lappir Posted December 18, 2014 Report Share Posted December 18, 2014 For the first time since going to a laptop as my primary computer I apparently let my guard down. I spilled liquid on the keyboard. Several ounces. I then watched as the screen showed me that I couldn't just wipe it off. I immediately turned the unit over and pulled the power supply and battery. It has had a fan blowing across it all night. How long do I wait until I try to power it back up, or do I just go buy a replacement and find someone to recover my data? Have been thinking about an upgrade but Nad planned to wait until after the New year. Thanks, Rod White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
DuffMan Posted December 18, 2014 Report Share Posted December 18, 2014 Diet or sugared? Sugared - say bye to the keyboard. But replacing keyboard is pretty cheap. I got a replacement for my old laptop for $25.00 on ebay and replacing is pretty easy. Plenty of YouTube videos with step by step for most models. Even if you get a new laptop - make sure it has two hard drive interior slots. Since your hard drive is probably OK, you can just move it to the new laptop as a secondary drive. Link to comment Share on other sites More sharing options...
Bill Joyce Posted December 18, 2014 Report Share Posted December 18, 2014 Your computer should be repairable or recoverable. Youtube and a search engine are your friends. You can get an external USB case to put your old hard drive in and have access to all your data. No need for two internal slots. 2004 40' Newmar Dutch Star DP towing an AWD 2020 Ford Escape Hybrid, Fulltimer July 2003 to October 2018, Parttimer now. Travels through much of 2013 - http://www.sacnoth.com - Bill, Diane and Evita (the cat) Link to comment Share on other sites More sharing options...
Kirk W Posted December 18, 2014 Report Share Posted December 18, 2014 Rod, drying is the key to the first step, but even once dry there is risk to doing a test of it. I guess it just depends upon how critical to you the data on the computer is about what I would do next. To answer your question, the time required to completely dry out will depend upon how wet things were, how far inside it got, and the temperature & humidity of the blowing air. I would give it at least 24 hours before any testing. If things are critical, you should take it to a shop and they will disassemble it to visually check for any remaining signs of moisture or remains of the drink before applying power. As others have stated, the kind of drink is a major factor. Distilled water seldom causes any problems once dry because it leaves no residual contamination. Most drinks do leave something behind that can cause problems and sugar is one of the worst. Coffee that has cream & sugar is really nasty as is a carbonated drink. If this was anything of that type, you need it cleaned inside before you power up. If just water, you probably will be OK but there is no sure way of knowing without disassembly and even then there is a risk that the damage has already been done. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Medico Posted December 18, 2014 Report Share Posted December 18, 2014 The drying out process has been discussed quite a bit but there is another side to this issue as well. To get into the other side of the issue, this points out why backing up our data is so important. Not only is backing up so important, but Imaging the entire hard drive regularly will let you get things back much quicker. If, for example, instead of spilling a liquid, you get a bad virus that wipes things out just as surely as the liquid spill, what do you do? This is where a full system Image allows you to format and restore the entire HD in about 20 minutes right back to where it was when you created the Image. (Cloning is similar to Imaging except that Imaging allows multiple copies of the system backup on the same recovery media). Using the Recovery Drive on your PC will get you back to the factory setup, but just think how many changes you have made since you first got your new PC. An Image will save ALL those changes in the compressed Image file so that all apps and customizations will be recovered as well. Now with an up to date backup of your data, you are back into business in less than an hour. Sorry to have diverged from the original question but I felt the backup issue is too important to not mention in this discussion. GS Lifetime #822128658, FMCA #F431170 2012 Airstream Mercedes Interstate Extended Class B Link to comment Share on other sites More sharing options...
docj Posted December 18, 2014 Report Share Posted December 18, 2014 I can attest to the fact that 2013-2014 has been a rough couple of years for our computers--some red wine spills (nasty stuff on electronics) and objects falling out of cupboards. I've learned my lesson with regard to backups! I'm currently using two external drives, one of which has an image of my drive and the other has all my pictures and documents files in their native, uncompressed formats. That way I can either replace my hard drive and use the image, if the drive should fail, or I can transfer all the important files to a new computer, if this one fails totally. I even have an entirely spare computer, my older Core i7 Inspiron, which I resurrected after destroying both its keyboard and LCD screen. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
rdickinson Posted December 18, 2014 Report Share Posted December 18, 2014 Another option is to get a wireless keyboard. It comes with an adapter which goes into the USB port. My laptop is 10 ft away, I have a 19" monitor on the coffee table a couple of feet away, or for Movies there is a cable which goes from computer to 42" Smart tv. Link to comment Share on other sites More sharing options...
