castlewood57 Posted April 8, 2020 Report Share Posted April 8, 2020 I have 2007 Volvo 670 last run I was on the wipers worked fine, but the washer pump has quit. Will be checking fuses, but I didn't see one for the washer fluid, only for the wiper motor itself. Any suggestions before I start randomly pulling and testing fuses? Is there another area other than middle of the top of the dash fuse panel? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
SuiteSuccess Posted April 8, 2020 Report Share Posted April 8, 2020 47 minutes ago, castlewood57 said: I have 2007 Volvo 670 last run I was on the wipers worked fine, but the washer pump has quit. Will be checking fuses, but I didn't see one for the washer fluid, only for the wiper motor itself. Any suggestions before I start randomly pulling and testing fuses? Is there another area other than middle of the top of the dash fuse panel? Thanks in advance. Don’t know about a fuse but mine did the same thing. Just quit. I replaced it and has been fine since. Located on my 780 on back side of reservoir which is behind batteries on drivers side. Was easy to replace. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
castlewood57 Posted April 8, 2020 Author Report Share Posted April 8, 2020 1 hour ago, SuiteSuccess said: Don’t know about a fuse but mine did the same thing. Just quit. I replaced it and has been fine since. Located on my 780 on back side of reservoir which is behind batteries on drivers side. Was easy to replace. Hmm .. Ok, Looks like get to crawl under, will wait until it warms up a bit. Quote Link to comment Share on other sites More sharing options...
rickeieio Posted April 8, 2020 Report Share Posted April 8, 2020 Before you start digging for fuses, check that you actually have fluid, and that the hoses are connected. These things hold a LOT of fluid, and those rubber lines don't last forever. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted April 9, 2020 Report Share Posted April 9, 2020 If the tank had fluid and froze, it will crack. The WW tank on our Volvo 610 cracked while in Kansas 2 winters ago... temps were in the teens or high single digits and the Walmart brand "Good to -20*" fluid froze.... and cracked the tank. Quote Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Exile Posted April 9, 2020 Report Share Posted April 9, 2020 Mine only works on passenger side. Driver side is clear when blown with air, and when the hose is disconnected it will flow from the pump, just won’t spray through the nozzles. maybe weak pump, looked in it, but can’t see anything. Quote 98 379 with 12.7 DD LG Dodge w/5.9 CTD Chrome habit I’m trying to kick. Link to comment Share on other sites More sharing options...
Pat & Pete Posted April 9, 2020 Report Share Posted April 9, 2020 11 hours ago, Exile said: Mine only works on passenger side. Driver side is clear when blown with air, and when the hose is disconnected it will flow from the pump, just won’t spray through the nozzles. maybe weak pump, looked in it, but can’t see anything. Have you passed a needle or small wire through the spay nozzle on the drivers side ? You might try clamping the passenger side hose to force fluid into the other side , as a test . Quote Goes around , comes around . Link to comment Share on other sites More sharing options...
Exile Posted April 9, 2020 Report Share Posted April 9, 2020 T pin won’t fit through, hole too small, I will clamp pass side, good idea. Quote 98 379 with 12.7 DD LG Dodge w/5.9 CTD Chrome habit I’m trying to kick. Link to comment Share on other sites More sharing options...
Pat & Pete Posted April 9, 2020 Report Share Posted April 9, 2020 If you have a standard wire brush , try clipping a single wire and using that to 'test' the nozzle hole . It's what I use . Quote Goes around , comes around . Link to comment Share on other sites More sharing options...
Parrformance Posted April 10, 2020 Report Share Posted April 10, 2020 Welding Torch tip cleaners are $5 on Amazon, great tool to have in the tool box. Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Jaydrvr Posted April 10, 2020 Report Share Posted April 10, 2020 On 4/9/2020 at 1:13 AM, Exile said: Mine only works on passenger side. Driver side is clear when blown with air, and when the hose is disconnected it will flow from the pump, just won’t spray through the nozzles. maybe weak pump, looked in it, but can’t see anything. Just replace the arm to get a new spray nozzle. They're inexpensive and the springs don't last all that long anyway. Jay Quote Link to comment Share on other sites More sharing options...
Pat & Pete Posted April 10, 2020 Report Share Posted April 10, 2020 4 hours ago, Jaydrvr said: Just replace the arm to get a new spray nozzle. They're inexpensive and the springs don't last all that long anyway. Jay The nozzles on our rig clamp onto the arms . I wouldn't think they come as a set . But ??? Quote Goes around , comes around . Link to comment Share on other sites More sharing options...
Jaydrvr Posted April 10, 2020 Report Share Posted April 10, 2020 (edited) 49 minutes ago, Pat & Pete said: The nozzles on our rig clamp onto the arms . I wouldn't think they come as a set . But ??? The arm comes with the new nozzle attached. Between the new spray nozzle and the new spring hugging the wiper blade to the glass, it's a worthwhile investment that'll make you smile every time you use it. Just watch out for the occasional improperly manufactured arm. I went through every arm in the dealer's stock, but ended up using my Dremel to "adjust" it. Hopefully, they've corrected that since. Jay Edit.. My truck is a '99 Volvo. Don't know about other brands. Edited April 10, 2020 by Jaydrvr Quote Link to comment Share on other sites More sharing options...
