I need help testing Maximum Signal booster at Escapees park in Livingston.
chiefneon
Posted
Howdy!
We recently purchased a Maximum Signal booster to help us with our internet in our travels. We also have a homebase at the Escapees in Livingston, TX. We recently witched our phone service from Verizon to AT&T and the service here at our location in Livingston is weak to non existant. That's why we purchased the Maximum Signal booster. Gordon has been very helpful trouble shooting problems we maybe having, but we are still not getting a good Signal as it goes in and out. Gordon believes it maybe due to our devices. When we switched to AT&T we purchased all new phones and tablets which are Apple (iPhones and iPads). Gordon states Apple is the worst devise on the market having the weakest radio Signal in them. My next and last check is to see if this Maximum Signal booster will work with a Android devise. So I'm in need of an Escapees friend at the Rainbow park here in Livingston with a Android phone that has AT&T service to help test to see if it works on Android but not Apple. Please give me a call if you can help 832-483-8509.
"Happy Trails"
Chiefneon
"Class of 2007 Fulltimer's"
Gary & karen
Smoochie & Michaela (fur babies)
2018 Chevorlet 3500 HD/LTZ 2L Custom Hauler
2014 Heartland Cyclone 4000
2016 Smart Car Prime
Posted
You might post a request for help in the club house?
You also might just go ask around with some of the other park members, what services provider they have, and how their signal is working for them. If others are doing OK on AT&T, that could be a positive for you. If they are not, then that is an indication that the AT&T signal and or tower traffic, is not real good in the area.
As I understand it, the recent FCC rules require Amps to be sold with a pretested and approved combinations of antennas(?). That being said, a different external antenna might serve you better then probably the 13" Mag unit that is so popular with the Max Signal Amp. A yaghi antenna, up on a partners pole a bit higher off our roof, might get you a stronger signal.
And while I have heard that iPhone Antennas have had problems in previous model phones, I do not recall hearing that lately on say the 5S and above. (Gord knows more about this stuff then I do:)!) That being said, even if the antenna in your iPhone is weaker, it really should not matter too much - as you are pulling in the signal from the inside the coach internal repeater antenna, not the tower(?).
Best of luck to you,
Smitty
Be safe, have fun,
Smitty
Posted
At Livingston at the moment using ATT; signal is good with no boost or external antenna. I have Apple stuff tho, so not sure if any of this helps you since you have Android.
And what Smitty said-my phone is far weaker everywhere than my mobile hotspot. Not sure why.
Ya just can't RV without a hitch.....!
Posted
Don't know wherein Livingston you are located, but @ Rainbows End ATT signal strength sucks ! Makes no sense to blame iStuff if the Max Signal thing was working fine, then not, then is....on several iDevices. What's common to all the iStuff ..... the Max Signal, and ATT.
Dave W. KE5GOH
Stuck in the 70's ---
In E. Texas
Posted
Smitty
The actual radio in the Iphone is weaker . , We have proved it when out testing . We will go to areas with an Iphone and a Samsung . The Samsung will still sense some signal ( low Level) While the Iphone just displays no service . With the Amp on the Samsungs will rock while the iphones still experience signal drop out even with a db level in the 90's . Weakest part of their devices is the Transmit and receive radios . Just trying to troubleshoot exactly what is happening there and you cannot do it with an IPHONE . This is why apple will not approve RF testing apps while Android now has 6 or 7 good ones. It will expose their flaw. This is common Knowledge to folks in Cellular RF. Iphones are great fashion .
accessary but!!!
Keeping You Connected
Proud Commercial Member #129 http://www.maximumsignal.net/
Posted
And my Chevy is much better than your Ford too! :rolleyes:
I'm no expert , but , I've seen a lot more Iphones not work when others have .
We've never been folks to follow the crowd though , so ...
Goes around , comes around .