socaltoolguy Posted December 18, 2014 Report Share Posted December 18, 2014 Do a google search for your make and model of laptop. There are many good websites and youtube videos on how to disassemble your unit. I have done it many times. Just take your time and you can do it. Good luck., Ray 2001 Fleetwood Southwind 32V 2011 Scion XB toad Link to comment Share on other sites More sharing options...
rvpopeye Posted December 18, 2014 Report Share Posted December 18, 2014 Just a reminder to all of another great use for having an image of your computer drive. The recent rash of ransomware hacker attacks , where your computer is encrypted and you have to pay an untraceable ransom(often several hundred dollars) to (maybe) get the encryption key and recover your data. Similar to a drive dying or drowning or dropping your laptop/phone/tablet etc.( You lose all your data.) That image is a great way to get it all back! I dropped my phone in the toilet recently and doused it in 91% alcohol , then put it in front of my rig's dash heater vent for a 3 hour drive.........powered it up and back to normal operation. I was lucky.....I wasn't stepping on the flush pedal !!!! Good luck with your fix. Several good ideas posted here. stay tuned popeye Link to comment Share on other sites More sharing options...
edatlanta Posted December 18, 2014 Report Share Posted December 18, 2014 I poured a cup of coffee on the keyboards of two laptops over an 18 month period before I got the one I have now. I use an online backup so I never lose any data. You ask why I didn't try to fix the two? A cup of coffee isn't too bad you say? That might be right on the coffee, but each cup had a shot of Bailey's in it. I didn't even try to save them because of the Bailey's and they were $400.00 laptops anyway. Now the one I have now is much nicer and I keep my coffee cup far away. Ed KM4STL2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch2010 Jayco Designer 35RLTS, RV Flex Armor Roof Link to comment Share on other sites More sharing options...
docj Posted December 18, 2014 Report Share Posted December 18, 2014 I poured a cup of coffee on the keyboards of two laptops over an 18 month period before I got the one I have now. I use an online backup so I never lose any data. You ask why I didn't try to fix the two? A cup of coffee isn't too bad you say? That might be right on the coffee, but each cup had a shot of Bailey's in it. I didn't even try to save them because of the Bailey's and they were $400.00 laptops anyway. Now the one I have now is much nicer and I keep my coffee cup far away. Fortunately for me, we had several Dell Inspirons with the same size screen. A YouTube video showed me how to remove the broken screen from my Core i7 unit and replace it with the one from my dying Core i3 laptop. Keyboard swaps on Dell's are easy but I ended up "washing" the wine off the damaged one since the BIOS didn't seem to like the other one. But, I also have a new Toshiba with an i7 and 16GB of RAM which is so much faster that now the old i7 is a spare; just in case there is another disaster. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
Mike and Claudia Posted December 19, 2014 Report Share Posted December 19, 2014 If it is a Dell, you can send it in to Dell, (They will even send you the box) They had us remove the hard drive, and send in the unit. They upgraded it, cleaned it, replaced whatever we needed to be replaced did the whole enchilada for $ 199.00. I practically got a whole new computer (with the old hard drive) for way less than what a new computer would be. Traveling America in "God's Grace" Link to comment Share on other sites More sharing options...
lappir Posted December 20, 2014 Author Report Share Posted December 20, 2014 Not a Dell. Toshiba, has been a good computer for the past 4 to 5 years. Thinking about a touch screen, use them at work and seem to poke the screen often at home and wonder for an instant why it doesn't respond. Wonder how much different the home version is compared to business. May go out today and see what's on sale. Rod White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
Pat & Pete Posted December 20, 2014 Report Share Posted December 20, 2014 Once you find what you want , you might take a look at Newegg.com . They seem to have some pretty good deals . Goes around , comes around . Link to comment Share on other sites More sharing options...
