mr. cob Posted May 6, 2016 Report Share Posted May 6, 2016 Howdy All, I recently bought and installed a scan gage for my truck, I am still figuring it out but on my last trip to and from my home in western Washington to Moab Utah and back I found some interesting things to discuss. In the past I have held my traveling speeds to 60-62mph as I thought that was were I would get the best fuel mileage, however using the gage and checking the numbers the gage gave by hand calculating gallons burned by miles traveled I have found that I get the same or better mileage while upping the speed. The gage can be set to display four different parameters on its face, I have it set to display, horse power being generated, percent of load on the engine, present fuel mileage in real time, and boost pressure. I have found that when in the mountains I climb hills faster and burn less fuel when running at higher speeds, sounds counter intuitive but the hand calculated numbers seem to prove it out. Running at 60-62mph, in 10th gear the truck would sometimes down shift into 9th, pull more boost and display more percent of load at higher horse power then when taking on the same hill at 70mph and staying in 10th gear. I ran from home to Moab using the gage to keep track of fuel mileage at my usual 60-62mph, on the return trip when safe and the speed limits allowed I ran at 68-70mph my hand calculated fuel mileage at both speeds was within a tenth of a mile per gallon. I am "assuming" that the aerodynamics of the truck really don't come into play until one drives over a minimum of 60mph and that being in the rpm range where the truck is producing more horse power thus less down shifting on steep grades is what makes the difference in how much fuel it takes to cover the same distance at different speeds. At 60-62mph my engine is turning1150-1200 rpm at 68-70mph its turning 1400-1450 rpm. My rear axle ratio is 3.55-1, engine is a Detroit 60 series 12.7L rated at 430-470hp. On a hard pull, pedal to the metal the maximum horse power displayed on the scan gage was 338 at 28 pounds of boost. I would be interested in hearing what others have to say about these numbers and my observations using the scan gage. Dave 2001 Peterbilt, 379, Known As "Semi-Sane II", towing a 2014 Voltage 3818, 45 foot long toy hauler crammed full of motorcycles of all types. Visit my photo web site where you will find thousands of photos of my motorcycle wanderings and other aspects of my life, click this link. http://mr-cob.smugmug.com/ Link to comment Share on other sites More sharing options...
MrSeas Posted May 6, 2016 Report Share Posted May 6, 2016 No pyrometer....to see what your EGT's are? Link to comment Share on other sites More sharing options...
mr. cob Posted May 6, 2016 Author Report Share Posted May 6, 2016 No pyrometer....to see what your EGT's are? Howdy MrSeas, There is no pyro gage on the dash, and I couldn't find one on the scan gage, I am "assuming" the ecm would stop fueling before the egts got to the danger point. If anyone has any information concerning the ecm and its ability to limit egts I am interested in hearing about it. Thanks. Dave 2001 Peterbilt, 379, Known As "Semi-Sane II", towing a 2014 Voltage 3818, 45 foot long toy hauler crammed full of motorcycles of all types. Visit my photo web site where you will find thousands of photos of my motorcycle wanderings and other aspects of my life, click this link. http://mr-cob.smugmug.com/ Link to comment Share on other sites More sharing options...
Nuke-E Posted May 6, 2016 Report Share Posted May 6, 2016 Dave, I've seen similar on my truck. On nice flat drives, lower speeds maybe yield a little better mileage, but especially in rolling hills I do same or better at higher speeds. I'm usually running between 65-70, but even at speeds much faster I never saw any real penalty at the pump. As far as EGTs, about the highest my factory gauge has ever shown is about 800F--well below danger zone--and that was climbing out of Laughlin towards Kingman in 110 degree weather. 45' 2004 Showhauler -- VNL300, ISX, FreedomLine -- RVnerds.com -- where I've started to write about what I'm up to Headlight and Fog Light Upgrades http://deepspacelighting.com Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted May 6, 2016 Report Share Posted May 6, 2016 Look on the downpipe from the turbo, or near the back exhaust manifold to see if there is a pyrometer in place. No pyro- no EGT gauge, and no way for the ECM to determine a temp. Most of these large diesels have an operating range of several hundred rpm where they are most efficient no matter the road speed. Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
Nigel Posted May 6, 2016 Report Share Posted May 6, 2016 Dave I have a Scan Gauge in my diesel smart and also have found that sometimes the fuel economy is better running one gear lower and keeping the rpm up. Mine is set up with both instant and average fuel economy, that way I try to keep my instant number better than my average number. I think I improve my economy by twenty percent when I pay attention to the gauge. It will pay for itself in no time. Nigel 2006 Volvo VNL 430, 2006 smart cabrio cdi, 2000 Triple E Topaz 30' Link to comment Share on other sites More sharing options...
