SuiteSuccess Posted May 28, 2020 Report Share Posted May 28, 2020 (edited) I have the TST 507 tpms on truck and trailer. I need to replace several of the cap 0 rings (not the stem) and was wondering if anyone could tell me the size of the ring or has a loose one they could measure? I know you can order them from TST but they only have the kits with six o rings, six stem seals, and screws. I have all the screws and stem seals I need so going to try and source the o rings themselves in bulk. Also if you know of a source would appreciate that link also. Small O ring and stem seal. Edited May 28, 2020 by SuiteSuccess Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
durangodon Posted May 28, 2020 Report Share Posted May 28, 2020 In the past, I called them and they sent me o-rings at no charge. Quote Link to comment Share on other sites More sharing options...
SuiteSuccess Posted May 28, 2020 Author Report Share Posted May 28, 2020 (edited) 41 minutes ago, durangodon said: In the past, I called them and they sent me o-rings at no charge. Thanks, yes they used to but now do not. You have to purchase the kit, I mentioned above at $8 for 6 O rings, 6 stem seals, and 6 screws. I have 14 sensors so $25 plus shipping is a little pricey to use just the O rings. I think if I get the size I can buy in bulk much cheaper. Edited May 28, 2020 by SuiteSuccess Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Parrformance Posted May 28, 2020 Report Share Posted May 28, 2020 I have a local shop, called Rubber and accessories. It's in Lakeland Florida. I suspect that there's other places like this in other communities but they always have the O-rings I need on hand. Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Jim & Wilma Posted May 28, 2020 Report Share Posted May 28, 2020 The o-rings I use are 11mm x 1mm nitrile. They're a tight stretch and other sizes may fit better and I may try another size if I ever use all these. I break about every fifth one when I put them on but have had no problems with water intrusion once installed. I also put a very small dab of silicon grease on the threads to help seal and thread the cap tight. You can buy these nitrile o-rings from Amazon. Quote Jim & Wilma 2006 Travel Supreme 36RLQSO 2009 Volvo VNL730, D13, I-shift, ET, Herrin Hauler bed, "Ruby" 2017 Smart Class of 2017 Link to comment Share on other sites More sharing options...
SuiteSuccess Posted May 28, 2020 Author Report Share Posted May 28, 2020 4 minutes ago, Jim & Wilma said: The o-rings I use are 11mm x 1mm nitrile. They're a tight stretch and other sizes may fit better and I may try another size if I ever use all these. I break about every fifth one when I put them on but have had no problems with water intrusion once installed. I also put a very small dab of silicon grease on the threads to help seal and thread the cap tight. You can buy these nitrile o-rings from Amazon. Thanks Jim. Will give them a try. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
rickeieio Posted May 28, 2020 Report Share Posted May 28, 2020 Carl, If I remember correctly, there's a hydraulics shop off 321 on the east side of Maryville. South side of road. But as mentioned above, any decent hydraulics or rubber shop should be able to fix you up. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
SuiteSuccess Posted May 28, 2020 Author Report Share Posted May 28, 2020 (edited) 1 hour ago, rickeieio said: Carl, If I remember correctly, there's a hydraulics shop off 321 on the east side of Maryville. South side of road. But as mentioned above, any decent hydraulics or rubber shop should be able to fix you up. Rick, Thank you. I ordered 100 of the ones Jim recommended. I have some silicone grease already so will give both a try. $5 and change for 100. Better than $8 for six. BTW looking forward to Monday. 😊 Edited May 28, 2020 by SuiteSuccess Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
rickeieio Posted May 29, 2020 Report Share Posted May 29, 2020 19 hours ago, SuiteSuccess said: BTW looking forward to Monday. 😊 Me too. Be there, or be.....not there. Washed trailer and checked tires. Almost ready to roll. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Star Dreamer Posted June 2, 2020 Report Share Posted June 2, 2020 (edited) We haven't used the orings on our sensors for quite some time now. So far no issues. Edited June 2, 2020 by Star Dreamer Quote 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
wihakowi Posted December 18, 2020 Report Share Posted December 18, 2020 Greetings to an old post! I too, am in need of the cap sensor "body" sealing o-rings mentioned above. When I open up the referenced Amazon listing, it gives a description of a much smaller size than I need! More like the "valve stem side" o-rings size. What I need are about 23 mm OD X 1.5 mm thick (7/8" X 1/16"). Any further advice, clarification or sourcing would be great. Thanks, Steve Quote Link to comment Share on other sites More sharing options...
Jim & Wilma Posted December 18, 2020 Report Share Posted December 18, 2020 7 minutes ago, wihakowi said: When I open up the referenced Amazon listing, it gives a description of a much smaller size than I need! I agree they're pretty small and don't recall whose "good advice" I followed in getting these. I'm on my second round of 12 sensors worth of battery replacements using these and have had no signs of water intrusion. Larger would be easier to slip on though can't attest they'd work better. I break about every fifth one but must have 70 left, so until they're gone I won't be buying others. If/when I do buy more, I might upsize to say 20mm x 1mm. Quote Jim & Wilma 2006 Travel Supreme 36RLQSO 2009 Volvo VNL730, D13, I-shift, ET, Herrin Hauler bed, "Ruby" 2017 Smart Class of 2017 Link to comment Share on other sites More sharing options...
Dutch_12078 Posted December 18, 2020 Report Share Posted December 18, 2020 Like Stardreamer, I haven't used the body O-rings for about 5 years now. I put a dab of silicone grease on the threads as a sealer and haven't had any problems. I also leave the rotating security covers off, making the sensors less noticeable and a bit lighter. That also makes removing them to air up no different than removing a standard valve cap, and even a little easier for arthritic fingers. Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
