Camera install today
Quickthrotl
Yep, good job.  Did you do it yourself?
2017 DRV 39DBRS3
Dan
I would be happy to share with you the "secret"
for switch relocation when you show up at the 2017 WCR.
"the secret is..... most of the wire harnesses to the switches are extra length so all you do is remove the switch and relocate it to the desired location".
9 minutes ago, MrSeas said:
Dan
x2 very easy.
2017 DRV 39DBRS3
I used my deemed tool and cut out down to where the switches bottom out when they are snapped in
to mount it I used the mount that came with it. I modified it of course
it is a 7" monitor
2004 Volvo VNL 780
2017 Momentum 376TH
2007 Harley Davidson FLHTC
2009 Smart4two
2 hours ago, Quickthrotl said:
Very easy plenty of wire
Hi Quick,
Where did you get your 12 volts from ? I know that the trucks fuse box is behind the monitor. If you tapped into the fuse box, where did you do it ? Do you have any pictures of your 12 volt connection ? My next project is to install my camera. Part of my plan is to install the monitor the same place that you did.
Al
i pulled it right off the fuse panel, i took my multimeter and found a connection that was only powered with the key on, i used an empty spot where you would put a fuse and used a spade connector and pushed it in
2004 Volvo VNL 780
2017 Momentum 376TH
2009 Smart4two
I did the same.  Here is a pic.
I'm going to re-wire as I didn't put a fuse in line when I originally wired.
2017 DRV 39DBRS3
http://www.ebay.com/itm/like/131329893013?lpid=82&chn=ps&ul_noapp=true
Fuse tap- This particular style lets you use the original fuse spot to continue to power its intended equipment, and the "New" side to power what you need.  I have the factory 12V CB radio clips/pins/hook-ups on the passenger side of the dash.  I utilize that fuse to power several items that I want full time power to.   Other fuse taps are on the Key-On side like carl's cameras are.
Alie & Jim + 8 paws
2017 DRV Memphis
BART- 1998 Volvo 610
Lil'ole 6cyl Cummins
2 hours ago, rdickinson said:
Not deep enough to take a Double dinnnnn Garmin Nav system.  The fuse panel gets in the way.  The Garmin was installed below which will be changed when I get back home in May.
That is why I was asking Roger, great minds think alike! Lol
There is a 2-din unit that has a 10" monitor on it that would perfect for that spot, IF, you had the depth behind it.
How are you going to change your install?
John
Southern Nevada
2008 Volvo 780, D13, I-Shift
2017 Can-Am Maverick X3-RS
Thanks Jim, gotta get me some of those for my re-wire if I have room.  Do they make them with the mini-fuse on top rather than on side?
2017 DRV 39DBRS3
It may not necessarily be the Garmin that is too deep but the metal shell or case it fits in.  There were several as I recall but only one would fit in the space and it made the radio stick out of the higher opening.  Putting the Nav device in the lower one like mine is not the answer.  It's too far outside the field of vision and could be dangerous.  Being in the vehicle it is no use to me as a trip planning tool which can be used at home.  There is nowhere near as much detail as the Microsoft Streets and Trips program.
The Garmin is better at voice directions, but the cellphone with google earth is better still.  I often use the cel and Garmin in the Smart a the same time.  Example, ask the phone for Fort Myers Costco.  It comes up then hit directions and off you go.  Costco has a ice cream and straw berry sundae for 1.65$  I know where all the ice cream and onion ring joints are.
About future plans, truck Garmin comes out, perhaps replaced with a bigger tablet  in the area above.  Just peeking up above the top of the dash but not by much. I'll see how the garmin or another program looks and works compared to MS&T.  MS is older tech, voice commands are not as good as Garmin or cel phone.
Also the touch screens are a pain, fingerprints leave a smudge and a lot of  fingerprints leave a lot of smudges which in certain conditions makes the screen tuff to read.  This is compounded if you have greasy fingers from eating onion rings on road....bad grammar.
I still like my Toshiba roller trackball mouse to move the cursor for MS.  Mouse sits on a side table , mouse has Velcro to keep it in place.
Above or sitting on top of the dash is a 3x12" or close to it, monitor which has the front fender  and the rt side rear looking camera.  Both mounted on the rear view mirror on the truck door.  Very tite for wiring in the mirror arms.
To sum up, it will have to wait 'till I get back to Victoria and test out some options.
On 3/19/2017 at 9:05 AM, VaOutlaw said:
Very nice install.  Do you have the part numbers for that monitor and camera you used by any chance?  Thanks
I bought it from Leviathan _holdings on EBay seven years ago. I heard recently he is liquidating his stock so look on EBay and see if he is still there. Sorry don't have parts numbers.
2017 DRV 39DBRS3
That is also where I got mine just a few weeks ago
2004 Volvo VNL 780
2017 Momentum 376TH
2009 Smart4two
