Legendsk Posted November 16, 2015 Report Share Posted November 16, 2015 Actually, I use my RV gas oven a lot. It's a great place to store my George Foreman grill and a frying pan. Haven't ever lit it. My toaster oven has been ok, but is even a little smaller than the RV oven. I've been thinking of getting an induction cook plate. I can see that I really want a griddle and a grill for it (then George can go away). When I used to go camping I had a portable oven that would work on a propane gas stove or camp fire. I haven't been able to find one that will work with an induction cook plate, but that seems to me like it would be a good seller. With one of those I could get rid of the toaster oven too. Does anyone have an oven that works on an induction plate? A link to one? TIA Si F-250 SCREW 4X4 Gas, 5th NuWa Premier 35FKTG, Full Time, Engineer Ret. Link to comment Share on other sites More sharing options...
lappir Posted November 16, 2015 Report Share Posted November 16, 2015 I really wanted my gas unit to have the ability to really use my griddle with it. I did during my first month when it was always below freezing but when I got to Florida and tried to use it the heat it generated inside was awful. Started using the induction plates and have ever since. Do I miss my griddle, yes some, but it will have to get real cold before I start using it with the gas cooktop. Would like to have one to use with an induction system. I find that I don't "NEED" on but maybe just want one. Rod White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
budeneighe Posted November 16, 2015 Report Share Posted November 16, 2015 You say your are "gasless"??? I assume you mean for cooking? Or do you mean you replaced your propane furnace and your propane hot water heater as well? Gasless for cooking. I corrected the original post, thanks. Still have gas to back up my heat pump, though. RVBuddys Journal Our progress into full-timing.Budd & Merrily ===-> SKP# 088936 Other Websites:---> Hub of all my blogsClifford - 2000 VNL64T770 :: DakotR - 1999 C40KS King of the Road :: $PRITE - 2013 Smart Passion w/cruise Link to comment Share on other sites More sharing options...
budeneighe Posted November 16, 2015 Report Share Posted November 16, 2015 I really wanted my gas unit to have the ability to really use my griddle with it. I did during my first month when it was always below freezing but when I got to Florida and tried to use it the heat it generated inside was awful. Started using the induction plates and have ever since. Do I miss my griddle, yes some, but it will have to get real cold before I start using it with the gas cooktop. Would like to have one to use with an induction system. I find that I don't "NEED" on but maybe just want one. Rod Cast iron works fine on Induction as long as it does not have little "legs" on it. Just have to get the right size. You can start looking here: RVBuddys Journal Our progress into full-timing.Budd & Merrily ===-> SKP# 088936 Other Websites:---> Hub of all my blogsClifford - 2000 VNL64T770 :: DakotR - 1999 C40KS King of the Road :: $PRITE - 2013 Smart Passion w/cruise Link to comment Share on other sites More sharing options...
lappir Posted November 16, 2015 Report Share Posted November 16, 2015 Cast iron works find on Induction as long as it does not have little "legs" on it. Just have to get the right size. You can start looking here: Budd, I actually already have a round griddle, but a 10 inch skillet is much better. I have a large 12 X 18 for the gas range but the grease rails around it lift it too much from the induction source to work. Looked today at an induction cooktop where I purchased my gas one. Only 3 times the money I paid for the gas. Will stick with the hot plates for a while. Rod White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
richfaa Posted November 17, 2015 Report Share Posted November 17, 2015 Checked out our Nu Wave Induction cooker with our Kill-A-Watt meter. It draws 8 amps on the high setting. Helen and I are long timers ..08 F-350 Ford,LB,CC,6.4L,4X4, Dually,4:10 diff dragging around a 2013 Montana 3402 Big Sky SKP 100137. North Ridgeville, Ohio in the summer, sort of and where ever it is warm in the winter. Link to comment Share on other sites More sharing options...
Sehc Posted November 17, 2015 Report Share Posted November 17, 2015 My cheapy induction works great as a grill using a cast iron pan. It uses 1000 watts. That is 80 some 12 volt amps through the inverter. It may heat water quickly, but it still takes 10 minutes to cook spaghetti. Link to comment Share on other sites More sharing options...
