SuiteSuccess Posted August 7, 2017 Report Share Posted August 7, 2017 My cable internet by Xfinity has an approximate 50' run from the pedestal to the distribution connection. This was done with direct bury cable (orange) which I believe is RG11 flooded. Well we're having a retaining wall built and even though the path was marked the mini- excavator guy cut the cable trying to get close. They made a one foot splice to repair with RG6 and supposedly waterproof connectors. I'm thinking this is a future problem so how should it be done before the section is reburied? 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
avvidclif Posted August 7, 2017 Report Share Posted August 7, 2017 Buried splices are a problem in the making. Make them replace it. You don't want splices underground, especially with unk suspect cable. Link to comment Share on other sites More sharing options...
castlewood57 Posted August 8, 2017 Report Share Posted August 8, 2017 I'd replace as well. After 9 years of internet support for a rural phone company, I definitely agree with the replacement. Link to comment Share on other sites More sharing options...
Hot Rod Posted August 8, 2017 Report Share Posted August 8, 2017 I'd absolutely replace the entire cable. Doesn't make sense to do otherwise, sounds like it will run under your wall and be a nightmare to replace later vs. very simple right now. I've got about 600' of this: http://www.ebay.com/itm/CAT6-550MHz-Outdoor-Waterproof-UV-Direct-Burial-Gel-Filled-Ethernet-Cable-1000FT-/122154846871?hash=item1c70ff0a97:g:yQkAAOSwTA9X9T8B left over from a project. not sure if that is what you need. let me know how much you need and I'll send it to you. This is just the cable, ends are not terminated. Let me know. Link to comment Share on other sites More sharing options...
Hot Rod Posted August 8, 2017 Report Share Posted August 8, 2017 Never mind, reread the op, you need coax not cat 6. stiil, if anybody needs some, let me know. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted August 8, 2017 Author Report Share Posted August 8, 2017 8 hours ago, Hot Rod said: Never mind, reread the op, you need coax not cat 6. stiil, if anybody needs some, let me know. Thanks for the offer anyway. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Jack Mayer Posted August 8, 2017 Report Share Posted August 8, 2017 Carl, as the others said, replace it. For sure. And if the retaining wall is substantial I'd be putting a conduit under it for this and any future "endeavors". Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
SuiteSuccess Posted August 8, 2017 Author Report Share Posted August 8, 2017 Thanks everyone for the help. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
RickW Posted August 8, 2017 Report Share Posted August 8, 2017 I agree replace it all. Otherwise it is a future headache waiting to happen. I also agree with Jack that at the very least run conduit under the wall. If feasible I personally would run conduit from point to point. Technology has a tendency to change. Already having conduit in place for any possible future upgrade/change will make life easier. 2017 Entegra Anthem 44A SOLD - 2004 Volvo 780. 465hp and 10sp Auto Shift (from 2010~2017) SOLD - 2009 Montana 3400RL Link to comment Share on other sites More sharing options...
Imurphy907 Posted August 8, 2017 Report Share Posted August 8, 2017 Don't bury a splice. Make the contractor replace it from the ped to your house. 2016 Road Warrior 420 2001 Volvo VNL 660 Alaska Based. Link to comment Share on other sites More sharing options...
RandyA Posted August 8, 2017 Report Share Posted August 8, 2017 Carl, if for some reason the contractor will not replace the cable each end that has been cut should be brought up out of the ground in PVC conduit and the splice made above ground in a junction box. This may result in two above ground boxes with the splice running between them. Remember, anything stamped waterproof will leak and anything underground will eventually succumb to the wrath of the minerals in the soil/water, moles, shrews, or whatever. Your wall contractor will be long-gone when this happens. If you have RG-11 splicing with RG-6 will change the characteristic impedance of the entire cable run which can be a problem with high speed data lines much more so than TV. Your cable/Fios company actually owns that line and should be notified to see how they want it repaired. Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
SuiteSuccess Posted August 8, 2017 Author Report Share Posted August 8, 2017 Talked to contractor. We are going to rerun entire line from box to box with RG11 flooded cable. I was able to get 100 ft with ends already on for $50 on amazon. He will pay and his guys will bury. Last time I tried to get Xfinity to respond took 5 weeks and 6 phone calls so just going to replace with same cable. Seems that the cable companies have one team to connect and lay an orange cable across your lawn but a second team to come dig your lawn up and put it 8" underground. No communication between the two. Took all of 30 minutes to bury. Thanks again for the advice. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Jack Mayer Posted August 9, 2017 Report Share Posted August 9, 2017 5 hours ago, SuiteSuccess said: TSeems that the cable companies have one team to connect and lay an orange cable across your lawn but a second team to come dig your lawn up and put it 8" underground. No communication between the two. Took all of 30 minutes to bury. Thanks again for the advice. Generally the way it works is that the owning company lays the wire, and they contract another company to bury it. That is almost always the way it is done. So the guys burying it are just contractors....(typically). Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
ALLOY Posted August 10, 2017 Report Share Posted August 10, 2017 I run under ground gas, wiring, plumbing (Uponor) in PVC conduit. Protects the line and is serviceable. 2011 Cameo 34SB3 Link to comment Share on other sites More sharing options...
Sculptor Posted November 22, 2017 Report Share Posted November 22, 2017 Run conduit! X4. Over size diameter. With a wire knotted at both ends. When you install any wiring later you will be glad you did. Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
SuiteSuccess Posted November 22, 2017 Author Report Share Posted November 22, 2017 Thanks folks for all the good suggestions. Got it done. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
lockmup68 Posted November 22, 2017 Report Share Posted November 22, 2017 Highly agree to put conduit under the wall for next time it needs replacing. Sometimes those cables just develop a break and you have to pull a new run. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
