CHIEFWAHO Posted February 23, 2017 Report Share Posted February 23, 2017 Help me source side windows for our sleeper - 1999 Volvo VNL 610 Would like something that slides or hinges/tilt open. Iv'e reviewed this: http://hhrvresource.com/node/186 First truck looks like they used Volvo lower windows and trim. But I do not see any mention of what windows and trim they used on the second. I wouldn't mind the larger window as shown here: http://rjnatter.tripod.com/id2.html Once again no mention of window and trim used? I don't have a problem relocating supports as shown on driver sidewall. But not sure what to do on the passenger side is there is a vent duct running up the wall. It is mentioned on last picture of duct relocation but I don't really follow what has been done. I called about these Volvo uppers but they will not include any interior trim. Guess the interior trim piece is large and runs from window to headliner so they keep it with the sleep/cab. https://www.vanderhaags.com/detailview.php?part=24530252 Also called about these Volvo lower windows from a 2003. Can someone explain how these windows install. The guy at Vander Haags says the only way to get the frame work I'd need would for them to sawzall it out the side of the sleeper. Is that correct????? This thread shows how to repair these windows when they become loose. http://hhrvresource.com/node/180 There are a couple of pictures but I just can't tell how the windows mount. https://www.vanderhaags.com/detailview.php?part=24510940 https://www.vanderhaags.com/detailview.php?part=24510941 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
lockmup68 Posted February 23, 2017 Report Share Posted February 23, 2017 off topic, see you are in Kansas, you know Jake Good? Bronco buddy of mine. on-topic: I'm in same boat for windows for the International. From what I can tell, any RV window would work, just cut a hole window pops on from outside, and you use the provided hardware to attach the smash mount from the inside. The framing just needs to be consistent. Trim pieces are hit and miss and have to be adapted. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted February 23, 2017 Author Report Share Posted February 23, 2017 off topic, see you are in Kansas, you know Jake Good? Bronco buddy of mine. on-topic: I'm in same boat for windows for the International. From what I can tell, any RV window would work, just cut a hole window pops on from outside, and you use the provided hardware to attach the smash mount from the inside. The framing just needs to be consistent. Trim pieces are hit and miss and have to be adapted. I know of Jake. Isn't he now running the new 4WheelParts in KC ? I followed his Bronco build and see him with it at Kansas Rocks Park once in awhile. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
SIBERNUT Posted February 24, 2017 Report Share Posted February 24, 2017 I used sleeper windows from a F-liner turned 90 degrees. Should be in HHRV, if not ping me. They do have an inside trim. 2000 Volvo 635 A/S, N-14 Cummins"The Phoenix"'03 KA 38KSWB http://s918.photobucket.com/user/sibernut/library/?sort=6&page=1Furkids- Sibe's CH. Sedona & Tseika Link to comment Share on other sites More sharing options...
lockmup68 Posted February 24, 2017 Report Share Posted February 24, 2017 I know of Jake. Isn't he now running the new 4WheelParts in KC ? I followed his Bronco build and see him with it at Kansas Rocks Park once in awhile. Yup, that's him. Good people. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
roadfitter Posted February 26, 2017 Report Share Posted February 26, 2017 CHEIF Try Bontragers RV Salvage in White Pigeon, MI. They have many types and sizes and are very helpful. If you can ask for Daryl. roadfitter roadfitter 2000 T-2000 10 speed autoshift DD430/500 H.P. 2001 Alfa 39' Toyhouse http://community.webshots.com/user/roadfitter597 Holiday lite trucks. Link to comment Share on other sites More sharing options...
lockmup68 Posted February 26, 2017 Report Share Posted February 26, 2017 http://www.ebay.com/itm/RV-Trailer-Window-with-Trim-Ring-17-x-21-approx-/381976969084 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted March 1, 2017 Author Report Share Posted March 1, 2017 I used sleeper windows from a F-liner turned 90 degrees. Should be in HHRV, if not ping me. They do have an inside trim. Thanks SIBERNUT! Have a set of lower sleeper windows & interior surround /trim rings sourced, should have them Friday. They are from a 2006 Freightliner C120 Century. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
lockmup68 Posted March 2, 2017 Report Share Posted March 2, 2017 where did you get them? 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
Jeff.Sloan Posted March 2, 2017 Report Share Posted March 2, 2017 I used sleeper windows from a F-liner turned 90 degrees. Should be in HHRV, if not ping me. They do have an inside trim. I put FL Columbia sleeper windows on my 630, but they leak. The fixed slider portion has holes on the sides to hold the slider window open. Once the window is rotated 90 degrees these holes become leak points into the window frame. I silicon'd mine and cut new drain holes in the outer channel, but it still seeps in heavy rains. I was thinking about having custom windows made so they won't leak any more . . . 2004 Volvo 630, Cummins ISX, Eaton 10 speed (air assist clutch), 3.71 3.07 rear locker, ET jr, 200" WB, GearMaster 2017 Forest River Sierra 372LOK Full time June 2017 DW, 2 kids, and 2 dogs Link to comment Share on other sites More sharing options...