Posted
You can think I do not know my stuff but I do and so do the RF engineers that work for us and other RF engineers I talk to on a regular basis. Sorry to insult the apple devices but it is their known weakness.
Posted
Howdy!
Gordon, As you can see I have not been able to test the Maximum Signal with a Android device yet. Dave did help me out by setting my iPhone so that it now shows the db level rather than dots. These db levels fluctuate while setting in the same spot from -87 -97, -111, -114, -118, -120 without any movement in a matter of few minutes. But it usually above -111 to -117. I haven't had any completely dropped service after disregarding the 110 volt and plugging into12 volts.
Folks as for the Apple vs Android we now have way to much invested in Apple in the last few months to start over again with Android. In April we purchased two new iPhone 6s Plus phone and two new iPad Pro's with data connections two make use of our unlimited data service. I purchased the Maximum Signal before returning to Escapees to solve this problem after we found out that as Dave stated AT&T is week here. Gordon has given us great customer service so I'm hoping with his help we can solve this issue.
"Happy Trails"
Chiefneon
Gary & karen
Posted
Maybe as Gordon says his Maximum Signal may or may not work very good with a iPhone.
And maybe his Maximum Signal web site should have that info included with the ad if he knows it is true. ;)
Full Time since Oct. 1999
99 Discovery 34Q DP | ISB
Posted
The problem is not compatibility with the device it is the actual radio in the device that makes it drop signal. The amplifier is providing a full signal to the device
Posted
I have an android and my DW has an iPhone 6s. we are on Verizon unlimited and she always has a weak signal. Took over 2 minutes to open PayPal web site on her phone. I grabbed my iPad Pro that is tethered to my phone and tested the speed. Download and upload were both over 10gbps. Even when her iPhone is conned by wifi to my phone, it is still slow as an old dog. I like my iPad, I can't stand an iPhone.
Ron C.
2013 Dynamax Trilogy 3850 D3
Posted
I don't want to be disrespectful, but are you aware of the fact that the signal strength is displayed as negative numbers because the smaller the number the LARGER the signal is? You may already know this, but the way you phrased this answer caused me to wonder if you did.
As for whether or not an amp can help in a particular situation often it is helpful to know more about the signal than just its overall intensity. There are available phone apps that you can download which provide additional information but you would need to understand how to interpret the data they provide. For example, at our current location my Android Galaxy S7 operates quite well with an overall signal strength of about -104dBm but that's with exceptionally good Signal to Noise (SNR) and RSRP values. The same signal strength might not perform as well if the other parameters had different values. And how fast your speeds are at any particular tower is a complex function which involves these signal parameters and the overall load on the tower.
I have one of Gord's amps and it has performed well for the past several months, but I'm not normally in an area with a weak enough signal for it to strut its stuff. But a few weeks ago we suffered an outage on our Verizon tower and I'm pretty confident that the Max Signal amp was what gave us any service at all during the outage.
Sandie & Joel
WiFiRanger Ambassador
Posted
What's the latest Gary ? With all the Boot Camp attendees there are bound to be 1 or 2 with Androids?
Dave W. KE5GOH
In E. Texas
Posted
Howdy!
Dave, I have not connected with any Escapees at Livingston that have AT&T service and a Android device to test the Maximum Signal.
The good news is without asking Gordon contacted me last Friday and advised he was shipping me a new Maximum Signal and new 110 volt connection. He stated he tested it to make sure everything was working on AT&T, Verizon and Sprint. I received it yesterday and connected it up. The great news is it's working and we're getting a good signal no dropped calls and good data now. I can not say how much I appreciate the customer service that Gordon provides with his product. As RVer it is tuff to get good customer service from folks in our travels. Gordon has work with me over the phone and priority shipped things to us without question.
I would still like to test it comparing iPhone to Android if anyone can help.
Thanks for everything Gordon you've got a great product keep up the good work.
"Happy Trails"
Chiefneon
Gary & karen
Giraffe G4.