mr. cob Posted May 6, 2016 Author Report Share Posted May 6, 2016 Howdy All, Thanks for the feed back, good to know I am not imagining the results I got. Dave 2001 Peterbilt, 379, Known As "Semi-Sane II", towing a 2014 Voltage 3818, 45 foot long toy hauler crammed full of motorcycles of all types. Visit my photo web site where you will find thousands of photos of my motorcycle wanderings and other aspects of my life, click this link. http://mr-cob.smugmug.com/ Link to comment Share on other sites More sharing options...
JEEPOHOLIC Posted May 6, 2016 Report Share Posted May 6, 2016 I want to get a second gauge and stack them so I can watch 8 different parameters Link to comment Share on other sites More sharing options...
RandyA Posted May 7, 2016 Report Share Posted May 7, 2016 I am running the Silverleaf VMSpc on a Acer Netbook in my truck with the D12 and a standard 10 speed manual transmission. One of the first efficiency improvements I noticed was to stay in 8th gear up to 45 mph, 9th gear between 46 and up to 55 and to NOT get into 10th at a lower speed. This smacked right in the face of getting into the higher gears ASAP to get the best mileage. I now run 9th more often than I did before installing the VMSpc and avoid shifting into 10th until I am over 55. As far as getting better MPG running 60-62 on the Interstate I found that was a false assumption. You are better off to forget speed and pay closer attention to engine load. Setting up a histogram with the gauge for engine load gives one a great picture of what is happening over time. This, of course, dovetails with what David has shared about his Showhauler MPG. A good explanation as to why it works this way can be found here. I am still learning and experimenting with the different parameters I can monitor with the flexibility of the VMSpc. My best efficiency related to load, speed, turbo boost, gear and RPM have yet to be finalized. I need more time on the road under varying conditions to analyze the captured data. BTW - I have a Scan Gauge on my GMC dually with a 7.4 gas engine. I love it! Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
Jack Mayer Posted May 7, 2016 Report Share Posted May 7, 2016 I have found the same thing.....sometimes running faster is more efficient. That was on my autoshift ISM 400hp/1450 torque. On my D16 Volvo the computer/trans is so smart that I'm not sure what works best. The durn thing coasts down hills, after all BTW, I have a VMsPC for older trucks I'll sell if someone wants it. I'll have to dig it up and confirm what it will work on....but I think pre-2005 Volvo's. I have a new verwion with wifi for this truck...but I have to get around to installing it.....my tablet PC is acting funky which I have to solve first. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted May 7, 2016 Report Share Posted May 7, 2016 I might be interested in that Jack. Provided it will work on the '98 Cummins M-11 with manual trans. Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
Jack Mayer Posted May 7, 2016 Report Share Posted May 7, 2016 I might be interested in that Jack. Provided it will work on the '98 Cummins M-11 with manual trans. Do you have the electronic bus in that truck? The M-11 has less electronics than the ISM. Randy might know.....Otherwise I'll have to research it... In any case, I'll not have the opportunity to pursue this until we get the campground open next week. Plus I have to start testing the Max Signal amp and some nifty new WiFiRanger stuff..... not enough hours in the day. Who said they get bored in retirement?? Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted May 7, 2016 Report Share Posted May 7, 2016 Do you have the electronic bus in that truck? The M-11 has less electronics than the ISM. Randy might know.....Otherwise I'll have to research it... In any case, I'll not have the opportunity to pursue this until we get the campground open next week. Plus I have to start testing the Max Signal amp and some nifty new WiFiRanger stuff..... not enough hours in the day. Who said they get bored in retirement?? We have a grey round plug under the left side of the dash. Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