lappir Posted December 21, 2014 Author Report Share Posted December 21, 2014 Picked up another Toshiba yesterday at the local BJ's Wholesale, $50 less there than any of the surrounding Best Buy, Office Max, Office Depot and Costco. Almost went with one of the new "All in One" Desktops but when comparing RAM, most of them had only 4 GB and the laptop has 12 GB also there were the Intel vs AMD processors. I got a 15.6 inch screen, 12GB RAM,1TB hard drive for under $800. But I may take it back. This Windows 8.1 is CRAP you have to be on line to sign into the computer and there is so much wasted memory on games and lot's of other stuff that I will never use. Of course the things I would use are only trial versions and you have to pay more to actually use them. The keyboard is good. on this model, it has larger keys and they are spaced with part of the base and just not a keyboard dropped in a hole. The touch pad is quite sensative and I haven't found a way to turn it off yet. On my previous Toshiba, there was a small button at the bottom that would deactiate the touch. I'd rather use a mouse most of the time anyway.Really haven't had much luck with the touch screen. it's sure not like the Android. The big question is if I decide to turn this one back in what do I need to do to remove all of my private data that was required just to get to the start page on the PC. They always say they require all the private information to keep you safe. Well allowing me to keep my information private in my own way would be much better. IF someone else doesn't have that information they can't lose it. I know you can always make up the information but what good is that, and how do you remember what is not real????? It took me 15 minutes to get signed into the computer this morning. It kept asking me for the last password I used since I wasn't "ON LINE". Finally I had to bring up my Foxfi, was able to sign into the Microsoft site and change my password and delete all the emails from them regarding the wrong password and changing of my password. Will I remember what I changed it to tomorrow? I don't know. The funny part is when I came to this site my password was remembered. Guess since I was using Foxfi it remembered the something. Rod White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
docj Posted December 21, 2014 Report Share Posted December 21, 2014 Picked up another Toshiba yesterday at the local BJ's Wholesale, $50 less there than any of the surrounding Best Buy, Office Max, Office Depot and Costco. Almost went with one of the new "All in One" Desktops but when comparing RAM, most of them had only 4 GB and the laptop has 12 GB also there were the Intel vs AMD processors. I got a 15.6 inch screen, 12GB RAM,1TB hard drive for under $800. But I may take it back. This Windows 8.1 is CRAP you have to be on line to sign into the computer and there is so much wasted memory on games and lot's of other stuff that I will never use. Of course the things I would use are only trial versions and you have to pay more to actually use them. I also enjoy my new Toshiba; mine has 16GB of RAM and very powerful Core i7 processor. Yours sounds similar. Don't give up on Windows 8.1 that easily. You don't have to be online in order to sign in. You can create local user accounts that are not associated with the "cloud." Just follow the instructions in the attached picture: Joel Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
lappir Posted December 25, 2014 Author Report Share Posted December 25, 2014 I guess I waited long enough. Today was my first real day off since the computer disaster. (That I didn't have a lot of other stuff I needed to do.) Tried to remove the cover to the computer to see if there was any residue that I could remove. Took out a dozen or so screws, but the three under the cd/dvr drive wouldn't accept any of my multitude of screw driver bits, so I put the screws all back in and installed the battery. The computer booted up after initially going into the safe mode and seems to be no worse for the wear. Am still just on battery power so hopefully nothing happens when I plug in the power cord. Merry Christmas to all. Rod White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
Kirk W Posted December 25, 2014 Report Share Posted December 25, 2014 Perhaps Santa & the elves cleaned it up for you! Very good news indeed. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Solo18 Posted December 26, 2014 Report Share Posted December 26, 2014 I have two external hard drives since I use my laptop for work and I would hate to lose all My photos. One stays with me in my motorhome in a drawer protected from heat with bubble wrap. Other stays at my sons house in his gun safe. I switch them out periodocally. Having one hard drive is better than none but if you gave a fire or crash you need one stored in a second site. Link to comment Share on other sites More sharing options...
DuffMan Posted December 26, 2014 Report Share Posted December 26, 2014 I keep one in the RV and one in the toad. The one in the toad is used for a weekly image backup. Chances of loosing both is slim. Link to comment Share on other sites More sharing options...
yourpcgeek49 Posted January 1, 2015 Report Share Posted January 1, 2015 Glad to hear your machine came back to life! In the general arena of hard drive disaster recovery, you can buy a $20 SATA to USB adapter (Sabrent USB 2.0 to 2.5"/3.5"/5.25" Hard Drive Converter) that will allow you to remove the drive from your old machine, connect it to this device & plug it into a working PC. You can read files, transfer data, etc. - as long as the old drive is still working. I have used several different brands and they all seem to work just fine. If you are going to use a drive regularly, the external drive enclosure is the right way to go. But if it's just for a one time data recovery; these are a lot cheaper. Judith & Mark - Class of 2015 2011 Chevy Silverado 3500 dually 6.7 L Diesel 2011 Heartland Bighorn 3670 (38') Blog: http://www.yourpcgeek.com/blog Link to comment Share on other sites More sharing options...
lappir Posted January 1, 2015 Author Report Share Posted January 1, 2015 Thanks, Yup it's still working. Tried to buy a backup hard drive at BJ's a couple days ago. The 1TB was out of stock so I backed up using some flash drives for the mostly important stuff. Rod White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
