trimster Posted August 22, 2020 Report Share Posted August 22, 2020 I want to move switches around on the dash. How does one pop out the dash piece(s) that hold the switches? Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Parrformance Posted August 22, 2020 Report Share Posted August 22, 2020 Plenty of wire available, dash comes apart very straightforward. Remove the faux wood trim remove the torx screws and pull forward. If I recall most of the plugs were labeled. I moved all the switches closer to the steering wheel, and placed the 7 inch monitor in the space to the right, just like everyone else has. Might have taken an hour start to finish. Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
trimster Posted August 22, 2020 Author Report Share Posted August 22, 2020 "Might have taken an hour start to finish" ...but how much beer? Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Jaydrvr Posted August 22, 2020 Report Share Posted August 22, 2020 Which generation? Mine is first gen and you remove the ashtray to access the screws behind, then carefully pop out the trim panel to the right of the steering wheel, which gives access to all the trim screws in that set of panels. Jay Quote Link to comment Share on other sites More sharing options...
trimster Posted August 22, 2020 Author Report Share Posted August 22, 2020 2015, so 2nd gen I think. Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted August 22, 2020 Report Share Posted August 22, 2020 If you’re talking about the whole section to the left of my duct they just have plastic clips so access by directions of Parrformance. If you’re talking about the little black inserts where the switches go ...same thing, they are just clipped in. Push from front carefully (easy to break the tabs.). As to the faux wood trim below, start from the right with a flat head screw driver and gently pry. It is spring clipped in. DON’T start from left as it has a “hook” on that end that easily breaks off. You’ll see as you work from right to left. Switches themselves will just clip into the panel so you can arrange any way you wish. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
trimster Posted August 22, 2020 Author Report Share Posted August 22, 2020 Perfect. Thanks all. Will be digging into it today. Man, the smoke from Utah & calif fires is thick here in Salt Lake. Ugh. Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
alan0043 Posted August 22, 2020 Report Share Posted August 22, 2020 1 hour ago, SuiteSuccess said: If you’re talking about the whole section to the left of my duct they just have plastic clips so access by directions of Parrformance. If you’re talking about the little black inserts where the switches go ...same thing, they are just clipped in. Push from front carefully (easy to break the tabs.). As to the faux wood trim below, start from the right with a flat head screw driver and gently pry. It is spring clipped in. DON’T start from left as it has a “hook” on that end that easily breaks off. You’ll see as you work from right to left. Switches themselves will just clip into the panel so you can arrange any way you wish. 2X with what Carl said. Be very careful with the faux wood trim. Have a beer or two after you have the faux trim removed. Quote 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
Parrformance Posted August 22, 2020 Report Share Posted August 22, 2020 If you have a porta John in the cabinet behind the drivers seat, as I do you can have as many beers as you can drink in an hour. Be careful when climbing out of the truck though, go out the door where the grass is. Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
trimster Posted August 22, 2020 Author Report Share Posted August 22, 2020 Porta john....check. Beers in truck fridge....check. Passengers side faces neighbors lawn....check. Good to go! Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
rickeieio Posted August 22, 2020 Report Share Posted August 22, 2020 Exit cab feet first, uh-oh!!! Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Parrformance Posted August 22, 2020 Report Share Posted August 22, 2020 A watered lawn is softer, I'm just sayin' Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
trimster Posted August 23, 2020 Author Report Share Posted August 23, 2020 Switches moved. The air hitch adjuster switch will just hide inside the dash for now.. Monitor velcro'd in place. No beers were harmed during installation. I damaged a few home brew ciders, however. Now to run the 4 camera cables. That should be right up there on the fun meter. Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted August 23, 2020 Report Share Posted August 23, 2020 41 minutes ago, trimster said: Switches moved. The air hitch adjuster switch will just hide inside the dash for now.. Monitor velcro'd in place. No beers were harmed during installation. I damaged a few home brew ciders, however. Now to run the 4 camera cables. That should be right up there on the fun meter. Bob Nice. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Parrformance Posted August 23, 2020 Report Share Posted August 23, 2020 5 maybe 6 tall boys, I suspect. Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted August 24, 2020 Report Share Posted August 24, 2020 16 hours ago, SuiteSuccess said: Nice. Looks good Bob. Quote Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
Chad Heiser Posted August 25, 2020 Report Share Posted August 25, 2020 Looking good. Quote 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
