing options...
Tim and Peggy Posted May 9, 2021 Author Report Share Posted May 9, 2021 There is no cabinet above. Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 9, 2021 Report Share Posted May 9, 2021 Just now, Tim and Peggy said: There is no cabinet above. Sorry, I mistook what now appears to be the slide surround, for cabinets. Quote Link to comment Share on other sites More sharing options...
Jaydrvr Posted May 9, 2021 Report Share Posted May 9, 2021 2 hours ago, Tim and Peggy said: which that was the case but mine (apparently) has two screws from the top. see picture below. no easy way to get to it. Remove molding to try and gain access to top of screw to remove. Seems daunting at least. This is how ours was installed. The room across the top was removed and screws were driven at an angle through the frame of the micro into the cabinet framing above. Re the mother board.. Have you looked into rebuilt boards? That's how I fixed ours. There were multiple sites that had rebuilt boards. I picked the lowest price one that sounded legit. The first board had a stem problem, but the board worked. They shipped out another board pronto and the unit is still working. Jay Quote Link to comment Share on other sites More sharing options...
Tim and Peggy Posted May 9, 2021 Author Report Share Posted May 9, 2021 20 minutes ago, Jaydrvr said: This is how ours was installed. The room across the top was removed and screws were driven at an angle through the frame of the micro into the cabinet framing above. Re the mother board.. Have you looked into rebuilt boards? That's how I fixed ours. There were multiple sites that had rebuilt boards. I picked the lowest price one that sounded legit. The first board had a stem problem, but the board worked. They shipped out another board pronto and the unit is still working. Jay I have tried several website searches and no luck yet. The model has been discontinued and will keep looking. So are you agreeing with me that it will be a major undertaking to get access to the screws/bolts? I pulled slide in and the area where the bolts must be is covered with rubber membrane for the slide roof. Thanks. Love the graphic, will have to look for it, very cool. Quote Link to comment Share on other sites More sharing options...
Jaydrvr Posted May 9, 2021 Report Share Posted May 9, 2021 18 minutes ago, Tim and Peggy said: I have tried several website searches and no luck yet. The model has been discontinued and will keep looking. So are you agreeing with me that it will be a major undertaking to get access to the screws/bolts? I pulled slide in and the area where the bolts must be is covered with rubber membrane for the slide roof. Thanks. Love the graphic, will have to look for it, very cool. How old is your unit? Ours is the original Camco/GE in our 2011 Newmar and long since discontinued. There were no other units I could find that would fit properly and look like the original install, so I really wanted to fix the one we had. Yours looks like a challenging situation and one where I would definitely prefer to fix it, rather than demolishing the entire slide to get to it. Good luck, Jay. Quote Link to comment Share on other sites More sharing options...
Dutch_12078 Posted May 9, 2021 Report Share Posted May 9, 2021 (edited) I can't tell from the photo, but are there some small screws through the top edge of the unit into the filler piece above it? If so, I wonder if removing them would allow the filler to be removed for access to the mounting bolts. Edited May 9, 2021 by Dutch_12078 Quote Link to comment Share on other sites More sharing options...
Tim and Peggy Posted May 9, 2021 Author Report Share Posted May 9, 2021 if only that were the case. no evidence of small screws, I too was praying for something that would allow me to remove that filler piece. Thanks for think of that...but. Quote Link to comment Share on other sites More sharing options...
Tim and Peggy Posted May 9, 2021 Author Report Share Posted May 9, 2021 15 minutes ago, Jaydrvr said: How old is your unit? Ours is the original Camco/GE in our 2011 Newmar and long since discontinued. There were no other units I could find that would fit properly and look like the original install, so I really wanted to fix the one we had. Yours looks like a challenging situation and one where I would definitely prefer to fix it, rather than demolishing the entire slide to get to it. Good luck, Jay. 2016 Thor Tuscany Quote Link to comment Share on other sites More sharing options...
Jaydrvr Posted May 9, 2021 Report Share Posted May 9, 2021 (edited) 14 minutes ago, Tim and Peggy said: 2016 Thor Tuscany You might try repairclinic.com. Also, this is a search for panels. http://www.google.com/search?hl=en-US&source=android-browser&q=rebuilt+appliance+control+boards&oq=appliance+rebu&aqs=heirloom-srp.4.0l5 I'm sure you probably have seen these. Jay Edited May 9, 2021 by Jaydrvr Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 9, 2021 Report Share Posted May 9, 2021 3 hours ago, Tim and Peggy said: which that was the case but mine (apparently) has two screws from the top. see picture below. no easy way to get to it. Remove molding to try and gain access to top of screw to remove. Seems daunting at least. At this point, I'd be looking at breaking the spring clip holding the nut against the top of the micro. Assuming that you can see both screws. Quote Link to comment Share on other sites More sharing options...
Tim and Peggy Posted May 9, 2021 Author Report Share Posted May 9, 2021 3 minutes ago, Darryl&Rita said: At this point, I'd be looking at breaking the spring clip holding the nut against the top of the micro. Assuming that you can see both screws. IF I can do that and it releases the unit, what about the installation of the new one which surely depends on bolts from the top. Right? Anyway to talk by phone? Quote Link to comment Share on other sites More sharing options...
GlennWest Posted May 9, 2021 Report Share Posted May 9, 2021 Buy one with the rear wall mounted bracket. That is what should have been used to start with. Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 9, 2021 Report Share Posted May 9, 2021 1 hour ago, Tim and Peggy said: IF I can do that and it releases the unit, what about the installation of the new one which surely depends on bolts from the top. Right? Anyway to talk by phone? Reuse the trapped bolts. Pull the nuts off, inside the microwave, instead of threading the bolts out externally. Quote Link to comment Share on other sites More sharing options...
Tim and Peggy Posted May 9, 2021 Author Report Share Posted May 9, 2021 18 minutes ago, Darryl&Rita said: success, sort of So attached is a measure of success. I pulled the filler strip out (carefully) and guess what, the bolts that I thought were holding the microwave to the roof or frame are holding the bracket to the microwave. As you can see, there our three bolts on the right side that hold the bracket to the side wall and one on the left side. Wife says, now hire someone to come take it out and install the new one. I don;t have the right tools to reach in a small space only 2 inches high and the damn bolts are about 8 inches inside. My fat hands cannot get in with enough strength/torque to loosen...let alone re-attach. So at least we know it can/will be done. Going to the floor of the Gran Canyon tomorrow and will have someone come over on Tuesday, hopefully to "finish." Quote Link to comment Share on other sites More sharing options...
Dutch_12078 Posted May 10, 2021 Report Share Posted May 10, 2021 A socket wrench, 12" extension, a swivel, and of course the correct socket, would make short work of those bolts Quote Link to comment Share on other sites More sharing options...