docj Posted November 17, 2015 Report Share Posted November 17, 2015 It may heat water quickly, but it still takes 10 minutes to cook spaghetti. It's a common misconception that induction burners heat water magically fast. They don't. I takes a specific amount of energy to raise water to the boiling point and supplying that energy to the pot and the water can't go any faster than the wattage rating of the burner. Yes, induction burners couple the energy efficiently to the contents of the pot, but a 1000W burner has only a specific heating rate. To say it another way, a thousand watt induction burner will be only a bit faster heating a pot of water than will a thousand watt hotplate. The only difference will be the heat lost to the room when the hotplate is doing the job. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
chirakawa Posted November 17, 2015 Report Share Posted November 17, 2015 So, a 1000 watt microwave doesn't boil water any faster than a 1000 watt hotplate? Interesting. Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
Kirk W Posted November 17, 2015 Report Share Posted November 17, 2015 So, a 1000 watt microwave doesn't boil water any faster than a 1000 watt hotplate? Interesting. That was not what Joel is saying. The actual energy to the water required is exactly the same, the differences are in the efficiency of getting it there. A microwave will waste less energy than most sources as is true of the induction plate. But unless you put a very small pan on a very large burner, the gas stove top isn't as wasteful as some folks expect. The microwave is by its design the most efficient of the three for several reasons. Induction has nearly as much energy loss to the surrounding air as does a gas burner if you use the proper match of burner & pan, but both will loose more than a container that is enclosed inside of the microwave where energy is absorbed into the contents and heated from the inside out. With either a gas or an induction heat source, the heat is generated outside of the contents you wish to head and must be transmitted to the contents and some of that heat is lost to the surrounding air. Heat transfer is better with induction, but loss from the walls and top of the pan would be little if any different. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
chirakawa Posted November 17, 2015 Report Share Posted November 17, 2015 It's my understanding that in a typical hotplate, the appliance itself is heated through electrical resistance and then that heat is transferred to the cooking pot through conduction. In the induction process, the heating appliance is not heated at all, that magnetic energy is applied to the cooking pot which causes the pot to heat up. The heat is then transferred to the food. If that's the case, then it is much more efficient use of energy since energy is not wasted on heating the hotplate itself. In microwaves, I understand that radio waves are concentrated on the target food to cause molecular activity within that food. Molecular activity is the essence of heat. So, no appliance must be heated, no pot must be heated, only the food must be heated. Of course, my elementary understanding of the physics involved could be incorrect. It has been before. Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
mohamer Posted November 17, 2015 Report Share Posted November 17, 2015 Efficiency, an interesting term. If you power the Induction cooking apparatus with an inverter you need to consider the efficiency of the inverter. There is always a loss when we modify power, battery losses can be high when you consider the power put into the battery and what you can get out of it. Inverters have some power loss in the inversion process. I work with this a lot when working with transmitters and losses in amplifiers etc. My Motorhome came with a Propane stove, we use it a lot, the capital expense is paid, we paid it when we purchased the MH. I also cook outside a lot, I have a propane grill, charcoal grill, and sometimes I use a fire ring to cook with, it all depends on the situation. The other day we pulled into a campground and they had a sign up "no wood or charcoal fires allowed" due to a burn ban. So I used the propane grill to cook the steak. Just takes situational awareness. I love my American Junk RV!!! Southwind 35P ARS KB0OU EX Submarine driver Link to comment Share on other sites More sharing options...
outwestbound Posted November 24, 2015 Report Share Posted November 24, 2015 My Carri Lite had an electric cooktop when I bought it in 2014. For boondocking, I replaced the electric Amana top with a Seaward (Princess 2277) marine gas two burner top with 7,000 and 10,000 btu burners. This allowed me to repurpose the electrical capacity, which is a scarce commodity in these little trailers. I'm no cook, but I know that there seems to be a great deal of personal preference involved for those that are. 2011 F350 Lariat, 6.7L, 3.73, CC, DRW, 8' Bed, Reese Elite 25K, TST 507 2011 Carri Lite 36XTRM5, MORryde IS/ Pin Box, Hydraulic Jacks/ Brakes, 17.5" Wheels/ G114 Tires Solar 960 watts, (2) 50amp controllers, 3,000 watt hybrid inverter/charger, 830 AH batt bank WiFi Ranger Elite Pack; weboost Drive 4G-X Link to comment Share on other sites More sharing options...
ganto Posted November 25, 2015 Report Share Posted November 25, 2015 I have induction now and it's ok I hate having to run the gen set even with 8 AGM batteries it still can't handle the load. and you don't need special cookware to go along with it. Link to comment Share on other sites More sharing options...
Yarome Posted November 26, 2015 Report Share Posted November 26, 2015 I have induction now and it's ok I hate having to run the gen set even with 8 AGM batteries it still can't handle the load. and you don't need special cookware to go along with it. If you're talking 8 - deep cycle AGM's then you should have more than enough available energy to run your induction plate (judiciously). The shortcoming is more likely to be in your inverter. I'm assuming of course that if you're talking batteries and genny's you're talking about a boondocking situation. Link to comment Share on other sites More sharing options...
ganto Posted November 26, 2015 Report Share Posted November 26, 2015 If you're talking 8 - deep cycle AGM's then you should have more than enough available energy to run your induction plate (judiciously). The shortcoming is more likely to be in your inverter. I'm assuming of course that if you're talking batteries and genny's you're talking about a boondocking situation.yes I'm talking about batteries and genius and boondocking. I have a 5000 watt inverter more than enough power for the cooktop I'm gonna have to bring it in again for service and see what's going on as road trek claims that I should be able to run the a.c. unit for at least ten hours and I can't even get five hours out of it. The etrek is a complete price of carp I wish I researched before I bought!!! Link to comment Share on other sites More sharing options...
Yarome Posted November 26, 2015 Report Share Posted November 26, 2015 I have a 5000 watt inverter more than enough power for the cooktop There certainly seems to be something hinky going on there. You should be having no problem whatsoever running a single induction plate. Do you have any other heavy loads on when trying to use it? You mentioned the A/C unit in a different context, but are you running your A/C while trying to cook? How low do your batteries generally get between charges? Link to comment Share on other sites More sharing options...
ganto Posted November 27, 2015 Report Share Posted November 27, 2015 There certainly seems to be something hinky going on there. You should be having no problem whatsoever running a single induction plate. Do you have any other heavy loads on when trying to use it? You mentioned the A/C unit in a different context, but are you running your A/C while trying to cook? How low do your batteries generally get between charges? somethings going on!! I run one thing at a time when i'm boondocking so i'm not running everything at once unless i'm plugged in. I really don't like to cook inside because it gets to hot and to messy . it's going back to the stealership this week to have them look at it. I never looked at my battery levels between charges that might be something to look at also as that could be the problem I know that batteries can build a memory effect ( not sure about AGM batts though ). Link to comment Share on other sites More sharing options...