SIBERNUT Posted March 2, 2017 Report Share Posted March 2, 2017 I put FL Columbia sleeper windows on my 630, but they leak. The fixed slider portion has holes on the sides to hold the slider window open. Once the window is rotated 90 degrees these holes become leak points into the window frame. I silicon'd mine and cut new drain holes in the outer channel, but it still seeps in heavy rains. I was thinking about having custom windows made so they won't leak any more . . . Don't know what to say, but mine don't leak. Maybe a factor is that I put smoke-colored rain deflectors above them. I seem to remember they were for the back door windows on a 4 door pickup. Then both front & back edges turn down, not like a front. PM me for pic if you want 2000 Volvo 635 A/S, N-14 Cummins"The Phoenix"'03 KA 38KSWB http://s918.photobucket.com/user/sibernut/library/?sort=6&page=1Furkids- Sibe's CH. Sedona & Tseika Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted March 2, 2017 Author Report Share Posted March 2, 2017 where did you get them? www.vanderhaags.com 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted March 23, 2017 Author Report Share Posted March 23, 2017 Been slow going! After lots of measuring and thinking. We determined our window would fit in between the horizontal supports. The side Volvo vent windows were removed. Next the we cut the bottom and top vent window frame work to lay down out cut lines for the new windows. The lower had spot welds that were drilled out. Upper area was cut. Made this handy tool to cut thru the panel adhesive. Little damage to my fingers, should of had gloves on. Band aids and a little electric tape. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted March 23, 2017 Author Report Share Posted March 23, 2017 After transferring our cut lines from inside to outside it was time to cut some metal! Trial fit, nailed it the first time! From the inside. Interior panel back in to mark for it's new cut out. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted March 23, 2017 Author Report Share Posted March 23, 2017 New opening for the interior panel. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted March 23, 2017 Author Report Share Posted March 23, 2017 Ready for window final install. These were originally vertical windows so some new drain holes were drilled on the now bottom side. Still have a lot of interior trim cutting and fitting to do. Hope to get it all buttoned up this weekend. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
lockmup68 Posted March 23, 2017 Report Share Posted March 23, 2017 nice, this is exactly what I need to do in the Intl. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
noteven Posted March 23, 2017 Report Share Posted March 23, 2017 Those will go nice with the fender skirts on your deck Chief "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Star Dreamer Posted March 24, 2017 Report Share Posted March 24, 2017 I have used C.R. Laurence for sunroofs before and they carry numerous different Van and RV side windows. Here is a link to their vertical sliding ones: http://www.crlaurence.com/crlapps/showline/offerpage.aspx?ProductID=4582&GroupID=2395&History=30587:21889:16124:21889:2089:2102&ModelID=2395&pom=0 They have horizontal sliding and fixed windows and have interior trim pieces for them. Dave 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted March 27, 2017 Author Report Share Posted March 27, 2017 Getting closer! Made some clips to help keep interior panel in place and secure the window trim. Moving the rear air control panel Coming together nicely, also mounted controls for the new back wall heat/ac unit. Started on the passenger side. We are also adding a factory upper cabinet to house the microwave. Plan to put a 110v receptical box and a cord off it for a place for a microwave to get power. Had to revised the trucks rear air duct work. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted March 28, 2017 Author Report Share Posted March 28, 2017 Passenger side moved the vents, doubled them in 1 location 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
Chad Heiser Posted March 28, 2017 Report Share Posted March 28, 2017 Nice job with the whole project. I'd like to do something like this with my T2000 some day. 2009 Volvo 670 with dinette/workstation sleeper - Walter 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage) My First Solar Install Thread My Second Solar Install Thread & Photos and Documents Related to the build My MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted March 29, 2017 Author Report Share Posted March 29, 2017 20 hours ago, Chad Heiser said: Nice job with the whole project. I'd like to do something like this with my T2000 some day. Thanks! 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted March 29, 2017 Author Report Share Posted March 29, 2017 FYI, when you go to remove the front seat belts. Be sure to clip the belts so they can not retract. We are learning the hard way. We let them fully retract and can not get them to release. Have google searched for fixes but so far none have worked. Hope we don't end up having to buy replacements. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
