hemsteadc Posted November 22, 2020 Report Share Posted November 22, 2020 (edited) 2008 Sportchassis cummins 8.3. I have 2 air tanks, and both have that needle valve thingy on them you're supposed to push now and then to expel any condensed water inside. One of them has a slow leak, and I'm not sure how to stop it. I have crawled underneath and fiddled with it, and I got the leak to become less, but I can't stop it and it allows my rear suspension bags to deflate over a few days. The next thing I may try is pushing it open and blowing air back up into it, thinking there's something like a grain of sand stuck on the lip. I hesitate to take it apart as I'm out in the sticks and I don't need any catastrophes. Anybody have any ideas? Thanks Edited November 22, 2020 by hemsteadc Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted November 22, 2020 Report Share Posted November 22, 2020 Change it. Rubber seal is likely shot. If your rear suspension is going down, you may have another leak you don't know about. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
hemsteadc Posted November 22, 2020 Author Report Share Posted November 22, 2020 (edited) Just now, Darryl&Rita said: you may have another leak you don't know about. Lol.. there's always another leak I don't know about. Where is the rubber seal? Edited November 22, 2020 by hemsteadc Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted November 22, 2020 Report Share Posted November 22, 2020 Buy a new one before removing this one or remove this one and insert a pipe plug until you do find a new one. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
hemsteadc Posted November 22, 2020 Author Report Share Posted November 22, 2020 (edited) Just now, Ray,IN said: Buy a new one before removing this one or remove this one and insert a pipe plug until you do find a new one. Are they standard pipe threads? I really don't need this thing as it never has any water in it. Edited November 22, 2020 by hemsteadc Quote Link to comment Share on other sites More sharing options...
rickeieio Posted November 23, 2020 Report Share Posted November 23, 2020 3 hours ago, hemsteadc said: Are they standard pipe threads? I really don't need this thing as it never has any water in it. And you'll never need it as long as your dryer is working properly. You do service it occasionally? Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
hemsteadc Posted November 23, 2020 Author Report Share Posted November 23, 2020 11 hours ago, rickeieio said: And you'll never need it as long as your dryer is working properly. You do service it occasionally? I never have nor have I seen it done. I'll get a new part, I just need it to stop leaking for now. Quote Link to comment Share on other sites More sharing options...
noteven Posted November 23, 2020 Report Share Posted November 23, 2020 Yes - pipe threads. Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Ray,IN Posted November 24, 2020 Report Share Posted November 24, 2020 (edited) A pipe plug is a temporary patch, the air drain is required. As rickeleio said when the air dryer is functioning as designed very little/no water will be in the tank, If there is water in the tank there is a chance water also found its way into the air brakes, which can be a dangerous and expensive situation. For semi-tractors, if stopped by DOT, they will pull the cables to the manual air drain fitting for a test. That is how important the manual drain valve is to safety. The most important item to avoid moisture is the air dryer assembly, including its regular maintenance. Edited November 24, 2020 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
hemsteadc Posted November 24, 2020 Author Report Share Posted November 24, 2020 10 hours ago, Ray,IN said: , If there is water in the tank there is a chance water also found its way into the air brakes, which can be a dangerous and expensive situation. I don't have air brakes. Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted November 24, 2020 Report Share Posted November 24, 2020 13 minutes ago, hemsteadc said: I don't have air brakes. Here we go again. You still have an air system, that needs care and attention. If you skip over it, you'll end up paying in the future. Either when you have to replace extra parts due to rust, or when sale time comes, and the buyer catches your skipped maintenance. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
hemsteadc Posted November 24, 2020 Author Report Share Posted November 24, 2020 16 minutes ago, Darryl&Rita said: Here we go again. I don't know what that means, but it doesn't sound friendly. Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted November 24, 2020 Report Share Posted November 24, 2020 Entirely friendly. Your air dryer maintenance has been mentioned in the past. It's your choice. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
noteven Posted November 25, 2020 Report Share Posted November 25, 2020 (edited) Example on Amazon for $13. I only maintain truck air systems with parts "intended for a truck or bus" (sorry I don't know the correct backed up by documentation to prove it term) often found at the truck dealer's parts dept. or a reputable commercial vehicle aftermarket source. Edited November 25, 2020 by noteven Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
hemsteadc Posted November 25, 2020 Author Report Share Posted November 25, 2020 47 minutes ago, noteven said: only maintain truck air systems with parts "intended for a truck or bus" (sorry I don't know the correct backed up by documentation to prove it term) often found at the truck dealer's parts dept. or a reputable commercial vehicle aftermarket source. Crawling under this truck every day is not something I'll ever be doing. I have never found the air dryer, and according to my mfr, there isn't one. I'll keep looking. Quote Link to comment Share on other sites More sharing options...
noteven Posted November 25, 2020 Report Share Posted November 25, 2020 If you do not have air brakes your truck may not have an air dryer. If it had one you would hear it discharging contaminants when the compressor cycles off. If there is no dryer fairly frequent pulling of the drain lanyards when you are doing your pre trip walk around with the engine running is a good habit. Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
ms60ocb Posted November 26, 2020 Report Share Posted November 26, 2020 My Air drier on my 2015 FF M-2 is located in front of the right front tire. Clay Quote Clay & Marcie Too old to play in the snow Diesel pusher and previously 2 FW and small Class C Link to comment Share on other sites More sharing options...
hemsteadc Posted November 26, 2020 Author Report Share Posted November 26, 2020 20 hours ago, noteven said: If there is no dryer fairly frequent pulling of the drain lanyards when you are doing your pre trip walk around with the engine running is a good habit. I don't even have those. I have to crawl under the truck. Quote Link to comment Share on other sites More sharing options...
noteven Posted November 26, 2020 Report Share Posted November 26, 2020 7 hours ago, hemsteadc said: I don't even have those. I have to crawl under the truck. I posted a link for valves with lanyards on Amazon for $13 each. If I was camped near you we could install them in minutes. My son has a saying on his ranch when we are doing something the hard way: "Pa, it's because we enjoy the struggle..." 🤣 Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