RandyA Posted May 7, 2016 Report Share Posted May 7, 2016 Jim - if you have the gray round plug the VMSpc Jack has should connect fine. If not, I can tell you what pins to tap (there are only two plus 12 VDC). Not sure what JIB Jack has but it most likely it has a nine pin RS232 port for output to the PC. To use a more modern PC with no RS232 you need to purchase a RS232 to USB cable and install the associated drivers. I am using the Sabrent cable and it works great. My netbook runs Windows 10 and the Windows 8 drivers from Sabrent work OK. For engine type I select the Cummins 450 HP rather than the Volvo D12 as the D12 engine software won't compute HP and Torque (derived from load and RPM) - the software isn't set up right for the D12. But, the data stream for the Cummins is identical to the D12 so no sweat. There are scores of different engines to select. The neat thing is VMSpc will run on most any PC - even an old one with Windows 95. I have a little RGB to composite video converter that allows use of a generic 7" video display if you want to hide a PC in a cabinet. I'm not using it but when testing it produced a readable display. Once VMSpc is installed you need to build your gauges - you can select any of them, put them where you want and select a color, size, warning lights and sounds, text, background, etc. Gauges not defined in the OEM software are created by using the PID sniffer feature. I have several gauge screens, one has Microsoft Streets and Trips 2013 in the middle and the gauges on the sides. Lots of possibilities and fun! I'm still learning and designing Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
RandyA Posted May 7, 2016 Report Share Posted May 7, 2016 I want to get a second gauge and stack them so I can watch 8 different parameters If you want to monitor that much data consider the VMsPC from Silverleaf. Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
sclord2002 Posted May 8, 2016 Report Share Posted May 8, 2016 Dang, Randy....if you are enjoying the Silverleaf that much, you need to sweeten the trade we made. Seriously, I am glad that it is working out well for you. Soooo, the Cummins engine file will show HP and engine Load and the Volvo engine file won't ?? Have you had any more discussion with Silverleaf tech support or just decided that the Cummins file is satisfactory ? Hope you are all well....give Nancy a hug for me and give Oscar a treat and an ear scratch. Charlie Don't ever tell a soldier that he doesn't understand the cost of war. Link to comment Share on other sites More sharing options...
JEEPOHOLIC Posted May 8, 2016 Report Share Posted May 8, 2016 Randy, I have thought about this after reading your posts, and looking at the web site, but Im far to technically challenged and dont really have room for a lap top on my dash of our FL-60 Sport Chassis, now maybe something like the size of a tablet might work and some training on how to set up and the functions of the unit, and suggestions ? Link to comment Share on other sites More sharing options...
Jaydrvr Posted May 8, 2016 Report Share Posted May 8, 2016 If Jim doesn't find a need for the VMsPC, I may be interested also.. Link to comment Share on other sites More sharing options...
Jack Mayer Posted May 8, 2016 Report Share Posted May 8, 2016 Randy nailed it.....that is the one I have. For display, you can use a Windows tablet, or one of the hybrid computers. It takes up very little space. You don't need a fullblown laptop. On the VMsPC I have you do need to use a physical cable so you need the adaptor Randy described and a USB port on the tablet. Be careful in buying Windows tablets because some do not have a USB port. I won't get to digging this out for at least a week. But once I do I'll post it with an ad and pictures. I'll also look to see if I have a W tablet that I can let go with it..... It is a VERY nifty device for those that want to know what is going on. I doubt it will continue to work with the NEW Volvo's that are encrypting the data bus. But my trucks are not that new. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted May 8, 2016 Report Share Posted May 8, 2016 Sounds great. Stay warm opening up the campground! Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
