Nwcid Posted September 1, 2020 Author Report Share Posted September 1, 2020 2 minutes ago, Randyretired said: I have a picture of just the truck on my phone but I don't know how to post it here. Maybe someone can point me in the right direction. If you are willing to email, nwcid@yahoo.com Quote Link to post Share on other sites
Lance A Lott Posted September 1, 2020 Report Share Posted September 1, 2020 Just for reference a couple of winters ago I left my truck, singled short Volvo 630 with super singles, parked on the side of the driveway a little to long. The front wheels had sunk a little and the ground was frozen when I decided to move it. This was before I built the bed, I tryed laying chains on the ground but I could only get it to rock. I tried to pull it with my 90 horse 4 wheel drive farm tractor, no chains on tractor, no go. I was by my self so as a last resort I set the bucket on the frame and lifted the front of the tractor off the ground probably added 3 or 4 thousand pounds as far back as I could. It walked right out pushing the 9000 lb tractor. I do have a locking diff sure would like one. Quote Link to post Share on other sites
Lance A Lott Posted September 1, 2020 Report Share Posted September 1, 2020 (edited) 7 minutes ago, Randyretired said: I have a picture of just the truck on my phone but I don't know how to post it here. Maybe someone can point me in the right direction. Go to the top of this HDT page about the forth post down is picture posting instructions. Edited September 1, 2020 by Lance A Lott Spelling Quote Link to post Share on other sites
DesertMiner Posted September 1, 2020 Report Share Posted September 1, 2020 http://photoposting.is-great.net/?i=1 Quote Link to post Share on other sites
Ray,IN Posted September 1, 2020 Report Share Posted September 1, 2020 I just read the thread, I suspect what you should be looking at is a MDT (Class 5/6) with 4 WD; or check in to having hydraulic AWD put on a HDT. Quote Link to post Share on other sites
Nwcid Posted September 1, 2020 Author Report Share Posted September 1, 2020 4 minutes ago, Ray,IN said: I just read the thread, I suspect what you should be looking at is a MDT (Class 5/6) with 4 WD; or check in to having hydraulic AWD put on a HDT. I have looked at the MDT also and not sure they fit what I want for the price they cost. I do know they make true 4x HDT because we get them as tactical water tenders on wildland fires and they are impressive. I do not know for sure, but I would imagine the cost is higher then non 4x HDT and the ride is not as nice. That AWD link looks pretty cool, but I could not find any pricing info. Quote Link to post Share on other sites
Randyretired Posted September 1, 2020 Report Share Posted September 1, 2020 This is my HDT. The car goes up the ramps length wise and a small RZR rides cross wise under the car. The black boxes on the bed are steel covered 100 gallon fresh and waste tanks. The ramps across the bed just ahead of the hitch deploy for the car and 2 are used for the RZR. The front of the car extends over the cab. The half round stops on the far end catch the front tires of the RZR. Unfortunately I don't have a picture of the truck loaded with me now. Quote Link to post Share on other sites
Lance A Lott Posted September 1, 2020 Report Share Posted September 1, 2020 There is a device called the Claw, I think, that comes in a HDT size there are also ways to turn you drive wheels into a winch. There was a guy on here that went winter camping pulling his camper with a slead. Quote Link to post Share on other sites
rickeieio Posted September 1, 2020 Report Share Posted September 1, 2020 A small winch will pull a lot, with pulleys. Think block and tackle. You don't need to lift the truck, just provide some additional pull. Not a good solution if you expect to use it a lot, but it would do in a a pinch. Quote Link to post Share on other sites
steiny93 Posted September 1, 2020 Report Share Posted September 1, 2020 the bummer about a winch is that you tend to not have an attach point where you need one Concerning the sizing. I run 12k winches on the jeeps; we've been in many situations where that isn't enough. Quote Link to post Share on other sites
mr. cob Posted September 1, 2020 Report Share Posted September 1, 2020 Howdy Nwcid, Found this, put a sleeper on the rear deck and call it good, yeah it's not as nice inside as the usual HDT used for dragging a camper but it should do what you want to do and its CHEAP. $17,500 Get Financing as low as $294.00/month* Stock #: - Odometer: - Military Trucks - EXTRA LONG WHEEL BASE- DUAL 14 X 20 DRIVE TIRES, HEAVY REINFORCED FRAME, CAB HEAT, CUMMINS DIESEL, 5 SPEED TRANSMISSION, CAB HARD TOP, EXCELLENT SHAPE, MILITARY REBUILD T... More Info Eastern Surplus & Equipment Philadelphia, PA Dave Quote Link to post Share on other sites
Nwcid Posted September 1, 2020 Author Report Share Posted September 1, 2020 8 hours ago, rickeieio said: A small winch will pull a lot, with pulleys. Think block and tackle. You don't need to lift the truck, just provide some additional pull. Not a good solution if you expect to use it a lot, but it would do in a a pinch. Yes, but snatch blocks also cost money along with the hardware needed to set them up. Often times you are better off going with a properly sized winch. Quote Link to post Share on other sites
Nwcid Posted September 1, 2020 Author Report Share Posted September 1, 2020 7 hours ago, steiny93 said: the bummer about a winch is that you tend to not have an attach point where you need one Concerning the sizing. I run 12k winches on the jeeps; we've been in many situations where that isn't enough. Yeah. Most recommend at least 2x whatever your weight is. I have always carried a block with me, but I have never needed it for a straight pull. Quote Link to post Share on other sites
Nwcid Posted September 1, 2020 Author Report Share Posted September 1, 2020 3 hours ago, mr. cob said: Howdy Nwcid, Found this, put a sleeper on the rear deck and call it good, yeah it's not as nice inside as the usual HDT used for dragging a camper but it should do what you want to do and its CHEAP. $17,500 Dave While it would definitely off road, outside of that I do not think it would meet any of my other requirement. It would be cool to have one for sure. I have a neighbor that frequently drives one all around the county. Quote Link to post Share on other sites
